110 TLB Adding Rear Remote Hydraulics
/ 110 TLB Adding Rear Remote Hydraulics #1
threepiece
Farmington, Mi
Kubota L3400 John Deere110 TLB Wheelhorse 520H
After searching for two days I could not find a kit for the 110 TLB. I am somewhat surprised. I suspect there would be a significant demand for such a kit and there doesn’t seem to be much complexity to create one, or so I think. If anyone knows of a kit available please feel free to tell about it.
What I want to accomplish is adding three remotes to operate a grader box. Two remotes to operate the top and tilt on the three point hitch and one remote to operate the scarifiers on the grader box.
/ 110 TLB Adding Rear Remote Hydraulics #2
That machine is no less than 12 years old, not a lot of companies are going to make kits for machine that old, especially ones that where usually sold with full hydro packages already.
Since the backhoe will be removed it seems logical to use the lines remaining on the tractor to feed the remotes. I think sourcing control valves with the same port size is also a good idea. This way there will be know concern of damage or overheating. Am I on the right track here fellows?
/ 110 TLB Adding Rear Remote Hydraulics #4
Yes,
You can use the "power beyond" that feeds/fed the backhoe to add in a new valve stack. You can configure the stack as you'd like, even adding an electric spool for a front remote if you use ones from Bucher.
That was a quick response.
Well the machine wasn’t always 12 years old. Has there never been a kit made?
/ 110 TLB Adding Rear Remote Hydraulics #6
As I wrote, they where usually sold with all the hydro options available from JD, and generally only in the TLB configuration so no rear remotes was need by most customers. The market was smaller contractors and builders who had no use for a 3PH, thats why so many guys in the last few years have looked for them (the 3PH hardware) because they bought used machines from business and they didn't come with them. It too was an option from JD.
Adding remotes is fairly easy, there are 100's of threads here on TBN about it, the theory is all the same no matter the model or brand.
/ 110 TLB Adding Rear Remote Hydraulics #7
Something like this maybe? :unsure:
Yes adding rear remotes to the 110 TLB seems particularly easy as the hydraulic lines from the removed backhoe are easily accessible. I wonder how many 110’s were fitted with rear remotes from the factory. I suspect a significant amount were not due to the primary use of the backhoe. I bought mine with 500 hours, I’m fairly sure the backhoe was never removed.
Yes something very much like this! My plan is to make a consolidated unit like the one shown in your picture but with a quick attach feature. This way it won’t be causing interference when the backhoe is used. Taking advantage of the existing quick couplers should make this feasible.
Do I see a set of hoses going to the front on this set-up?
/ 110 TLB Adding Rear Remote Hydraulics #10
It looks like it, but I do not know for sure, it is a customer's tractor from years ago. All I provided was the valve set and the couplers in a coupler mount. The customer did everything else.
/ 110 TLB Adding Rear Remote Hydraulics #11
I watched a pretty good video on YouTube a while back. The person added rear remotes to a Kubota L48. He utilized the supply/return lines for the backhoe to energize a removable valve set. The valve set was mounted with "shoulder" bolts that replaced the standard fender bolts. The mounting bracket had hole/slots to drop the bracket onto when the backhoe was removed. It looked like a pretty slick set up.
Do a YouTube search including Kubota L48 and rear remote hydraulics as the search terms and it will pop up. This is on my to do list as well.
Doug
2014 BOBCAT T650 SKID STEER (A65053)
2014 BOBCAT T650...
2015 Jeep Renegade Latitude SUV (A64557)
2015 Jeep Renegade...
2017 Nissan Altima Sedan (A64557)
2017 Nissan Altima...
2001 Belshe Backhoe Trailer (A64194)
2001 Belshe...
Club Car Carryall 6 Medical Utility Cart (A64553)
Club Car Carryall...
2005 KENWORTH T800 T/A 6X4 DAY CAB TRUCK TRACTOR (A67147)
2005 KENWORTH T800...
