No brakes
/ No brakes #1
gramer
I'm fairly new to the tractor repair side of things but I need some input. I have a 2017 JD 5045 2wd, recently the brakes started going to the floor after about two hours of use, the steering got choppy while bush hogging. I changed the hydraulic fluid as well as the hydraulic screen (which was covered in gunk) and the old fluid looked a lot like chocolate milk. I ran the tractor for approx thirty minutes this afternoon .....the steering is good, however the brakes go to the floor even before I cranked it, after cranking and running the bush hog I still have no brakes. No problem with the loader, it works great. Any advice is greatly appreciated..........................! Thanks
/ No brakes #2
Candidly, I don't believe I've ever used the brakes on either of my Kubota's. I need to check and see if they even work.
/ No brakes #3
Dang flatlanders, 'ain't got no appreciation for gravity!
/ No brakes #4
If it were a car, I'd guess that the O rings in the master brake cylinder are shot. But I'm not familiar with the brake system on your tractor.
2019 Posi Track RT25 Compact Track Loader Skid Steer (A61572)
2019 Posi Track...
2013 Infiniti JX35 AWD SUV (A61574)
2013 Infiniti JX35...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2015 Chevrolet...
2023 Freightliner Cascadia 116 S/A Day Cab Truck Tractor (A61573)
2023 Freightliner...
Kubota MX5400 land mgmt package
Kubota MX5400 land...
DSP 900 Balancer with Split Weight (A63689)
DSP 900 Balancer...
