Is boiled linseed oil a useful rust preventative for seasonal implements stored outdoors?
   / Is boiled linseed oil a useful rust preventative for seasonal implements stored outdoors? #31
I use a small amount of pure lanolin mixed with a light carrier oil... like Miracle Oil or transmission fluid. Lanolin has been found to be the best overall long-term protector. You can find pure lanolin online easily, then I just warm a little of the carrier oil and melt in some lanolin, then put it in a spray bottle and mix it with a balance of the carrier oil. For a commercial lanolin based protector, Fluid Film works great, but is fairly expensive.
WD-40 works only for a very short term solution, and will definitely not protect anything for very long. God gave sheep a much better and longer lasting protective lanolin oil.
   / Is boiled linseed oil a useful rust preventative for seasonal implements stored outdoors? #32
linseed oil is useful for garden tool handles, etc. note that being organic, it will eventually turn dark from algae or bacterial growth when exposed to elements
NOTE: linseed oil soaked rags after the job will go through a heat and possible spontaneous combustion will occur. nearly had a garage fire when i found the rags smoking, dispose pf properly
   / Is boiled linseed oil a useful rust preventative for seasonal implements stored outdoors? #33
Years ago, I worked in a woodworking shop. We had some spilled linseed oil. I soaked it up with sawdust and disposed of it in the trash dumpster. Later that day, the dumpster was ablaze.
   / Is boiled linseed oil a useful rust preventative for seasonal implements stored outdoors? #34
Whatever I use around here had better dry pretty quickly. Even the gentile breezes are dust laden. I smear a thick coat of axle grease on the cutting blades of my Wally chipper. But that is to prevent rust.
I do store all my implements up on pallets. This definitely limits rust.
   / Is boiled linseed oil a useful rust preventative for seasonal implements stored outdoors? #35
When rebuilding my airplane and replacing the wing struts I poured hot linseed oil into the struts. I filled them full and let the struts sit at least over night. I then drained what oil would drain leaving the inside of the struts coated and preserved. It is common practice in older aircraft restoration.
   / Is boiled linseed oil a useful rust preventative for seasonal implements stored outdoors? #36
When ever I would find a road that has just been oiled I would drive my
pickup on it at 50 mph and everything under got coated and never had
any rust
willy
   / Is boiled linseed oil a useful rust preventative for seasonal implements stored outdoors? #37
If you mix it with paint thinner it will also go deeper into the wood.
For many years I have used boiled linseed oil on my wood trailer floors and they still look fresh and good looking.
I sweep the wood bed and then mix a solution of maybe 40% linseed oil and 60% turpentine. I slop it on the wood bed with a 4" paint brush and that's it. No second coats. Looks great and people think I just put new wood down.
   / Is boiled linseed oil a useful rust preventative for seasonal implements stored outdoors? #38
any rust
willy
Obviously your not a mechanic or you don;t keep your vehicles very long
   / Is boiled linseed oil a useful rust preventative for seasonal implements stored outdoors? #39
The turpentine or paint thinner allows the mixture to be thin enough to be absorbed into the pores of the wood. Pure linseed oil doesn’t soak in very well.
   / Is boiled linseed oil a useful rust preventative for seasonal implements stored outdoors? #40
Linseed oil would remain sticky. Also you have to be carefull if you get it on any rags and then leave them around in a pile. It can spontaneously combust.
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A57453)
(1) HD 24ft Free...
2011 Chevrolet Silverado 2500 Pickup Truck, 127808 Miles, Utility Rack - GREAT WORK TRUCK (A56438)
2011 Chevrolet...
207277 (A52708)
207277 (A52708)
16ft Driveway Entrance Gate with Deer Design (A57454)
16ft Driveway...
Pickup Truck (A59230)
2007 Ford F-550 Crew Cab 11ft Flatbed Truck (A55852)
2007 Ford F-550...
