You Have a Cab?
/ You Have a Cab? #41
I'm very thankful for my cab. Factory heat and A/C means I can be at it any time it's needed. We get both kinds of weather here. Hot and cold.
When it's -40 F, the wind is blowing at 40-50 mph, it's 5 am and the driveway must be opened, well we just call that "Tuesday" up here. That's winters.
When it's +100 F and 90 % humidity, there's no breeze and the pasture must get mowed, that's "Saturday". That's our summers.
The most extreme temp range I have seen so far is -45 F in winter and +105 F in summer. Those are ambient air temps, not this "wind chill" or "heat index" bullcrap.
Opening the driveways I do in winter usually only takes a couple hours (depending on how many neighbors need help). But mowing fields, I may be at it all day for a couple days in a row, depending on how big the fields are. I'm comfortable in each extreme and thankful for watching the blizzard of snow fly past the windshield while I'm sitting in heated comfort wearing just simple pants and a sweatshirt and drinking my coffee. I'm also thankful for climbing out of the cab at the end of a summer day of mowing not feeling like a wet noodle, or covered in dust, dirt and pollen. Also great fun when I encounter a wasp nest and they just fly around the cab glass looking for a way in.
/ You Have a Cab? #42
Our tractor has a cab. No problem with heat, cold, dust, bugs etc
To replace cab windows IMHO Lexan would be your best bet!
Lexan is stronger than Plexiglass:
Impact resistance: Lexan is 250 times more impact resistant than glass, while Plexiglass is 17 times more resistant. Lexan can withstand impacts without cracking, and instead bends to resist them. Heat resistance: Lexan can withstand temperatures up to 240°F, while Plexiglass begins to lose its form at 195°F.
Chemical resistance: Lexan is highly resistant to acids and chemicals, such as gasoline. Flammability: Lexan has a low level of flammability.
Lexan offers a tensile strength of up to about 10,100 to 10,200 psi (pounds per square inch
Lexan costs more that plexiglass but its worth the extra cost!
willy
/ You Have a Cab? #44
Have both but I use Cab tractor most of the time. Tired of hot weather and eating dust and feels good staying out of elements in winter. Several hours when wind is blowing 90mph and wind chill below zero.
/ You Have a Cab? #47
Main tractor (L4240HSTC) has a cab. Nice being warm in Winter and cool in Summer. Nice having glass between me and the bugs, dust and pollen.
Other tractor (Ford 1210 HST) is open cab. Recently made a carryall for the 3-point so it gets used mostly as a Gator now to haul stuff around. Until now I carried weed eaters, saws, blowers etc on the deck of the Kubota's finish mower. Sometimes stuff fell off:)
/ You Have a Cab? #48
No cab for me as I primarily use mine in the woods and would not want a cab for that. I have used my brother-in-laws cabbed tractor and much prefer my open station to be more in tune with what I am doing.
/ You Have a Cab? #49
I have two OS tractors. Would like to have a cabbed tractor for A/C, insects and dust, but the places I mow, a cab would be in the way and ain't worth the cost at this point.
/ You Have a Cab? #51
I have an articulating offset ditch & bank flail mower that can be used vertically. When I use it to trim brush and branches along my private road, I would get pelted with flying debris on my open station tractor. I would have to "suit up" with gloves, goggles and a hard hat. A cab solves that problem.
/ You Have a Cab? #54
Yeah. No way would I want to deal with a cab on my place.
/ You Have a Cab? #55
That sounds like a very expensive glass replacement just waiting to happen.
/ You Have a Cab? #58
For me, it's multiple reasons. I don't want to knock out expensive windows. I get on/off my tractor so often hooking up logs, checking if there are obstructions in my path, etc. that no way do I want to fight with a door to get in/out of constantly. I like to be able to easily hear what's going on around my tractor with no muffling of a cab, and I actually enjoy being outside whether it's warm or cold. Maybe when I'm 80, I will want a cab. Who knows...
2013 FORD F750 XLT SD SERVICE CRANE TRUCK (A62613)
2013 FORD F750 XLT...
Trailmobile Van Trailer (A63689)
Trailmobile Van...
2017 International 4300 Box Truck (A62613)
2017 International...
Deutz 4-Cylinder Air-Cooled Industrial Diesel Engine (A63689)
Deutz 4-Cylinder...
PACER 2" PUMP, BRIGGS & STRATTON ENGINE, HOSE (A64276)
PACER 2" PUMP...
2019 International LT625 Sleeper 48 (A62613)
2019 International...
