You Have a Cab?
/ You Have a Cab? #81
I have a cab because it was on the 9600 when I got it auction. AC and heat don't work, I keep the doors off and the back window open with a magnet fan on. I've never needed it in the winter, but if it comes up I'll fix the heat. The other two have canopies.
/ You Have a Cab? #82
Open. We built the barn to accommodate a cabbed unit, but I actually prefer the open station for what I do. It also helps with trees in apiary.
/ You Have a Cab? #83
Everything I have has a cab.
This is just one of the many reasons.
Are you a cab, or open station type?
Yeah that’ll get your attention if you don’t see it, I was hauling a tree stand on the back of a 4 wheeler and part of the ladder ripped a basketball size hornets nest in half that was beside the trail hanging in a little pine. At least the 4 wheeler is fast enough to get away.
/ You Have a Cab?
Best of both worlds, one of each. I've lost more mirrors, etc from my cabs when I decide it too hot/cold to use the open and do something stupid like bush hogging around heavy brush & tree areas.
my typical scenario looks like this: You watch to the left and at that very second a tree comes out and bites off your right mirror - still waiting to see that pesky tree do it (maybe I'll have to put video in the cab 😂). Then you back up to get close to the tree - because mamma wants that part of the field to look prettier, and as soon as to look through the back window another pesky tree sneaks up and hits your brush guard with a limb or something. I actually had a tree throw one of its limbs that was really high up in the tree at my door and broke the glass! There really ought to be a law!
Hey, I've got an idea, let's advocate for a bill to outlaw trees from bitting and/or hitting our tractors with any of their body parts. First offense could be No water for 30 days, 2nd offense would be removal by force numerous limbs and if it still doesn't learn it's lesson after that. It will be sentenced to death by woodstove or fireplace. 😂🤣😁
I do shredding/bush hogging for a living seasonally, among other ag services.
Those mirrors are a huge problem when cutting around and through trees. o_O
In addition to getting them knocked out of whack where you can't see where you need to, and have to get out and refocus them, they have potential to kill you, or at a minimum, trap you in the cab. If the tractor is on fire, that scenario gets serious real quick! (When your mirror folds back against the door, it can keep you from a quick exit because the door is blocked.)
When I get a tractor now, before I ever even take it out, I reposition those side mirrors to be in front of the windshield so that I can still see behind me, but the mirrors are now protected, and not so prone to getting out of focus or being a safety issue.
Still use them a lot to see behind me.
That may help save you from cutting so many trees down... ;)
/ You Have a Cab? #85
I'm glad that I have two doors, because a mirror will block the door so good it's impossible to open the door!!!
I made the mistake of not pushing the mirror back out one time when it was pushed back over the door, and then I caught the other mirror on a branch, and both doors where blocked. I had a second of concern that I couldn't get one of them pushed out far enough to open the door, and then started wondering if I could get out the back window?
I wanted to remove my mirrors and use a back up camera, but the camera doesn't have a wide enough view to replace the mirrors. Maybe two cameras? I like being able to see with the mirrors, but it's too easy to catch a branch and push them back.
I'm going to try adjusting them farther forward so they don't stick out the side so much. It's either that, or learn to stop getting too close to branches!!!
/ You Have a Cab?
Just swing those mirror around and look through the windshield at them. Try it.. If you don't like it, you can always put them back. 😉
/ You Have a Cab? #87
I wish my Mahindra had a cab with A/C, couldn't afford that when I bought the tractor.
/ You Have a Cab? #88
The mirror swivel mechanism on my L6060 is loose enough that putting a little pressure on the door will force the mirror back enough to get your hand on it.
The down side is, the mirrors are easily knocked out of position.
/ You Have a Cab? #89
The funny thing is that a snake bite doesn't hurt whatsoever, a chihuahua bites harder than a snake does.
I'll keep that in mind if I ever come across a python.
Funny thing, when I first came over to the USA I was convinced that I'd die within three minutes if bit by a rattle snake, just like in the movies.
In reality I probably would have died simply because of mind over matter. Surely there would be a physical reaction of some kind from the venom, and that would've likely made my brain decide to shut all operations down.
/ You Have a Cab? #92
lol I guess I should have said the majority of snakes, at least the ones here in the U.S. I would not want to get bitten by a green tree python!
I was bitten by a cottonmouth once and the bite felt like a wasp sting.
/ You Have a Cab? #94
No cab, its just another delicate glass box full of more stuff to break... Lights, fans, wipers, AC, heater core, 100 extra yards of wires and hoses, mirrors, radio, etc... If I made money with it or it was a field tractor, and I was in it for hours and days at a time, then sure a cab is nice then, more expense to write off! We don't seem to have many above ground wasp nests, and the rare in ground ones have never stung me. Mosquitos or blackflies are the only pests.
I kind of like my tractor like my dirtbike, atv or chainsaw, its a simple tool, add fuel and go use it for a couple hours and put it back in the shed, and do some maintenance related to its function once in a while. I wear appropriate clothing for the weather and its fine. Last night I was ditching and grading the driveway under the full moon in shorts and a t-shirt, and I got a bit dusty, so I had a shower.
/ You Have a Cab? #96
The cabs are great for the folks who just don’t enjoy their time in the great outdoors. To them I say, why the heck don’t you get an office or factory job ?
/ You Have a Cab? #97
Umm, I do enjoy my time outdoors (as explained earlier in this thread), but there are times when having the cab is about the only way to truly enjoy it.
Besides, I'm not interested in getting an office or factory job. Can barely keep up with everything that should/needs be done around here, so not even a part time job would be feasible.
/ You Have a Cab? #98
I love all the folks denying the idea of a cab. I can remember back in the 60's agreeing with my father that a factory cab was a waste of money, we could just throw the heat houser on for the winter and use an umbrella in the hottest summer days.
Then about 6 years later I drove my first cab with AC tractor cultivating corn, I haven't looked back since. I have bought open station tractors since then because of the $$$$$$, but now I sit here with 3 cabbed tractors and one open station. The main use for the open station is the pto generator and backup for the others.
/ You Have a Cab? #99
There are MANY of us who have used a cab tractor quite a bit and STILL prefer an open station. I am one...
/ You Have a Cab? #100
They do make sense for full time farmers or maybe for folks stuck living down south below the Mason Dixon line. Whenever I see one on a CUT up in the northern US, all I can think of is “a fool and his money are soon parted”.
Single Cedar Glider (A65583)
Single Cedar...
1985 GREAT DANE 45' SLIDE AXLE FLATBED TRAILER (A59911)
1985 GREAT DANE...
2026 DEVELON DX27Z-7-US30 EXCAVATOR (A65053)
2026 DEVELON...
2025 Pabreak 6-Way 84in. Serrated Hydraulic Dozer Blade Skid Steer Attachment (A61567)
2025 Pabreak 6-Way...
2017 Bobcat T770 Compact Track Loader (A63689)
2017 Bobcat T770...
New/Unused Landhonor 6ft x 8ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
