You Have a Cab?
/ You Have a Cab? #1
rockinbbar
Gold Member
South Texas
New Holland Powerstar 120, Powerstar 75, New Holland c245
Everything I have has a cab.
This is just one of the many reasons.
Are you a cab, or open station type?
/ You Have a Cab? #5
So glad I got a cab. Helps a lot whether it's cold, warm, dusty, or raining.
Yet, I use the little tractor that only has a canopy a lot more often...when the weather permits.
/ You Have a Cab? #6
I upgraded to a cab for snow plowing, but it's definitely a plus in the summer months also!
We had a blizzard come through in 2016 that was miserable on an open station tractor for 24 hours of seat time. I had a cab that following April.
/ You Have a Cab? #9
I only ran this machine about two hours since I cleaned it. Not eating dust in the cab is nice.
/ You Have a Cab? #10
The only reason I have an open station is because a cab wouldn't fit in my garage.
/ You Have a Cab? #15
3 with cabs, little Kioti 2620, Branson 8050, and NH 8160, then the old IH 574 open station that primarily sits on the pto generator.
/ You Have a Cab? #16
Isn't a soft cab as miserable as a Jeep's soft top?
At least with the Jeep there's a glass windshield and wipers.
Granted there is no glass windshield and wipers, never had a need for them. Main use was to keep warm in the winter when moving snow. Snow just blew off but cab kept me out of the wind and snow and I was perfectly warm even on 0 deg days.
This the cab I have for my tractor:
/ You Have a Cab? #17
I've got the optional glass windshield for my Original Tractor Cab. I didn't get the wiper but I've never needed it. After 13 years, there are a few scratches on the side and rear plastic windows but not enough to affect visibility. No heater but it cuts the wind and cold enough that I'm comfortable in Carharts.
/ You Have a Cab? #19
My M6040 is open station with a canopy. I enjoy the fresh air and ability to hear whats going on when using implements.
I seldom use the tractor if the weather is bad. Being retired usually means most anything can wait.
An example - I use to get up very early to plow snow on my mile long driveway. Not any more.
/ You Have a Cab? #20
Also - I don't really mind the heat so much here. When it does get hot - the humidity is always below 15%.
If for some REALLY important reason I might have to go out in the cold and snow. My Eddie Bauer down jacket, pants and gloves are a whole lot less expensive than a cab.
1997 Kubota L35 Loader Backhoe (A64047)
1997 Kubota L35...
2010 Toyota 7FDKU40 7,350lb. Straight Mast Diesel Forklift (A60460)
2010 Toyota...
UNUSED REMOTE CONTROLLED BULLDOZER (A62130)
UNUSED REMOTE...
2011 Ford F-550 Bucket Truck - Power Stroke Diesel, Altec AT40G Boom, 45 ft Working Height (A61306)
2011 Ford F-550...
2019 Kuhn GMD3151TL Disk Mower (A63116)
2019 Kuhn...
2017 Load Trail 22ft. 7 Ton T/A Equipment Tilt Trailer (A61568)
2017 Load Trail...
