Knob that slows 3 pt. arms wont move??
   / Knob that slows 3 pt. arms wont move?? #1
fluffers
nh
none
Guys just got a 2021 Yanmar YT235 and the knob under the seat that slows the drop of the 3 point arms will not budge- Tried turning it both ways and it will not move- Tractor only has 60 hrs on it -What am I doing wrong??- thks so much!!!
   / Knob that slows 3 pt. arms wont move?? #2
Is your implement in the air? Meaning, is there a load on the 3 pt hitch. It's really tough to turn the knob is there is a significant load on the system.
It could be that the knob is seized due to lack of use. Spray some lubricant on it, and let it soak, then try to work it both ways with a pair of channel locks. (but not too much pressure at once, or you could break it)
   / Knob that slows 3 pt. arms wont move?? #3
The knob controls a needle valve in the rockshaft housing and you need to replace it and clean it and lubricate it. Spraying it with penetrating spray does NOTHING. You need to remove it and clean it, physically. Do it with the engine off so there is no hydraulic pressure on anything. I remove mine infrequently and clean and lubricate it when it gets difficult to turn the knob on my Kubota's. Not using it regularly causes it to bind up. I make it a habit to turn it regularly, whether I'm using it as a control or not. Just a little needle valve that controls the flow rate, nothing more and don't force the knob or you'll break it off.
Hi- no load on it- the PTO has never been used on it- the guy just used a box blade- I will try and spray some WDW-40 and see what happens- thks
   / Knob that slows 3 pt. arms wont move?? #5
My older Yanmar has a Set Pin the sets the Knob to the Shaft. Notorious to get Sheared. Be careful turning it being locked down. You have to look hard for it on mine. Then owners not knowing it's there and it breaks thinking it's a big problem!!
so i Sprayed it let it sit and nothing will not move- cannot see where this pin would be - any more ideas??- thks
   / Knob that slows 3 pt. arms wont move?? #7
I told you what to do in my comment a few comments up. You can do what I told you to do or not, your choice but spraying it with anything won't cure the issue as the issue is the needle valve inside the rockshaft assembly. You can spray it until the cows come home and it won't do squat except make a mess on your concrete....lol.. :rolleyes:
I know what you said but I do not know where the needle valve is located - can you take a pic and show me- thks
   / Knob that slows 3 pt. arms wont move?? #9
Hyd. Section tells you do not operate the tractor with the Hydraulic rate control knob in the fully closed position. I have a feeling we now know what will happen. I would Chk. with Yanmar. Not much doubt they know what the problem is.
yanmar yt235 owner manual - Search Videos
UNUSED FUTURE 12" HYD AUGER (A52706)
UNUSED FUTURE 12"...
(4) Ratchet Straps (A57453)
(4) Ratchet Straps...
2016 Ford Transit 250 Cargo Van (A56858)
2016 Ford Transit...
54" Pin-On Bucket (A55272)
54" Pin-On Bucket...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
Yard Max Push Mower (A57453)
Yard Max Push...
