Need Reality Check on Trailer Wiring Issue
   / Need Reality Check on Trailer Wiring Issue #1
nikdfish
Person Co. NC
John Deere 3038E & 1025R FILB
I've run into an oddball issue with the brakes on one of our trailers. Three of our trailers have electric brakes, a landscape trailer, a car hauler and a dump trailer. The same tow vehicle used on all, a 2020 RAM with factory trailer brake controller. Everything is fine with car hauler & dump trailer. Brakes function as expected and use settings in the middle range. The exception is the landscape trailer. In the past, brakes worked but not strongly & required a max setting on the controller.
Currently I have zero brake response with the landscape trailer, but all lights (led) work properly. I jacked up the trailer with all wheels offf the ground for testing. I hooked up the RAM & had the wife depress the brakes. The brake lights came on but I could still spin all wheels with zero resistance. However, when I pull the plug on the brake away box, the brakes are set on all wheels & won't turn. The cable's brake wire & the break away box output wire both terminate on the same post in the junction box. I have checked continuity between the cable plug's brake contact and the trailer junction box brake terminal, and it shows good with zero resistance.
Does anyone have any insights with regard to further testing to find the source issue? I'm just about to the point of doing a plug & cable replacement to see if that cures it.
   / Need Reality Check on Trailer Wiring Issue #2
Does the landscape breakaway control have its own battery?
   / Need Reality Check on Trailer Wiring Issue #3
Have you tested continuity of the wires in the wire run from truck to controls. From pin inside plug to where it terminates. It has to be this wire. The brake lights use a diffrent wire than the brakes themselves. You may have done this, im just confused with the way its described….its probably just me
That was what I expected, but continuity from plug brass contact back to wire end that connects on the junction box was good.
   / Need Reality Check on Trailer Wiring Issue #6
The fact that the battery locks the brakes, it has to be in the wire harness itself. Especially since all the other trailers are braking properly.
Yep, that's why I'm think about replacing plug, cable, or both. It would be simplest to just do the plug first & see if that does the trick.
   / Need Reality Check on Trailer Wiring Issue #8
Would the brakes being out of adjustment not cause the brakes to be less than effective? Thinking that way, the only way there's enough current to pull the brakes hard enough is when it gets a full 12V from the controller or in this case from the breakaway battery?
   / Need Reality Check on Trailer Wiring Issue #9
I wouldnt think so. The brake controller gain controller can place enough charge thru to the brakes if hes turned it up. It runs brakes on other trailers.
Ive had so many issues with the male and female ends on trailer wires ever since our county started using magnesium chloride on the roads for ice control. I swear im replacing them every 4-5 years it seams.
I double checked resistance between the plug contacts for ground & brakes. You would expect to see one ohm or less (1/4 the value for a single magnet). What I found is that I sometimes got OL (no continuity) even with the side of the probe pins making contact with the brass contact. Moving the probe pins around, pressing deeper, would then produce a reasonable value (between 1 & 0.8 ohms) I'm starting to think the plug is faulty & the contacts are not always properly connected to the cable wire. A new plug is starting to look like the way to go.
2014 Ford F-150 4x4 Crew Cab Pickup truck (A55973)
2014 Ford F-150...
DEUTZ MARATHON...
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
2003 Big Tex 10PI...
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
2013 Ford Explorer AWD SUV (A56859)
2013 Ford Explorer...
