Hay Making on a Different Scale
/ Hay Making on a Different Scale #181
I'm heading up to my cousin's next month for a family thing. I'll have to look closer at his hay operation.
His primary product is beef cattle, but he raises a lot of his own hay and does a bit of grain as well. He (60s) and his boys also hire out combining.
They tend to use rounds they feed the beef by un-rolling a couple of bales per pasture. 1000+ head and many acres. I see the positives for large squares, but I think it would mess up how they deal with the cattle. Their bales are wrapped in an edible mesh.
I noticed the hay guys near here have baled their 3rd cutting already. I think they have orchard grass. Back home it was almost pure alfalfa. Always interesting to me to see the regional differences.
Thanks for these threads. Lots of interesting info.
/ Hay Making on a Different Scale #182
I've watched a few YouTube videos that showed round bales rolling down the hill and going pretty far, but I never thought of them hitting a house, or some sort of structure. I guess it happens. I wonder how much damage they do to a house?
/ Hay Making on a Different Scale #183
If they got a fast rolling start like some of mine did, they could easily crack typical 2x4 house wall studs.
I lost one down a steep hill, it went over a hump in the gound, got air and broke off a 6” thick sassafras branch like it was a toothpick.
Those top couple of pictures remind me of my youth. Round bales were not in common use. Don't recall any stackers on Bobcats, either. Small bales directly from baler to wagon. Stacked by hand on the fly. Barn were filled manually, too. Lots of hard work, but rewarding, too. I worked some for my grandpa and, like many where I grew up, for a little spending cash for various farmers.
That’s how all the hay was done when growing up until about ‘98 when dad put a bunk in for silage. 60 head dairy. 120+- overall. All fed small squares. Several thousand bales on baling day when enough help. All hand stacked on wagons 125/load. When uncle available was not unusual to have 8 wagons (1000 bales) lined up from previous day ready to unload after morning chores. Cousin and I would each run a tractor bringing full loads from the field, drop at barn and take empty back to field. Those were the summers. I will admit I do miss loading wagons…………….some.
/ Hay Making on a Different Scale #185
I was doing that until about 2016. We had the EZ-Trail dumping bale bins and would tow them to the barns, then throw the bales up top and dump them for the first floor. Hard work. I was doin 10,000+ with my 15 yr old son.
Bought a round baler and sunset the small squares. Thought I died and went to Heaven.
Then I realized it’s hard to store & stack 2,000+ round bales, too. Ran a RB for 5 years, then bought a large square baler. That was an even greater improvement.
Life is real good, but the large square baler, as fast as it is, is a real money pit sometimes.
60 acres on the ground for this week. Got the 2nd mower going finally. That helped move things along
/ Hay Making on a Different Scale #187
I have about 40 acres down & dryin’.
Tomorrow should be a big hay day….heck, all of September for that matter.
Good luck!
60 acres wasn't enough. Had it done in 2 days. Should have had 90 down. Underestimated badly and had no hay to bale with this nice weather. Oh well I got a break and worked in shop.
And got some spraying done.
/ Hay Making on a Different Scale #190
What are you spraying? Is it to stop weeds from showing up?
/ Hay Making on a Different Scale #192
Never heard of that. I’ll look it up.
/ Hay Making on a Different Scale #193
I just knocked 40 down. Tomorrow I’ll do another 40 if it doesn’t rain too much.
Spread urea on 13 acres for a last late batch of hay. Using up leftover bags. 120 lbs/acre on our best producing field and rained right in. Cooler temps coming up. I'm predicting it could push the 50-70 bales/acre for 3rd cutting.
/ Hay Making on a Different Scale #195
Local farmer hired me to deliver 12 bales to a customer, 3x3x8, alfalfa/grass. She didn't have a way to unload so I used the dump. I stopped at the gravel pit and weighed, 23580 gross, 15260 tare, 8320 net, so 693 per bale. Then I picked up 6 ton of rock for myself.
I kinda messed up the dump, one side was hung up on a D-ring, so I had to lift it pretty high to overcome it. That caused the load to dump too fast and the top bales kinda flew:) I will do better next time.
/ Hay Making on a Different Scale #196
No problem getting hay to dry out your way LOL
/ Hay Making on a Different Scale #197
Is that ten hours of mowing? 4 acres per hour? I've said it before, but I really do find it amazing at how fast you can go in your tractor, and get so much done!!!
Another 35 acres down and I'll be "caught up". That is not something that happens very often with the amount of acreage we cover. Also not common the weather models agreeing on a long stretch of rainfree weather.
/ Hay Making on a Different Scale #200
Its chemically burning a field by spraying it so you can plant new grass, alfalfa, cereal rye, etc.
2004 Rogers Detach Lowboy, 28' Well, Tandem Axel (A62679)
2004 Rogers Detach...
CATERPILLAR DP40 STRAIGHT MAST FORKLIFT (A64279)
CATERPILLAR DP40...
2026 Kearney 7'x16' Trailer (A64119)
2026 Kearney...
Yale 5K Forklift (A63688)
Yale 5K Forklift...
213079 (A64276)
213079 (A64276)
2017 INTERNATIONAL PROSTAR + 122 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2017 INTERNATIONAL...
