ordered Makita 18 volt band saw!
   / ordered Makita 18 volt band saw! #1
ArlyA
Super Star Member
Houghton MI (the Lake Superior snow belt) USA
Outlander max 1000 6x6, Ego lawn mower
Just ordered me a makita 18 volt band saw! It was slightly used and on ebay. I used these for years and loved them. (not mine) Finally got one for myself. Its like my birthday.
   / ordered Makita 18 volt band saw! #2
Deep thoughts with Arly...
   / ordered Makita 18 volt band saw! #4
Fancy!
I am apparently the worlds worst operator of porta bands though. I always end up killing a blade every time I use one at work.
   / ordered Makita 18 volt band saw! #5
What tpi are you guys running? I thought I'd order some 14 and 18's.
Might depend on what you are going to cut, but I use 18 tpi on my HF bandsaw for cutting mild steel. It's pretty aggressive, but I like getting through stuff as fast as possible.
I started using hand held saws like this many years ago, may be 20. Mostly with this model but did have a milwaukee at my last job. Didn't break many blades, one per year at the most.
What thickness materials?? Seems 18 is for thinner.
   / ordered Makita 18 volt band saw! #8
I cut everything with that blade, from 1/16"x2" all the way up to 1/2" x 2", 2x2 3/16" wall tubing, you name it. If it fits in the old 4 x 6 bandsaw, it gets cut.
Not many comments so I ordered 18 and 14 TPI blades. Also some "weld on" tie down loops for this project I'm working which is a implement dolly.
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
2025 Swict 66in Bucket Skid Steer Attachment (A50322)
2025 Swict 66in...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
2014 Freightliner M2 106 Ambulance (A50323)
2014 Freightliner...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A52128)
Neckover GL24-2-7K...
2010 Lincoln MKS Sedan (A50324)
2010 Lincoln MKS...
