ordered Makita 18 volt band saw!
   / ordered Makita 18 volt band saw! #1
ArlyA
Super Star Member
Houghton MI (the Lake Superior snow belt) USA
Outlander max 1000 6x6, Ego lawn mower
Just ordered me a makita 18 volt band saw! It was slightly used and on ebay. I used these for years and loved them. (not mine) Finally got one for myself. Its like my birthday.
   / ordered Makita 18 volt band saw! #2
Deep thoughts with Arly...
   / ordered Makita 18 volt band saw! #4
Fancy!
I am apparently the worlds worst operator of porta bands though. I always end up killing a blade every time I use one at work.
   / ordered Makita 18 volt band saw! #5
What tpi are you guys running? I thought I'd order some 14 and 18's.
Might depend on what you are going to cut, but I use 18 tpi on my HF bandsaw for cutting mild steel. It's pretty aggressive, but I like getting through stuff as fast as possible.
I started using hand held saws like this many years ago, may be 20. Mostly with this model but did have a milwaukee at my last job. Didn't break many blades, one per year at the most.
What thickness materials?? Seems 18 is for thinner.
   / ordered Makita 18 volt band saw! #8
I cut everything with that blade, from 1/16"x2" all the way up to 1/2" x 2", 2x2 3/16" wall tubing, you name it. If it fits in the old 4 x 6 bandsaw, it gets cut.
Not many comments so I ordered 18 and 14 TPI blades. Also some "weld on" tie down loops for this project I'm working which is a implement dolly.
2018 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A50323)
2018 GMC Sierra...
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A51039)
Adams Load Out...
2013 Ford F-150 (A50397)
2013 Ford F-150...
2013 FORD F750 26FT BOX TRUCK (A51219)
2013 FORD F750...
2018 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2018 PETERBILT 579...
Unused 2025 CFG MX50R Mini Excavator (A49461)
Unused 2025 CFG...
