Rehab Softball Diamond
/ Rehab Softball Diamond #1
3rd Coast
MI
Power Trac PT422
Greetings folks,
I have a PT422 and have been voluntold I'm going to repair a softball diamond for my daughter's travel team practice field. There is zero budget, and anything I buy is coming out of pocket. I'm not sure I have the tools to do this but a quick review of attachments I do have that may be of use:
  1. Rototiller
  2. Various buckets, some with teeth
  3. plow blade
I have not personally seen the field yet, I'm told it is overgrown with lots of weeds. I plan to get down there this week to view the project area. Really, with the tools I have, I'm not sure what I could do except rototill the top few inches and back drag with a plow or bucket to smooth the surface. Seems like a drag would be a good tool to have. There are a few spring drags for sale locally under $100 I could probably rig up to work, not sure if that's the right kind of drag for a softball diamond. I have read some other accounts of doing this here on TBN, pretty old threads. Wondering if anyone had any ideas on drags or if I can build one that'll get the job done. This is also just a practice field so I'm not really looking for a game day finish and play surface, just want to remove tripping hazards and bad ball hops. Any tips?
/ Rehab Softball Diamond #3
Pics would help.
  • Are you just making baselines, or an entire dirt infield?
  • Do you have to rehab any of the grass?
Any project worth doing is worth buying a tool for ;)
Your tiller should do the lions share of your work.
A chain drag or a pine straw rake would be handy tools.
When I coached my daughter's softball team, I bought some old catwalk to drag over the field and made a shorter one connected to a lawnmower handlebar that the girls could drag after each practice.
You can make a tire drag by bolting some old tires together.
/ Rehab Softball Diamond #5
A washer should do. I suppose you could use a hunk of 2x4. Some people have just wired them together.
/ Rehab Softball Diamond #6
My business is building and maintaining baseball fields.
Are you reworking the 'skinned' area? Or the entire field?
Does your field even have a skinned area?
Your tiller will be a good tool either way.
If you are reworking the skinned area, you will need to remove the grass somehow. If it has lots of grass on it, I would suggest you spray it with Roundup to kill it asap. After it begins to die, take your mower and mow it at it's lowest setting. Cut it down to the dirt if possible. Then you can lightly till it, and then drag it with something to separate the remaining roots from the grass. First, get a tape measure and a can of spray paint and paint the boundaries of the skinned area. You can do a search of softball dimensions to find what measurements you need.
If you are reworking the entire field, keep in mind you will need some time for the grass to grow back after you till it. Down here along the Gulf Coast, that takes at least 90 days.
I can go on and on, but it may be easier for you to ask specific questions that you need answered. I'd be happy to share my experience with you.
/ Rehab Softball Diamond #8
Here's a link to a thread I did many years ago about renovating/building a T-ball diamond. I also bumped it up in the projects forum for reference.
Go take a look at the diamond and see what the infield is made of. Ours was moon dust (granulated limestone). It was hard as a rock! Had to pry a few damaged areas around 1st and 3rd base up like broken concrete. Used my forks to do that.
Anyhow, hope some of these pictures gives you some reference.
And it's a very satisfying feeling to watch the kids out there on opening day! (y)
Thanks for the replies. There was no infield left, it's a city park that had gone unused for many years. Clover took the place of any old moon dust that was left. Put in about 6 hours yesterday tilling the infield up. I guess another parent has a power rake he offered to bring in so I'll let him hit that next to get the grass/clover clumps out. The team has a mat drag that works pretty well after I set a couple PT buckets on it.
My biggest annoyance is I can't seem to drive the PT in a perfectly straight line😅. After painting up the arc I took my time to carefully cut it with the tiller. Once that was done I just set 'er down and let 'er eat. PT took it in stride, I'm sure this machine wasn't built for continuous all day use. I've got some new creaks and groans in the hydraulics that i'll see if a full service will address. I did grease prior to starting, and shot a little extra into the tiller about half way through.
Anyone have comments on the hydraulic duty cycle? Should we be letting these machines cool every hour or two?
/ Rehab Softball Diamond #10
I use the well researched scientific method of temperature monitoring the hydraulic tank- with my hand. I have put an IR thermometer on it, but the hand is quick. If it gets too hot, I stop for a bit and let the fans cool things down. For me, it has to be something like tilling, or mowing, or chipping with WOT on a day when the temperatures go over 90F.
All the best,
Peter
/ Rehab Softball Diamond #11
I've found 99% of my squeaks and groans are the steering rams not being lubed enough. Lube the heck out of them every 8 hours or sooner if dusty. Resolved it for me several times.
Mowing thick grass with the brush cutter is my most heat intensive task.
/ Rehab Softball Diamond #12
More dust, more grease and lube.
Are you supposed to lubricate the actual piston rod? Super Lube? Dry lube? Spray, grease?
/ Rehab Softball Diamond #14
No. I lube both sides of the balls on both ends and wiggle/twist them around a few times to get a thorough coating. Super Lube or white lithium grease if I'm out of that. Every 8 hrs minimum. But usually more often.
Oh ok, i'll step up the frequency on that.
/ Rehab Softball Diamond #16
To be clear, I do the steering rams, the balls on the FEL arms, the QA cylinder, the lift cylinders, the curl/dump cylinder, and I try to grease the center pivot joints top and bottom fairly often. There's also a joint on each end of the rod that's under the tunnel cover.
Mine is a 2001 model with a treadle cable, so there are three zerks on the pedal assembly as well. I don't know how the hydraulic treadle is set up on the newer models.
Anyhow, grease is the word!
/ Rehab Softball Diamond #17
94606a41-94cf-402e-b856-dc94d1875251-jpeg.757184
I would suggest that you try to spray the lube at the top of the gap on top of the pin inside the bushing. (End of the green arrow above) The mount is a bolt in a bushing in an eye. The inner bolt/bushing bearing area is often missed. I didn't realize that it was there for many years until I had a persistent squeak.
I use Super-lube synthetic for these joints, sometimes with PTFE, sometimes, not.
All the best,
Peter
I think mines an '01 as well. #16312. Purchased January '03. Anywho, I've got the 3 zerk treadle.
My top center pin seems to be shooting grease out of a weep hole instead of greasing. Is there a procedure for pulling this pin out? Like shore up both halves first? I've got a part# in the manual here of HB075X318 - 3/4" -16 x 3 1/8" Hex Bolt(Special). Is this a PT part#?
Also my manual shows a lube point location B, each side of the lift arm hinge-at frame. There's no zerks there, is that correct?
/ Rehab Softball Diamond #19
Could you please post a few photos, as they would help a lot to make sure that we are all on the same page.
If your top center pin is your rollover, I think it should have two zerks, or at least my 1445 does.
All the best,
Peter
All the best,
Peter
(4) Texas Built 25' Stand Alone Livestock Panels (A66408)
(4) Texas Built...
2008 Ford E-450 Super Duty Ambulance (A64556)
2008 Ford E-450...
YANMAR VIO35-6A EXCAVATOR (A64279)
YANMAR VIO35-6A...
JOHN DEERE 8360R TRACTOR (A64278)
JOHN DEERE 8360R...
2012 Caterpillar Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
2012 Caterpillar...
ATS Power ATS-D12D Mini Excavator (A66408)
ATS Power ATS-D12D...
