Non Standard 3 Point Backhoe Pin?
/ Non Standard 3 Point Backhoe Pin? #1
quadridermx
Member
Lambertville, MI
Kubota L2500
Hi Everyone, quick question.
I bought this bh760 3-point backhoe used: https://www.northerntool.com/produc...yk14yNFAbpEHAsYwxD655r8nJVfyUT-EB1qCVpX45UKTS
It didn't come with the 3 point pins. I've tried 3/4 and 7/8 pins to mount it, but the 3/4 is too sloppy and the 7/8 is a little too big for the hole on the backhoe side.
Has anyone else run across this problem? Is there a common pin size in between 3/4 and 7/8? I looked at tractor supply and they didn't have one.
Not sure but I'd be very careful using a 3 point backhoe with no subframe. Really good way to break your transmission casting if you get it in a bind.
Its for this reason i went way undersized with the backhoe. It is rated for down to a 25hp tractor, and I have it on my 50hp. My tractor also has a steel housing vs the newer aluminum ones. Backhoe hardly even moves the tractor while I'm using it.
/ Non Standard 3 Point Backhoe Pin? #5
I had a Woods 3 point backhoe 30 years ago before I realized the damage I could do to my tractor. more than that, a broken part could kill you.
To lessen that, my Woods backhoe came with specially hardened bolts for specific points. You had to use their pins. And I did. Maybe that's what you have?
/ Non Standard 3 Point Backhoe Pin? #6
Do you have a set of calipers around? So you can measure the holes. If not, you could get a set of cheap ones to have around. It's a nice tool to have.
Wondering if it is 22 mm, would be close to 7/8" but if the hole is machined close enough to 22 mm, the 7/8" wouldn't work.
That makes a lot of sense. I believe the manufacturer is ansung. I'll check with one of their dealers to see if that is the case.
The annoying thing is that because their pin size is slightly smaller than the 3 point arm hole, it makes everything feel really sloppy.
Is 22mm a common link pin size somewhere?
/ Non Standard 3 Point Backhoe Pin? #9
Get the fit correct and verify by finding an owner's manual on-line. Woods was good about that. I wouldn't take a verbal answer from a parts guy unless Ii verified myself.
For Woods, the pins that went into the parts that held the 3pt to the backhoe were critical for safety. If the pin broke the unit could snap back and crush your head against the ROPS. Not cool.
/ Non Standard 3 Point Backhoe Pin? #10
It's not the movement of the tractor when using a 3 point backhoe, it's the side forces applied by the unit that breaks the transmission casting and I've never had an aluminum transmission casting on any tractors I own, all cast steel.
That force is applied to the top link mount more than anywhere else and that is what fails and usually takes the transmission case with it.
I know a person who did just that with a 50 horse Kubota and when he got done, the repair bill exceeded 10 grand. needless to say he sold the 3 point hoe and bought one that had a subframe mount.
3 point hitches are designed for straight line pulling, not side forces.
Good luck with it. Not in my wheelhouse anyway. If I need a trench dug, I call Black Swamp and have them deliver an excavator or call the guy down the road, He has a big Kobleco and charges little to dig.
/ Non Standard 3 Point Backhoe Pin? #11
It isn't just when working the hoe, either. That's a lot of weight sticking out the back and there is a lot of sideward movement when traversing. I have a 750 Woods which I use sparingly. I plan to get a subframe but it will have to be modified as they don't make one for such an old attachment.
/ Non Standard 3 Point Backhoe Pin? #12
Agreed. Guys today overuse the intent of a small and simple farm backhoe and try to make it a mini-excavator used beyond capacity. I formerly had a 3pt Woods 700 BH on a 2wd Ford 1900 and used it for years with no issues because I know the ropes.
Today, my little JD 790 TLB w/subframe digs stuff around a farm, scrapes out ditches and digs out bushes, smaller stumps, rocks and posts. I work it but know when to say when. Bigger things and you're right, commercial excavator guys are not expensive and do a way better job than I can.
/ Non Standard 3 Point Backhoe Pin? #13
Owners that 'horse' their tractors around using the backhoe to move it are playing with fire if there is no subframe. That horsing them around really imposes severe sideloading on the upper mount that if it fails, usually takes the transmission case out as well. Even with a subframe mount, that activity puts a lot of undue stress on the upper mount especially. Why I don't have one (I did long ago but sold it). Just as easy for me to rent an excavator or have the guy down the road drive his big Kobleco up and dig for me. I'd rather pay him than have one, lots less expensive than replacing failed, stressed components. I don't pull or dig stumps. I have a Landpride stump grinder which is really an Erskine in disguise minus the suitcase weight brackets which I added. I hang a pair of 100 pound Kubota suitcase weights on it to help keep it planted when I'm grinding stumps. It gobbles them up with 90+ pto horses on tap.
/ Non Standard 3 Point Backhoe Pin? #14
In the early 1980's, before I knew better, I had a teeny-tiny Ford 1900 2WD tractor that I put a Woods 700 backhoe on. We lived in Maine then and you would not believe the huge rocks I horsed out of holes with that. I twisted that boom every which way but loose. I dug stumps so big I spend all day digging and then could barely roll it out of the hole.
What I was thinking I don't know but if there is a patron saint of backhoe operators, he was with me. I used that backhoe for five or seven years that way and never any problem. I would never even have a backhoe without a subframe today, let alone use one the way I did with that little Ford 1900.
It wasn't as much stupidity as no money so I had to do what I did and is proof that every now and then a blind dog gets an acorn. As dumb as I was, however, I always left the special Woods backhoe pins in place when using a different one would have been easier.
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2016 Chevrolet...
2016 F-250 4X4 (A56438)
2016 F-250 4X4...
2017 Buick Encore Preferred SUV (A61574)
2017 Buick Encore...
2022 EZ-GO ELITE...
2014 GMC Sierra 1500 Crew Cab Pickup Truck (A61573)
2014 GMC Sierra...
Rake Mini Excavator Attachment (A61572)
Rake Mini...
