   / Your last generator Maintenance Run #6,921
I only use non-ethanol fuel treated with Stabil in anything less than vehicle size. Too many past problems from not doing that.
These conversations are reminding me..... I need to have a chat with an old-timer @ work, before he retires....
He used to fly a lot, light-planes.... I need to find out what the setup is locally (small airports) and if I can fill cans there with LL, before it gets disappeared too. If I can, that should be cheaper than VP Racing....
Unfortunately, everything anywhere near me is now E-tainted @ the normal retail pumps....
Rgds, D.
I've noticed many times those quoting how they use E fuel in this or that old engine and never have problems. I've experienced this with OLD engines too, and I think it's because those old engines aren't jetted so lean, and pass "junk" that would stop up one of the LEAN jetted newer engines. (read Honda)
SR
Another vote here, for the big-bore jets in the olde stuff :cool: If they are sort of gucked up, you could often trickle enough cleaner through while running to side-step a tear-down.
Nice of the local util to help you with you with a MTCE run, but 5 or so hours isn't too bad.
Rgds, D.
You mean Sta-Bil 360 which is the one to use for ethanol containing fuel treatment.
I have used it for several years in small engine fuel and it works as advertised !
360 was originally heavily marketed as protecting the top of the fuel tank from corrosion.
It's what I use in my small engine metal tanks, esp. @ end of season here. That "above the fuel line" claim has been dropped from their ads.
Haven't checked with their tech support - I'm hoping the formulation hasn't changed, and it's maybe just an edict issue by Corp Legal/Accounting to quit marketing it that way.
Could be nothing more than nuisance claims from people with gas tanks that rusted-out years ago.... or possibly some new enviro restriction kicked-in.
Rgds, D.
   / Your last generator Maintenance Run #6,926
Before non ethanol gas was available around here, I used engineered fuel in my small engines:
Due to the cost, it isn't practical for large gas generators though.
   / Your last generator Maintenance Run #6,927
My saw shop had a recommendation I liked, which was to use regular e-gas when running the machine, but then engineered or canned fuel for storage. This was more in reference to OPE that's used seasonally, essentially draining the e-gas and running some canned fuel through it before storage, but there's no reason the same couldn't be done for a generator. Doing this, one of those expensive gallon cans can last a long time, or serve several machines.
   / Your last generator Maintenance Run #6,929
I thin
Over 5000 hours on my Honda and it gets the same gas my truck and side by side and garden tractor get.
Regular use replenishing fuel seems ok... plus keeping in a lower humidity constant temp storage can't hurt.
It's when put up for storage or seasonal the mower shop says I'd problematic for the small carbs... nothing noted with the FI generators.
I use my Honda mowers year round without issue...
Got a free $1000 Honda mower because the owner couldn't get it started after a year away... The carb was crusty and I replaced and now ok.
   / Your last generator Maintenance Run #6,930
Those hours are what most of off grid systems are getting with there honda and yamaha inverter generators. Its good to see it reported by others every now and then! Regular maintenence, oil change intervals and spark plugs.
Most off gridders use thier generators enough in the winter that they use the cheaper e-gas. Its hasn't been a problem with continous use.
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
70pc. 12ft.x 3ft. Black Metal Roof Panels (A55758)
70pc. 12ft.x 3ft...
(NEW) SOUP KETTLE (A58374)
(NEW) SOUP KETTLE...
2016 Ford F-250 Knapheide Service Truck (A56858)
2016 Ford F-250...
2013 CATERPILLAR 259B3 SKID STEER (A52709)
2013 CATERPILLAR...
2020 Ford F250 Pickup Truck (A55973)
2020 Ford F250...
