Forum for air cooled diesel engines and clones
   / Forum for air cooled diesel engines and clones #641
From what I’ve seen it’s the cheap Chinese clone parts that are inferior. The camshaft material is inferior with improper or no heat treatment. An oem Yanmar cam & bearing may be interchangeable which would solve that problem.
The quality of clone parts varies from terrible to good/great.
Are you saying the crankshaft PTO and rod bearings are wearing also?
90cummins
Thanks! That's what I figured when I read through this topic, I just wanted to check if I missed something.
I actually have a running "8.5Kw" Chinese diesel, and an original Winco 5.5Kw with a Yanmar L100 with unknown hours. This unit I just stripped down was one that did not get enough or probably any oil changes. Thus it has PTO end bearing wear and big end crank bearing wear, also cam fallow wear as well! This all probably caused the poor running, hot exhaust and in turn the dropped valve.
I have thought of either:
- Get a needle bearing with inner race and machine down the end shaft to press on the inner race.
- open up the crankcase bore on the bearing end and get a large ball bearing installed with some machining on camshaft.
- I noticed the Yanmar original camshaft at the gear end actually has a bushing bearing and not a ball bearing. The ball bearing could actually be causing the issue at the small end by allowing more movement. If the big end was changed to a double-row ball bearing that might keep it a bit more "straight".
Did you say there is a ball bearing on the small end of camshaft not a needle bearing?
The plain bearing on the cam has not been an issue same with needle bearing in the crankcase. The problem is poor quality parts. Install genuine Yanmar parts & you should be good providing they are interchangeable.
90cummins
Could you take a photo of cam & bearings.
90cummins
   / Forum for air cooled diesel engines and clones #644
It's a needle bearing, the big end is the ball bearing, yet the Yanmar original has a bushing. My thought was to replace the needle bearing with either one with an inner race, or a complete ball bearing. The RPM rating only has to be 1800RPM, thus, its more about the pressure applied to that end.
The movement that I am concerned about caused by the big end bearing is radial, due to it be unbalanced on the small end bearing side. The bushing style on the original Yanmar might mitigate this issue.
I will post photos when back home in a few days.
   / Forum for air cooled diesel engines and clones #645
Here is the damage: 350hrs, dropped valve.
   / Forum for air cooled diesel engines and clones #646
Ouch!
   / Forum for air cooled diesel engines and clones #648
bump
What are your plans?
Scrap or attempt to repair?
   / Forum for air cooled diesel engines and clones #650
YANMAR OWNER MANUAL L70 L100 NDK6000YE.pdf
  • YANMAR OWNER MANUAL L70 L100 NDK6000YE.pdf
1994 Club Car Electric Cart (A56859)
1994 Club Car...
Brock 36'x17' Flat Bottom Grain Storage Tank (A57148)
Brock 36'x17' Flat...
2013 Yamaha YDREX4 Electric Cart (A56859)
2013 Yamaha YDREX4...
2000 GMC Dump Truck (A57148)
2000 GMC Dump...
1998 POLAR TANK (A58214)
1998 POLAR TANK...
Giyi Logging Winch (A57149)
Giyi Logging Winch...
