Forum for air cooled diesel engines and clones
   / Forum for air cooled diesel engines and clones #631
This is one reason why I try not to idle my diesel engine long. Yanmar even states not to idle more than 10mins at a time, and not to idle for 5mins and then turn the engine off.
I run the engine, gracefully lower the rpms, then shut down. Keeps the engine healthy and is a good practice. No glazing on these cylinder donuts with holes. ;)
I built my nephew a generator several + years ago using a Yanmar L70 diesel from eBay which needed rebuilding. New rings, camshaft lifter & rod bearing plus seals & gaskets. A belt drive 5kw generator was purchased also along with taper-loc bushings so I could mount a pulley on the shoulder of the crankshaft which was tapered for a direct drive generator.
Belt drive was chosen because of the ability to use any motor source to run it. It also allowed us to overdrive it with the appropriate pulley to reduce engine rpm.
It was sitting in the corner of my shop since it was first built & tested & I thought it is time to pull it out & check it.
There was fuel in it so I connected the battery & it cranked & cranked🤨
Very unusual to not start within 1 or 2 revolutions.
Found the injector rack was stuck closed, fortunately.
Removed injection pump hit it with some blaster worked it until it was free then reinstalled it. Cranked it & she started up nicely.
I put 2 heaters on it for a load of 2.9kw & ran it for over an hour.
Tested engine rpm unloaded 3720rpm, 1.5kw load 3600 rpm 2.9 kw load 3530rpm. Ran excellent. I put 2oz of marine 2 stroke oil in fuel & ran another 1/2 hr.
Diesels do store well but even they need a little love to stay healthy.
A word of caution here, fortunately the rack was stuck closed (off). If it was stuck open full throttle it could have been exciting. Always need to be ready to shut the air off or fuel supply with a diesel if it hasn’t been run recently to avoid serious damage/injury.
90cummins
   / Forum for air cooled diesel engines and clones #634
Hello my friends and helpers, finally i found time to dissasemble the engine.
Here are the results
   / Forum for air cooled diesel engines and clones #635
Congratulations on finding the cause! I hope that the rebuild goes quickly and smoothly.
All the best,
Peter
I can’t say what caused your piston to break but starting fluid can certainly cause that.
Give it a quick hone & a new piston & rings and you’ll be good.
Is that a Yanmar or clone?
90cummins
   / Forum for air cooled diesel engines and clones #637
Speaking of starter fluid, I had a weird dream last night where someone was trying to get my Massey tractor to start with a fire extinguisher filled with starter fluid. He was hosing down the air intake. Even weirder was that I was the one on the Massey holding the key in start position. :oops: :oops: :oops:
   / Forum for air cooled diesel engines and clones #638
Looking over this topic i could not find i formation about helping camshaft needle bearing wear.
This seems to be a common issue with these engines as pictured by others. What are some doing to mitigate the wear on the camshaft at the needle bearing?
I just stripped down one of these due to a dropped exhaust valve, and found significant wear on almost all bearing surfaces. The generator had only 325hrs.
   / Forum for air cooled diesel engines and clones #639
Welcome!
I'm afraid that as far as I know there isn't.
If you have a Chinese copy of the Yanmar engine, I think that at this point there is very little to be done to prevent wear due to soft bearing surfaces, beyond regular oil changes with good diesel oil. Bearing surface wear comes down to metal hardness, and oil, and I am assuming that you kept the oil level within specification. Technically, I guess you could machine out the old surface and press in harder metal, but I suspect for almost everyone it would be cheaper to go buy a Japanese Yanmar.
Enough people have found sand and metal in their first oil changes that I think the suggestion (@90cummins? up thread?) to fill a new machine with oil run it for a few minutes and drain and clean the filter and oil pan, and then refill is worthwhile. I ran the second oil change for 10 or so hours and drained it out of a concern for more debris, but I did not find anything visible in the second oil change.
All the best,
Peter
From what I’ve seen it’s the cheap Chinese clone parts that are inferior. The camshaft material is inferior with improper or no heat treatment. An oem Yanmar cam & bearing may be interchangeable which would solve that problem.
The quality of clone parts varies from terrible to good/great.
Are you saying the crankshaft PTO and rod bearings are wearing also?
90cummins
2016 KENWORTH T800(INOPERABLE) (A58214)
2016 KENWORTH...
2011 FORD F-550 (INOPERABLE) (A58214)
2011 FORD F-550...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
MERCURY VERADO ENGINES (A55758)
MERCURY VERADO...
1449 (A57192)
1449 (A57192)
2017 Bobcat T595 (A55272)
2017 Bobcat T595...
