   / Your last generator Maintenance Run #6,901
Went to check one of the houses I watch yesterday. First thing I do when I get there is open the cover on the standby generator and check the display for the last run time. Display showed the wrong time and date, and a bunch of red lights were on.
Flipped the manual start switch and nothing but a click. Threw my multi meter on the battery 12.9 v, flipped the switch again, click and voltage drops to less than 5. So I pulled the battery out and threw it in my truck. Got it home and threw my tester on it and instead of 550CCA, it was only 55! Going to head to NAPA today for a replacement.
Since the oil and filters were more than 5 years old, I’ll pick up new filters, oil and spark plugs and change them out too.
Generator is a Cummins/Onan with an air cooled Briggs Intek Twin. Looked up filters on NAPA $41 for the stinking air filter and $23 for the oil filter! Holy crap. Checked elsewhere and nobody is stocking both, including TSC.
ETA: it is a Briggs Vanguard not Intek.
The negative battery clamp split in half today. I did get it tightened up, but I’ll have to get that replaced.
   / Your last generator Maintenance Run #6,902
I've noticed many times those quoting how they use E fuel in this or that old engine and never have problems. I've experienced this with OLD engines too, and I think it's because those old engines aren't jetted so lean, and pass "junk" that would stop up one of the LEAN jetted newer engines. (read Honda)
SR
   / Your last generator Maintenance Run #6,903
Our power was off 5-1/2 hrs. yesterday, I didn't even bother to start a generator for the first three hours, and only then to cool down the fridge.
So, as my Honda 2000 needed exercising, that's the one I started and plugged in the fridge, then sump pump.
I didn't need electricity for anything else, so I didn't plug in anything else.
SR
   / Your last generator Maintenance Run #6,904
I also run regular e-gas out of the pump thru my 2013'ish Honda GX, my 2012 Subaru EX27, and a 2007 Kawasaki V-twin. No problem with any of them.
The Honda GX is the one that gets the bowl drained after each use, as that's on our emergency portable generator, and it's also run on fuel with stabilizer (usually Stabil) mixed before pouring.
The Subaru engine is on a leaf blower and the Kawi V-twin is on a mower, both of which get used daily for half the year, and then parked the other half. Both have a fuel shut off valve that I close to run them dry before their 4-6 months storage, but I don't bother draining the carburetor bowl on either. I also don't bother with fuel stabilizer in either.
   / Your last generator Maintenance Run #6,905
You mean Sta-Bil 360 which is the one to use for ethanol containing fuel treatment.
I have used it for several years in small engine fuel and it works as advertised!
   / Your last generator Maintenance Run #6,906
I make a point to start my 10,000 Watt Champion generator the first of each month and let it run for 10 minutes. I check the oil first before starting.
I only use non-ethanol fuel.
   / Your last generator Maintenance Run #6,907
I wonder what other people do to get the noise level down. My gen is LOUD. Tried adding an automotive muffler, but that didn't really work. And tried running the exhaust under water. That also didn't work. Figured out if I set it up to reflect noise away from the house, it is much better. The noise is in the single piston engine design. Even outside on the ground, we can feel the vibrations inside, panting the windows.
I wouldn’t mind having a loud generator just for Home back up or something but we have a food truck and I can’t believe the amount of food trucks that have a screaming loud generator, why would you spend anywhere from $30-$60,000 to fill a food trailer or a food truck and fill it with nice appliances and then get a screaming loud generator? I don’t understand.
We have a quiet Honda on ours that has over 5000 hours on it and if we are the only food truck at an event, we get guys wondering where we are plugged in because they don’t hear generator
   / Your last generator Maintenance Run #6,908
Well, that's probably what I should be using, but it's not. The bottle I have is red and just reads "Stabil". Since I've honestly never had a problem related to e-gas, I haven't put much time or energy into sourcing and buying the best stabilizer.
   / Your last generator Maintenance Run #6,909
we all think you should stop what you are doing and do this right now!
drain all your old gas out and do it properly. Buy several cases of STabil and get the right one. Take at least several hours in the hot sun to do it.
and no dinner until you do! ;):rolleyes:
just razzing a Philly neighbor...
I only have three motors left to take care of and the gen runs on propane.
The others I do nothing with other than lots of SeaFoam and making sure my gasoline supply is fresh. Kawasaki in JD mower always been a good starter. Snow blower has EFI and that seems to help a little. Otherwise I've gone to Makita cordless.
   / Your last generator Maintenance Run #6,910
Did you do your own propane conversion? My portable genny is the ubiquitous PowerStroke 6800 with Honda GX engine, that I see all over, I guess they're pretty popular. But they're gas only from the factory, and the propane conversion kit I found for them back when I bought new involved cutting the frame. Some folks reported issues with that, as it really weakens the thing, with regard to travel if you load it onto a truck or trailer, or tote it around on the back of a tractor.
If anyone knows of a better propane conversion kit, I'd be interested. We have propane in our garage already, feeding a space heater, so it wouldn't be hard to tee in another line on a quick disconnect fitting for feeding the generator when back-feeding the house.
2009 International 7400 Altec A77-TE93 92ft. Material Handling Bucket Truck (A55973)
2009 International...
2026 Anvil T/A Enclosed Trailer (A56859)
2026 Anvil T/A...
60'' SKID STEER BUCKET (A56857)
60'' SKID STEER...
24" X 32" X 60" METAL ROD CABINET (A58374)
24" X 32" X 60"...
2019 Freightliner M2 106 Johnston VT651 8.5 Yard Street Sweeper Truck (A56858)
2019 Freightliner...
2013 HYUNDAI Veloster Hatchback (A56859)
2013 HYUNDAI...
