Your last generator Maintenance Run
   / Your last generator Maintenance Run #6,891
Ever since I started turning off the fuel tank valve and running the engine till it stops from lack of fuel, it has always started right up, first or second pull. I even partially engage the choke as it starts surging from being lean, to help draw out as much as possible from the carb.
I never use the ignition switch.
   / Your last generator Maintenance Run #6,892
I know it sounds obvious, but we always keep 3 cans of starter fluid around, two in the barn and one in the garage. Cheap insurance!
   / Your last generator Maintenance Run #6,893
I wonder what other people do to get the noise level down. My gen is LOUD. Tried adding an automotive muffler, but that didn't really work. And tried running the exhaust under water. That also didn't work. Figured out if I set it up to reflect noise away from the house, it is much better. The noise is in the single piston engine design. Even outside on the ground, we can feel the vibrations inside, panting the windows.
Others have placed plywood around the generator to deflect the noise up & away from the house.
I set my generators on an old tire which eliminated vibrations transmitted to the power house.
90cummins
   / Your last generator Maintenance Run #6,894
Yes lucky is right. Dare you to pull a carburetor bowl and show us the gunk!….😉
I don't think he's lucky, as I have the same experience. Heck, I could go out to my shed right now, put a little fresh fuel in my Briggs-powered 1973 Toro mower, and I'll be it starts within 3-4 pulls. My generator always starts, never trouble, and I run all of my equipment on regular pump e-gas.
That said, I never leave fuel in the bowl of any machine in storage. The generator has a bleed screw right on the bottom of the carburetor fuel bowl, that lets me drain the bowl dry after use. I use the generator for probably 1 extended outage per year, after which I always kill it by closing the fuel valve between tank and carb, and then I drain the bowl from bleeder screw into a jar, which I pour back into the tank. The fuel is always treated with stabilizer before going into the tank, nothing special, just whatever is on the shelf at WalMart (usually Stabil regular flavor), and the oil is changed either immediately after usage or the following January when I do my other equipment.
The ancient Toro mower mentioned above has no bleed screw in the fuel bowl, so that is left with fuel in the bowl, at least until the January maintenance cycle. Also, never an issue, I guess the small fraction of an ounce of fuel held in the bowl isn't really enough to cause enormous trouble.
I see the complaints about e-gas on this site and elsewhere, and suspect 95% of them are probably from people who would have the same trouble without ethanol in their gas. "Take care of your equipment and it'll take care of you," is a phrase I was hearing 30 years before anyone was pumping e-gas around here.
Not sure how to feel about this. Last January we had our big ice storm. Checked the 27 year old Homelite 4400 Watt generator in December with new gas and oil and checked oil and stuff and cleaned the air filter, replaced the gas filter. It always started on second or third pull. Okay..... check that off and add some stabilizer to the gas. So we get this ice storm. Utilities said it will be a week or more to restore. No utility power for 8 days. Wife was really mad about the situation. Damn generator would not start, ..... pulled and pulled, had spark, and cleaned the carb in the cold. And made sure it had oil and was level. Made an attempt to start and work on it everyday to no avail. But I didn't have any Starter Fluid. We stayed out of power for eight days till utility came back on. We figured its time to get a new one, so we are looking these up online.
Just for laughs, I pull the gen out, this week, late August, for one last try before replacing it. Maybe I can get $50 for it as non-running. Starts on second pull and purrs like a cat. WTF....
Good points, in folk's responses to this Murphy 201 example ^
90's point on a damper (vibe) I like.... big stuff is sometimes isolated for that reason, and worn tires are everywhere. A few examples should be found on Ytube, of acoustic panels people have used to direct sound Up...... IIRC one, just the junk panels a guy had lying around showed showed some effect on his db meter.
Fuel.... I'll use my Mom's expression about me planning to spend beer-money (that I don't use) on VP Racing fuel for my small stuff..... me, and my Scottish ancestors both, would never expect me to type that.
Stock up on the Quik Start - I don't like to use it, and don't like seeing it over-used, but it has it's place. Backup, depending on ambient - just a propane torch (unlit); I bought one of those foldable silicone funnels @ the dollar store just for this purpose - sits in the garage beside the torch - emergency manifold, to get propane up to a carb.
Two is One, One is None..... I like to keep old equipment running (it's great to see what has been fixed in this thread), but esp. with a Generator, a backup is prudent.
I do like Honda, but these days I'd vote for propane - I suspect that "they" still aren't finished de-functioning gasoline. In smaller stuff, I'm attracted to what many people tag-team for RV's - small, light inverter generators, that are designed to be paralleled to double power capacity. Even if you don't buy two off the hop, you may want to buy the second later. Multiple sources for these ^, I don't own one, but from the feedback on here and elsewhere, I'd spend time reviewing Champion options - not hating on anything else, just a comment on perceived price/performance/reliability of Champion. Don't own this one either, but the reviews I've read on Harbor Freight's line seemed good - I've followed their Predator engines, so that ties together well, at least as a story !
Rgds, D.
   / Your last generator Maintenance Run #6,896
For those who try and avoid using e-gas in their small engines, here's a tip. If you use a pump that dispenses both non ethanol gas, and e-gas, make sure you clear the e-gas from the pump & hose first by selecting non ethanol and pumping the first couple of gallons into your vehicle tank before filling your gas cans.
   / Your last generator Maintenance Run #6,897
I like that idea! I’ll have to try that instead of Quik Start!👍🏻
   / Your last generator Maintenance Run #6,898
Well, i e had nothing but trouble with ethanol in fuel. I run only non ethanol in all small engines. Our station pump has separate nozzle for it.
I dont bother draining any carb anymore now with non ethanol. As a matter of fact, i needed my 6500 watt Briggs generator today to work on some fence posts out in the pasture today. Had same fuel since last years work, only added stable last winter. Darn if that thing didnt start on first pull…..surprised the heck out of me. Ran about an hour, shut it back down. Topped off tank, and put away.
Ive also read so many negative articles on leaving carbs empty. Drying out gaskets, etc. i really dont know which is the best way to store them.
   / Your last generator Maintenance Run #6,899
On the last bit of fuel running thru the engine run a bit of two stroke oil in it.
Another thing I used to do (when I could get real gas) was to shut off the fuel but not run the bowl out of fuel so there'd be a bit left in it to keep things moist. That way the needle wouldn't leave an impression in the seat because of fuel keeping it closed. Maybe a bit overkill but mehhh, I never had a problem LOL
   / Your last generator Maintenance Run #6,900
Unless you’re talking about a 50 year old carburetor with cork and paper gaskets, I say baloney.
Modern carburetor gaskets are fully compatible with gasoline and water, meaning no reaction. They don’t hydrate.
You’ll notice new carburetors and replacement gaskets are shipped and stored dry up to years. It’s the mechanical fastener clamping of their natural dry dimensions that provides and maintains the seal.
2019 Kohler 50REOZK 50 kW Diesel Generator (A56857)
2019 Kohler...
Grecer Food Trailer (A55973)
Grecer Food...
New/Unused CFG Industrial MX12RX Mini Excavator (A57453)
New/Unused CFG...
2012 International Derrick Digger (A55973)
2012 International...
Skid Steer Concrete Mixing Bucket (New/Unused) (A59225)
Skid Steer...
1852 (A58374)
1852 (A58374)
