John deere 301 pto lever stuck engaged
/ John deere 301 pto lever stuck engaged #1
jcharley
Member
Missouri
71 John Deere 301 (gasser)
Good afternoon,
I was using my 1970s john deere 301 with a post hole digger and after a few holes, when I went to disengage the PTO, the lever is stuck engaged and won't budge.
Pressing in the clutch disengaged the pto, but I can not get the lever to disengage.
I have tried to disengage the pto lever with the engine running and engine off. I've tried using it and then retrying to disengage the lever, no matter what, I can't disengage the lever.
Looking for any advice.
Thank you in advance,
Jeff
/ John deere 301 pto lever stuck engaged #2
If you open this link:https://partscatalog.deere.com/jdrc/sidebyside/equipment/16923/referrer/navigation/pgId/115741 It will take you to the John Deere online parts book for the 301, and one of several PTO set ups. Don't know if your 301 is set up with a mid-mount PTO, if not there are several more to look over.
But if similar to this one I'd have to guess part #9 in the exploded view may be part of the problem, with the dowel pins (parts 8) be the rest of it. Could be broken not allowing the yoke to pivot and disengage the shift collar #17. Could also be parts 10 & 11, the spring and ball that is a detent to hold in place once shifted in or out of gear.
The tractor will need to be split to repair. Probably not what you wanted to hear, just the cold hard truth.
We had 2, 301's back in the mid 70's with side mount sickle bar mowers to mow roadsides. The PTO engagement lever was on the left side on the torque tube case. I loved those tractors, but some of the guys didn't like mowing. Some found out that if you weren't pretty gentle engaging the PTO there was a roll pin in the shaft that would shear, and you couldn't engage the PTO. A very poor design in my mind for a tractor that you used the PTO quite a bit. Doubt that is your problem though, because that lever would flop back and forth pretty easy, and the PTO was not engaged.
Don't know if this will help but should give you an idea what is on the inside and what to look for.
/ John deere 301 pto lever stuck engaged #3
/ John deere 301 pto lever stuck engaged #4
Thanks for the correction. The engagement lever looks just like the one the 301's we had. #2 is the pin that would shear. But like you, seeing that collar and possible galling on the shaft could very well be the problem.
Thank you both for the reply. I never got an email notification showing that I had a response.
I do not have a mid pto, it is rear only and I am away from home for a few weeks.
Is cap 5 in the picture on the side of the tractor or inside
Thank you so much!
/ John deere 301 pto lever stuck engaged #6
Item 5 is item 14 in photo below on trans case exterior.
Unfortunately, that did not help. The lever is still stuck engaged
/ John deere 301 pto lever stuck engaged #8
Does the tractor have to be split? Can it be accessed with the rockarm cover off?
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
2005 EZ-GO Utility Cart (A55851)
2005 EZ-GO Utility...
BOBCAT T190 (A60736)
Volvo L306 (A57148)
Volvo L306 (A57148)
Truck Storage Boxes (A59317)
Truck Storage...
154 (A52708)
154 (A52708)
