CalG
Super Member
- Joined
- Sep 29, 2011
- Messages
- 9,173
- Location
- vermont
- Tractor
- Hurlimann 435, Fordson E27n, Bolens HT-23, Kubota B7200, Kubota B2601
I'm doing some work on the underside of my bank barn style shop and needed to get the Fordson out of the way (so she wouldn't get hurt)
I don't think she has been lit up and running for more than a year.
Opened the fuel tap and observed fuel fill the sight bowl.
Climbed up to the seat to press the clutch and give the starter switch a twist/
There was some sign of life...then nothing but the tick of the magneto impulse couple as the starter motor spun the crank.
I pulled the cap off the magneto and cleaned the points, with the battery charger hooked up while I did so. Pulled one spark plug to have a look, Sooty black...but dry. Wire brushed it and put it back in.
With it back together, tried the self starter again. Nothing, and then a puff, then a couple more puffs, the a ROAR! Set the throttle back a couple of notches. An unsteady beat as a cylinder or two caught and then faded out.
Drove it up into the yard , a bumpy ride with the snow chains still on the tires.
Took a look into the cast iron radiator tank. Might be down a gallon (it holds five gal easy, I keep it in anti-freeze, though I used to just drain it after every use. I'm getting too old to lift a five gallon pail up to the fill hole!)
Ran the rear lift up and down a time or two The pump drive engagement lever needs grease!
Put in the gear drive for the side pulley. Whee, that thing spins! I need some flat belt equipment!
Exercised the Western snow plow . I can tell the pump unit is low on fluid ...Hmm ATF or hydraulic? IIRC it's got ATF in it now.
Walked around with the grease gun, and gave all the greasers a squirt. Steering has been tight on the old gal since I replaced the spindle bushings 30 years ago.
Got out a squirt bottle with Dawn dish soap cut 50/50 with water and soaked all the grunge spots. Then took the garden hose to her . She looks good from 50 feet ;-) Showing her age up close
She is two years older than I am. I always did go for the older gals....
Gonna change oil tomorrow, three gallons IIRC. Drop the chains, air up the tires and take her on a road trip!
