Bentonite Grease
/ Bentonite Grease #1
mgsolakis
Member
Ontario, Canada
Case 446
My Homelite (Jacobsen) riding tractor seems to call for Bentonite grease in the transmission, but here in Ontario, Canada I cannot find it anywhere. I've read that it does not combine well with other greases but I've called Napa, and all the lawn and garden places around here and nobody sells it or has even heard of it. I was wondering if anyone knows what modern grease I can mix with it or if it is called something else here? It's for a Tecumseh Peerless 5 speed transmission. Thanks
/ Bentonite Grease #2
Bentonite is clay based ish. I assume that you have this apart and have issues? If not, leave it. If you do, then clean clean clean ever thing up and use a better lube. It is time consuming.
/ Bentonite Grease
Yeah I had to take it apart, I honestly don’t want to clean it out, it’s a huge job and I’d have to take the whole thing apart. I do appreciate that as a viable option though.
/ Bentonite Grease #6
I'd have no idea really. Somewhere I probably have a dried up jug of the Tecumseh stuff. It is thicker than a 00 grease if I recall. When it gets pushed around and water infiltration, it doesn't look very good does it? I've found with pricing old Peerless in Deere's this summer that the people that have them are really proud of them. And yet people initially are a bit shocked when I tell them to figure 5 hours labor possible + to RnR and clean one of these up to fix / change the lube.
/ Bentonite Grease #7
I have seen Bentonite used to fill in the out side of a basement, dig a hole
by the crack in the basement wall then fill the hole with Bentonite as when the Bentonite gets wet it swells up and seals the crack so no water can get in the basement
Knowling the above I would never use anything with Bentonite in an engine of any kind
willy
/ Bentonite Grease #8
It may have been part of the idiotic enviro-commie ban that took affect Jan 1,2024.
Things were banned that should not of been.
How close are you to the US border?
Or clean it out and use a good Poly urea grease.
2015 PETERBILT 579 TRI/A DUMP TRUCK (A59914)
2015 PETERBILT 579...
New/Unused Wolverine 44in Mini Grapple Bucket (A65583)
New/Unused...
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
2023 Bobcat T595 Compact Track Loader Skid Steer (A64553)
2023 Bobcat T595...
40ft High Cube Shipping Container (A65583)
40ft High Cube...
2017 Ford Fusion Sedan (A64557)
2017 Ford Fusion...
