Has anyone used AI to help select a tractor?
   / Has anyone used AI to help select a tractor? #11
I wouldn't trust any AI conclusion on tractor selection since it would almost certainly tell you to buy an EV tractor for the climate benefits or wait until they are more readily available. Given who winds up programming the AI algorithms, there will (almost certainly) be a bias against anything that uses fossil fuels. IMO
Better to contact TBN and told to buy a bigger tractor with a cab, Top n Tilt,a grapple, backhoe and 3 rear remotes.
   / Has anyone used AI to help select a tractor? #14
@MtnViewRanch needs to get referrals somehow! Same with @kennyd! Let alone all the non-member businesses' we shill for recommend.
It's part of TBN's charm. 🤣
   / Has anyone used AI to help select a tractor? #15
   / Has anyone used AI to help select a tractor? #16
AI would probably pick my perfect tractor and the dealer would be 200 miles away.
AI needs to mature more before I would have any confidence in it.
I would rather shop around and get a feel for what is best for me.
   / Has anyone used AI to help select a tractor? #17
I never have but it would work, I have play around with AI, and you have to be careful with it because it will spit out everything on the net so it's not all true, you have to interrogate it and make sure it spit out true fact or try to trick it to see if it will contradict itself ... I have used it get list of tires that would suit my needs as a examples, you tell it your criteria and it will give you a list of choice and explain why these choice is good for you... its a tool but not absolute, you have to double check it. Or simply used it to find where you can find certain information... but I like it because its quick and can help narrow down your search.
   / Has anyone used AI to help select a tractor? #18
Will it give the same recommendations as these forums?
AI, what tractor do you recommend for mowing my one acre suburban yard?
AI: You need a 600 h.p. John Deere 8R fully ballasted with a 40 foot batwing mower.
LOL
   / Has anyone used AI to help select a tractor? #19
ps this AI response brought to you for free courtesy of John Deere. o_O
   / Has anyone used AI to help select a tractor? #20
LOL
This just demonstrates that you need a bigger lawn!
Kubota BH92 Backhoe Mounting Brackets (A50775)
Kubota BH92...
2007 FORD F-150XL TRITON TRUCK (A51406)
2007 FORD F-150XL...
Kubota BX2370 Compact Tractor (RIDE AND DRIVE) (A50775)
Kubota BX2370...
2018 Ford Explorer SUV (A55758)
2018 Ford Explorer...
TAKEUCHI TL150 SKID STEER (A51242)
TAKEUCHI TL150...
2006 Ford Ranger Ext. Cab Pickup Truck (A55788)
2006 Ford Ranger...
