HST stop working
/ HST stop working #1
RgP454
New Holland TC45D
Hydrostatic transmission stopped Add new hydraulic oil gave to me by new holland dealer drove it about 100 yards and just stopped moving loader still working HST forward peddle wants to stay down to the floor it will return if I push reverse peddle but reverse doesn’t work either
/ HST stop working #2
I have a Kubota HST with a three speed transmission. If one of the gears is not engaged it will not move. There is a dead or neutral area between each gear, very easy to think you're in gear when you're not. You may wish to investigate that possibility on your tractor.
/ HST stop working #3
@RgP454 - I wondering if this is just a coincidence as far as adding Hydraulic fluid...
The first thing I would check is the Trans Pivot Assembly under the right side of the tractor it attaches the pedals to the trans... (it is in the picture below)... They sometimes break at the welds & will cause the condition you are describing...
/ HST stop working
Thank you I will check that out tomorrow
/ HST stop working
/ HST stop working
I zoomed in on the picture I see where it has been welded I will check that out tomorrow thanks again
/ HST stop working
That was the problem I got I weld back up all good creeping forward just a little but that job for another day Thank you so much for your help I really do appreciate your help thanks again
/ HST stop working
2018 GENERAC MOBILE PRODUCTS MLT6S (A67714)
2018 GENERAC...
2007 WESTERN STAR 4900 SB CRANE TRUCK (A67714)
2007 WESTERN STAR...
2007 Western Star 4900 SA Tri-Axle Wet Kit Day Cab Truck Tractor (A61573)
2007 Western Star...
220 VOLT 6IN SUBMERSIBLE PUMP (A67714)
220 VOLT 6IN...
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A67714)
2013 ORTEQ ENERGY...
2011 FORD F-150 (INOPERABLE) (A67714)
2011 FORD F-150...
