Grill Insert - YM347A
/ Grill Insert - YM347A #1
Rvrrat14
Texas
Yanmar YM347A Bush Whacker HD72 shredder, Armstrong BGR64-5 grapple, E.L. Caldwell 66” box blade, Advanced Earth 48” pallet forks, 43x45 Safety Basket
This is from Broken Anvil Metalworks. Allows you to open grill to first hole passed stop. Fit like a glove.
/ Grill Insert - YM347A #2
Keep in mind that the more restrictive a grill guard is, the less air the fan can pull to cool the motor. That and now your headlights will be compromised as well. They will reflect off the inside of the grill guard and not work very well.
Checked lights before dark yesterday, all seems fine. I don’t believe this will affect air flow at all. I’m more concerned about the pre-filter at the radiator than this. I always keep an eye on gauges. Appreciate the heads up.
/ Grill Insert - YM347A #4
This would be the case if the grill guard is sealed around the grill. However since there is often a significant space between the guard and the grill that exceeds the amount of surface area of the grill by quite some margin air flow should not be a problem. Your assessment of the lights is spot on.
2023 Kubota L6060HST Compact Utility Tractor (A63688)
2023 Kubota...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
2017 Freightliner M2 106 Auto Crane HC10 5 Ton Crane Service Truck (A61573)
2017 Freightliner...
3269 (A63117)
3269 (A63117)
New/Unused AGT 3000PSI Hot Water Pressure Washer (A65583)
New/Unused AGT...
2013 CHEVROLET 2500 HD (INOPERABLE) (A65643)
2013 CHEVROLET...
