Best string trimmer string.
/ Best string trimmer string. #1
N80
Super Member
SC
Kubota L4400 4wd w/LA 703 FEL
I have a Stihl FS-90R string trimmer. It is a nice unit. A little more than what is needed for just around the house but I use it for other heavier stuff too. Stihl lists it as a professional trimmer for whatever that is worth.
The Stihl string that came with it was terrible. Every post, pole, brick or piece of sidewalk it touched wore it down or broke it off rapidly. When that was gone I bought a large spool of Husqvarna branded 'heavy duty' string. It was just as bad or maybe worse. Now it is almost gone and I'm looking for something better. Tired of constantly having to reload string onto the trimmer.
Can anyone recommend a good durable string for a trimmer this size? Or if it is somehow user error I'm open to any tips for longer string life.
Thanks.
/ Best string trimmer string. #2
I have found the new (to us, anyway) tri-colour line from Stihl to be particularly strong.
It has Black/Grey/Orange stripes.
Well, that Husqvarna string is exactly what I have and it tested well in both of his videos. Not so much for me.
/ Best string trimmer string. #5
I got this guy here. No more screwing around with string. Blades last plenty long, and are pretty cheap.
/ Best string trimmer string. #6
Same for me, as I was going though the spool of Husqvarna I found it to vary in size/diameter. It ranged from about a .040 to .125, so thick it could not pass the guides of the trimmers. I am now back to using a spool of Stihl trimmer line and it is hit and miss, some of lengths of it wears very well and some of it breaks almost instantly.
  • Good Post
Reactions: N80
/ Best string trimmer string. #7
Thanks.
I can't tell what size string you are currently running. I'd suggest you get a cam lock head and go to .155 string. We've try lots of string brands and find little difference but size does matter. Go big.
/ Best string trimmer string. #8
I'm using .095 right now. Thicker than the OEM line, but not .115. I tried the plastic blades, they worked OK, but not nearly as good as thicker line.
I can take any grass and light brush with it on my Echo 58v trimmer. It may not be best for a pro, but I get 2 hours of trimming on one charge. With 90+ degrees and 90% humidity, I cannot stay out that long.
I may try some .115 next time.
/ Best string trimmer string. #9
I bought a large roll of Echo brand string at HD. One thing I learned from a small engine repair shop owner. He said that all of the strings become dry and brittle over time, especially if they are stored in the heat. He recommended that the roll of string be submerged in a bucket of water for a day periodically to avoid it becoming dry and brittle.
/ Best string trimmer string. #12
I have similar experience as you. I have a fairly long driveway and really have troubles when edging it. I hate to say it but I think it’s one of those things you have to live with. I’ve tried various string and none seem better. I do keep my string in a zip lock bag with a little water in it.
I have found if you just weed eating tall grass the string lasts a long time. It’s when you get up against hard objects it breaks off.
/ Best string trimmer string. #13
On my Stihl FS-110 I switched it to a cam lock head not long after I bought it and use the .155 line. So much better than a feed head and it works really well for fighting back the heavy growth/weeds with out constant line changes. I usually put a handful of cut pieces in my pocket and have a few left over when either I have done all I feel like doing or have gotten it all done which takes about 6 hours.
/ Best string trimmer string. #14
That is exactly what we do. Put string supplies in backpack or pocket for shorter work runs.
/ Best string trimmer string. #15
I had the same problem with my old Craftsman gas trimmer. Cutting along the walls, it would eat a spool of string in no time. It didn't seem to matter what size or type of string I used.
For most of the work I do along fence lines, walls & foundations, the gas trimmer was overkill. I also got tired of the noise, mixing gas, and draining the carb after every use. As a fix, I bought a DeWalt cordless string trimmer that uses the DeWalt batteries I already have for my tools. It has 2 speeds, and set on low, it cuts most of what I need to do with minimal string use. One or two spools lasts a season. It's also lighter weight and easier on the arm muscles. The best thing though, is the wife can use it! :) She wouldn't touch the gasser with a 10' pole.
I still use the old Craftsman for the gnarly stuff, but that is usually just once a season and I can put up with the excessive string use. I guess it all comes down to having the right tool for the job.
/ Best string trimmer string. #16
What size string was the largest stuff you tried?
/ Best string trimmer string. #17
I like the Echo Black Diamond line. Cuts great but like any other trimmer line it's going to break along fences or rock walls. If it's not heavy weeds, just lay off the throttle and you'll break less line.
John Deer MX8 Bush Hog, 3pt, Dual Gear Box, PTO (A62679)
John Deer MX8 Bush...
Kubota V3600-T-E2 Turbo Diesel Engine - 3.6L - 84 HP - 2018 - Tier 2 - Pump Takeout (A63689)
Kubota V3600-T-E2...
2016 Chevrolet Silverado 1500 Pickup Truck (A64194)
2016 Chevrolet...
2012 INTERNATIONAL DURASTAR 4300 BUCKET TRUCK (A65643)
2012 INTERNATIONAL...
Aluminum Hog (A65583)
2012 UTILITY VS2RA 53X102 REFRIGERATED TRAILER (A59914)
2012 UTILITY VS2RA...
