CK2620 to CK4020 or more
   / CK2620 to CK4020 or more #1
JetDoctor1
Member
Carrollton, GA
Kioti CK2620
I bought my CK2620 last winter and knew it was going to be shy on the HP I needed. Why didn't I just buy a CK4020?? The biggest reason is I didn't want a computer controlled tractor. I like the idea of having a tractor I can work on without taking it to the dealer every time it has a hiccup for them to connect it to a computer to tell me I have a bad sensor or two and 10 to 15 yrs from now they no longer service that model then your stuck with buying a new tractor. Second I knew this 100.5 ci engine had a lot more in it. Third it's the same frame as the 40hp engine and $6,000 less. This past weekend I turned up the global fuel screw beside the fuel cutoff solenoid and advanced the injection timing. Today I hooked up my 60" tiller and couldn't hardly tell it was even back there. Before it constantly stalled the tractor. Huge difference. I am betting it's sitting at 40 PTO shaft HP which is 44.35 engine HP. 4 to 5 parasitic drag loss between the engine and PTO shaft. I am looking around for a dyno to confirm my thoughts. I will report back.
   / CK2620 to CK4020 or more #2
Welcome,
I’m subscribed 😬
However, if you’ve turned up the fuel and increased the output by some 60%?!…..stuff is gonna break. (24.5 hp to 40ish)
Awaiting more info, especially your dyno results!
Welcome,
I’m subscribed 😬
Thanks for the welcome.
If your referring to breaking the motor, the pre-emission CK4010 is a Daedong 1.8L 3-cyl diesel. A slightly larger version of our CK2620 1.65L 3-cyl. That's only 11ci larger, which had a lot of power left in it too. but if your referring to the frame, axels and transmission they are both the same.
   / CK2620 to CK4020 or more #4
The 2620 has a rated PTO of about 20hp, while the 4020's is about 35hp. Assuming they are the same strength wise, you are still over powering it. As far as I know when people turn up the power on the 25/26 series, they keep it at 10hp increase or less.
   / CK2620 to CK4020 or more #5
Based on what I've seen, 35hp engine and like 28 pto is kinda the sweet spot; but I am following. Noone online that I've seen, has more than "feels like" power info on the turn up. I'm really considering the process, but will admit Id prefer to not void warranty.
   / CK2620 to CK4020 or more #6
Everything I've watched, is turn the screw up, then back it down till black smoke stops at full throttle, no load. Not very scientific. Is smoke an accurate measurement?
   / CK2620 to CK4020 or more #7
Also, sorry for the multiple short posts but, noone on YouTube mentioned anything about advancing time,
   / CK2620 to CK4020 or more #8
I was in the same dilemma. I did end up buying a CK4010. For me, it was less frightening having the CK4010 and hoping it does not have problems vs buying a 2610 and turning it up and praying it doesn't break. Seemed the less worrisome option. So far, I have had no problems with the CK4010 at 360hrs.
   / CK2620 to CK4020 or more #9
Forgive my ignorance, but with a carburetor gas engine, you set an idle screw and a fuel screw. On a this engine, it's just one screw; so for an ignorant guy like me, does that affect starting or idle speed or anything line that?
   / CK2620 to CK4020 or more #10
That screw only effects the maximum amount of fuel that is allowed to be injected. These diesels are set up quite lean and more fuel can generate more power at the same rpm. The engines governor and the min - max stops are what control the rpm.
The PTO power is 4 to 5hp less than engine horsepower due to parasitic drag. Same gearbox as the 4020.
I also advanced injection timing by 6 deg. If you would like I can give that procedure.
Not exactly. It governs the max fuel that can be injected under load not max rpm. RPM is set by the governing spring.
I knew I was voiding my warranty but when was the last time you heard of a engine failure on one of these things?
If it blows a poof of black smoke under load it's set perfect. That's what diesels do.
   / CK2620 to CK4020 or more #16
I do believe that is about what I said;
"That screw only effects the maximum amount of fuel that is allowed to be injected."
The idle speed is set by a screw that limits the fuel rack, the high speed max is set by a bolt on the governor speed plate.
I will agree that just a trace of smoke under a heavy load is a good "tune".
   / CK2620 to CK4020 or more #17
If you do the math the PTO power is always about 22% less than engine horsepower. Directly proportional. Same gearbox.
And you said you think it's at 40hp at the PTO, which is more than the 35hp the 4020 normally has, all I'm pointing out. I haven't looked up the parts, so don't know if it has the same gears and shafts as the 2620.
Its not ignorance at all. Just think as a diesel engine as just the opposite of a gas engine.
A gas engine limits power by the amount of air that it receives ie. (the throttle valve, butterfly valve).
A diesel engine limits power by the amount of fuel it receives (fuel injection pump). Open intake track all the way from the air cleaner to the intake valve.
Also the leaner a gas engine runs the hotter the combustion is. With a diesel engine the richer it runs the hotter the combustion is. Heat =power. Clear as mud. Lol
The CK4010 and CK4020 is 39.6 engine HP and 34.9 PTO hp. Which if I made 40 PTO hp on my CK2620 (my target) that would put my engine at 44.35. Very obtainable for a 100.5 ci 1.65L engine. The 4010 and 4020 is a 111.5ci 1.8L engine that has a lot left in it too.
   / CK2620 to CK4020 or more #20
Heck, the Kukje A1700 engine from Branson, now TYM, covers all the way from 25hp up to 48HP. Albeit, the 40 and 45 hp got the help of a turbo, probably to help cleary some of the smoke.
I see no reason why the Kioti engine wouldn't be able to do the same. The rest of the tractor doesn't concern me at all. They built the tractors to handle a range of HP, so we know that it's good for at least the highest HP model offered, probably more actually.
Also, I didn't research that but wouldn't surprised me if this Kioti engine would be tuned to higher HP on markets where emissions aren't required above 25hp.
I'm really interested to see the dyno results whenever you get into that.
2008 MOTIV ALUMINUM TRAILER CO. 32 TRI AXLE GOOSENECK ENCLOSED TRAILER (A58214)
2008 MOTIV...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2019 INTERNATIONAL...
JLG 660SJ (A58214)
JLG 660SJ (A58214)
WOODS 3120 BATWING MOWER (A60430)
WOODS 3120 BATWING...
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
1999 GMC C7500 S/A Dump Truck (A59230)
1999 GMC C7500 S/A...
