unsynchronized tranny use?
/ unsynchronized tranny use? #22
We will contact the owner of 2001 John Deere 4700 but dropping its price by 10K seems unrealistic.
Still thinking that’s way too much for a machine that’s 23 years old. I’m assuming that you’re talking in the $30 thousands.
Here is a 2021 John Deere 4044m for $25,990 Listed 4 days ago 4 days ago in Hudson, WI. Seem like a better price!
/ unsynchronized tranny use? #25
Don't know your market, but I've seen a couple mid-late 90s MF-231 2WD w loader machines online, for less than $8000. Unless I'm mistaken, which I might be, I thought all of the MF 231s were dry clutch shuttles, which is better than the hunt and peek JD-790s I've seen.
Edit: according to Google, I'm wrong, it says all 231 and 231S are 8x2 sliding shift; but I swear a contractor I worked with had a dry clutch shuttle 231. Maybe it wasn't a 231
/ unsynchronized tranny use? #26
I know it's not your area probably, and there isn't anything wrong with JD, but when we are in the $20-30k used tractors, there is a lot more machine when you include non-JD in the search. The link is a 49hp, syncro-shuttle, with like 350 hours, 4wd, loader, and 3 high value impliments.
/ unsynchronized tranny use? #27
Not only preaching MF, just saw a very low hours, 2018 Mahindra 4540, but it was hunt and peek trans, for $23k, including bushhog. Another 4540 for $17.8k, no impliments.
If we just like Green, JD-3032e, HST, loader,1767 hours in Lakeland for $12,900.
/ unsynchronized tranny use? #29
There likely is a reason that JD carries value longer and often higher than the other brands. Some like that, some do not. But it seems an undeniable fact.
Everyone has to make the decision for themselves.
/ unsynchronized tranny use? #30
Locally found a 2001 John Jeere 4700 with less than 200 hours on it AND is hydrostatic. Asking over 30K for it and looking at them on-line seems to be waaaaay to much.
A low-hour machine can mean several things and they're not all good. It may have spent more time in the shop than in the field. Or the previous owner couldn't use it--Too big for his use, didn't understand the mechanics and/or abused the heck out of it.
/ unsynchronized tranny use? #31
Simple and will work just fine...just a lot more leg work and slower. I ran a dry clutch tractor with an unsynchronized F-R lever for years, I got along just fine. I clutched well over 1000 times one day hauling and stacking round bales, right leg had to hold tractor with brake pedal during the F-R shift almost everytime too.
/ unsynchronized tranny use? #32
I only have dealerships nearby for JD and Kubota that I care to use.
There are deals out there; not helpful to you, unless you like to drive; but a 2 y/o Kubota 3902hst, with equipment trailer, bushhog and box blade, 9 hours of use; for $33,900.
/ unsynchronized tranny use? #33
There are deals out there; not helpful to you, unless you like to drive; but a 2 y/o Kubota 3902hst, with equipment trailer, bushhog and box blade, 9 hours of use; for $33,900. View attachment 882880View attachment 882881
That deal would be worth considering. Especially since it comes with a trailer. Drive there and tow it home. Assuming it’s in the condition as advertised.
/ unsynchronized tranny use? #34
It's in Jacksonvillw, so I'm guessing 14 hours from our OP; but 14 hours to buy a $40k package for $33.9k; might be time well spent. No way in heck I would make that drive without an actual phone conv with the guy selling.
New/Unused CFG Industrial H15R Mini Excavator (A65583)
New/Unused CFG...
12in. Tooth Excavator Bucket (A64194)
12in. Tooth...
2019 K&K Equipment Trailer, VIN # 1K9PE2029KA175459 (A65563)
2019 K&K Equipment...
Stertil Koni 18000lbs Auto Lift Columns (A61572)
Stertil Koni...
Chery 20'x30'x12' Storage Shelter (A64127)
Chery 20'x30'x12'...
NEW ATA-EPC40 Plasma Cutter (A62679)
NEW ATA-EPC40...
