John Deere 322 Yanmar 3TG66
/ John Deere 322 Yanmar 3TG66 #1
Daniel1
John Deere 322
John Deere 322 with Yanmar engine will run 15 minuets and shut off abruptly. Wait long enough will crank and run another 15 minuets.
Checked coils--all have fire.
No fuel in carb-- Fuel filter clear. solenoid working.
Replaced fuel pump. Still doing the same thing. Any suggestions? Thank you!
/ John Deere 322 Yanmar 3TG66 #2
Ah, your best bet is to ask Yanmar owners in the Yanmar section. (y)
Your machine has a specialized Yanmar diesel engine.
/ John Deere 322 Yanmar 3TG66 #3
If it's a gasoline engine with no fuel in the carburetor I'd check to see if the float valve is working properly. That can prevent fuel from entering if it sticks closed. Disconnect fuel pump from carb and check to see that it's putting out fuel.
Thanks. But is a gas burner. Ill
Check on there as well.
Took Carb off and opened up. Looks good. Hooked up fuel pump with top of the carb off. Turned fuel pump on. Observed float working properly. Reassembled everything and test ran for about 10 minutes tonight. Will test run again tomorrow with voltmeter hooked up to fuel pump to see if the pump shuts down due to loss of power.
2022 EZ-GO ELITE...
2016 Chevrolet Silverado 1500 Pickup Truck (A64194)
2016 Chevrolet...
APPROX. 1000 GALLON FUEL TANK (A63291)
APPROX. 1000...
2016 Nissan Titan XD Crew Cab Pickup Truck (A61573)
2016 Nissan Titan...
Adams 16T Tender Body (A63688)
Adams 16T Tender...
2015 MACK CXU613 T/A 6X4 MID ROOF SLEEPER TRUCK TRACTOR (A59912)
2015 MACK CXU613...
