JD 4115 front tires
/ JD 4115 front tires #1
Dave_in_MD
Finksburg, MD
JD 4115
what tires can replace 24x8.50 - 12 ? can't find them anywhere and the tractor is 4wd. Dealer says tire was discontinued.
/ JD 4115 front tires #2
Are these turf tires? Google shows a whole lot of manufacturers making that size.
Yes they are turf tires, if you look at the ones that google brings up they are usually 23x8.5-12 or 24x9.5-12. the firestones are discontinued. Since the tractor is 4wd tire size is important.
/ JD 4115 front tires #4
Uhmm. I am not a tire expert, so I would go to a tire shop that does ag work and see what they say. Rice Tire in Frederick has some knowledgeable ag tire people, but that may be a little far for you.
I know that if you get into the tire specs you can get the circumference, which combined with what can fit in your rims is the important number in 4wd applications. I believe most fronts lead by 3-5%.
Thanks, Frederick isn't that far away
/ JD 4115 front tires #6
As RJCorazza said go to an AG TYRE specialist. Even if that size is discontinued, they will be able to find a good subsitute size to maintain the front /rear tyre ratio which is what matters.
Talked to Rice Tires, they recommended 24x9.5-12 Kenda tires. they are 9 inches wide, so slightly wider than current, but are the same diameter. ordered new wheels, got one today offset is less so should give me more clearance. offset on current rim is 4" new rim 3 1/2".
2014 Ford F-150 Pickup Truck (A64556)
2014 Ford F-150...
2015 Nissan Altima Sedan (A64557)
2015 Nissan Altima...
2001 Belshe Backhoe Trailer (A64194)
2001 Belshe...
2014 International WorkStar 7500 T/A Leach 2RIII 25Yd Rear Loader Garbage Truck (A64556)
2014 International...
2012 FREIGHTLINER M2 6X4 T/A DAY CAB TRUCK (A66091)
2012 FREIGHTLINER...
UWS TBS-69 Truck Bed Tool Box (A64556)
UWS TBS-69 Truck...
