High Performance Radiator?
/ High Performance Radiator? #1
wdwurker
Albany, OH
4200 VXD, JD 990
I'm thinking about checking into using a High Performance radiator on my 4200 (4231TD) and was wondering if anybody else has gone that route. I have used them in race cars before, but their run time was much shorter than the Ventrac. I'm thinking an aluminum high flow radiator might allow me to watch what I'm doing... instead of constantly watching the darn temp gauge.
/ High Performance Radiator? #2
There's a factory upgraded aluminum radiator available I think they started using them around 2011-2012...my 4231 gas was left in an unheated garage with water in the cooling system ,the copper radiator was toast,I went with the aluminum high capacity and I can't tell you if it is better because I bought the machine with the exploded stock radiator, but it sure cools great. Like any other quality radiator it's not cheap. The 31TD is a known overheater,some worse than others but either way I'd do the upgraded radiator. .
/ High Performance Radiator? #3
That is very interesting. I was/am impressed at the quality construction of the OE radiator in the 4500Z. Not sure if hi flo or not, but quite robust. I wonder if Ventrac adopted a new design for the later model tractors? Besides, aluminum has to be less costly than copper. I let my VT get hot during brush cutting a while back when the screen was fouled (radiator under the screen fouled too) with pollen and chaff; there was a loud alarm that got my attention right quick. Pulled the throttle to idle and cut the PTO, the alarm ceased within seconds of lifting the screen with engine at idle. I need to put a soft brush in the tool kit to gently sweep the radiator in the field. That day I used my shop-vac with brush attachment to mostly clear the radiator. Back washing the radiator is quite a challenge as the fan and fan shroud leaves little room.
prs
/ High Performance Radiator? #4
I seen they have a kit for the TD engine at the time I ordered this one,not sure if anything has changed...I found the install sheet for mine,I think this was about a 750.00 radiator, my bill was 1200 but I had alot of other parts in there like a head gasket,all filters,fan belt,thermostat,and other misc parts...I can run my machine with the screen plugged and it's never got over 190 yet,I clean the screen after every mowing, or if it gets hot while mowing, it never does though.The turbo diesel engine has a known cooling problem,more of them than not overheat on hot days ,my dealer has one that overheats after an hour of use and simply cannot fix it,he's tried everything. .idling til it comes down off 220 is the only thing that stops it..if I were you I'd be careful with that machine those engines are expensive and have a very high failure rate..even when properly maintained..
/ High Performance Radiator? #5
The last picture has the manufacturer info...the kit for the turbo diesel is different, probably more cooling capacity. ..anyway here's all I have ,if you have any trouble with your dealer finding it , my local dealer ,Round out Valley Engine, in Accord NY is excellent, you can call him and I'm sure he will help you.
Thanks Raw... I pulled Radiator Specialties Inc. phone number off the ole internet and will be calling them Monday morning. $750. huh, WOW. I could pay someone to watch the temp gauge for a long time for $750.
But then again, I could have paid someone a couple hundred dollars a month to mow my acreage and still save money over buying this high dollar mower... but how much fun would that have been.
/ High Performance Radiator? #7
I'll try to find the receipt I think it was around 750.. Of course that was through my local ventrac dealer. I am pretty loyal to him he has always treated me well and helped educate me on the hydraulic pumps and motors these machines have. If it wasn't for him I wouldn't know half of what I do about the Steiners hydraulics. He has become a very good friend as well as a great businessman, how often will a shop owner tell you how to fix something when it cuts into his profits . I would imagine your radiator would slightly more, it's probably a little bit thicker I wanted to get the turbo diesel radiator version for mine because you can never be over cooled, as long as you have a working thermostat. I ended up getting the normal version and I gotta tell you this thing is incredible however my dealer says the gas engine doesn't have an overheating problem.
/ High Performance Radiator? #8
Wonder if a good local radiator shop could make up something. We used to have them made for our heavy equipment and they would leave out every other fin to reduce plugging from chaff, made a big difference .
/ High Performance Radiator? #9
Leaving out every other fin may keep grass collection down,it will also dramatically affect the radiators ability to transfer heat..if they could compensate with a thicker core I'd be willing to try it.on my machine there's plenty of room for a thicker radiator, an inch easily, possibly 2 or more if you rerouted one hydraulic hose a little rearward. .my dealer says that water cooled turbo is a double edged sword..it adds a tremendous amount of heat load to the cooling system, an amount that was never factored in ,as the original design was a normally aspirated diesel,the turbocharger was added later on,to match the gasoline engines performance,but the engines with them tend to run hot and not have the service.
I want to update my thread a bit. OMG! What a difference! I bought the upgraded Aluminum Hi-Flow radiator from my dealer for a delivered price of $485. installed it in an hour or so, and brother... my overheating troubles are history. I have about six hours on it now (2 x 3hrs) at full throttle and plenty of slope. The temp gauge never went over 190, actually it was at 185 for most of the session. When finished mowing, the pre-screen was about one third plugged and had no effect on the cooling. I am so happy I could ... mow my neighbors yard!
I highly recommend anybody who is running with a TD engine to get one of these ASAP. WOW, what a difference.
/ High Performance Radiator? #11
So glad you got the radiator! I told you it was worth it!I had the same experience ,you can clog my screen and keep mowing and never go over 190..That's a great price, they must have come down in price,that modification will save your engine. .
/ High Performance Radiator? #12
How often are you cleaning the Radiator?
/ High Performance Radiator? #13
Mine has one on it right from Ventrac and it leaked in a year. Had it repaired and it has been good for over two years.... Jim
/ High Performance Radiator? #14
I have a 4200 VXD Turbo Diesel. The belt that goes on the alternator, fan, and I believe the cam/drive shaft, broke. I'm told I need to pull the radiator to get to 4 bolts on the cam/drive shaft to get the belt on. I cannot for the life of me find any pictures, videos, diagrams, or tech manuals from Ventrac to show me how to do the work. Any help would be greatly appreciated. Thank you.
Bill Guzewicz (Guh' zuh wits)
billguz@gmail.com
/ High Performance Radiator? #15
billguz@gmail.com
Pages 11 and 12 of this manual may give some insight. Keep in mind that components like radiators and air intakes and the like on these engines are frequently moved around for different applications, so I can't tell you if this mirrors what you have without seeing some pictures.
Posting this as a new thread this with some pictures would help us keep up with your progress.
/ High Performance Radiator? #16
billguz@gmail.com
I agree with what @MountainBuck posted. When I first saw that a response had been made to a 2+ year old thread about "High Performance Radiators" I didn't pay any attention to it. I might have done so for a new thread about "How to replace the alternator belt on my Ventrac Turbo Diesel engine". If you create a new thread you might get more useful responses.
I read through the Ventrac operator's manual and it seems that the manuals for the earlier versions are much less complete from a service perspective that those for later models. Unfortunately the 3-cylinder turbocharged Vanguard diesel is no longer offered as an option, so we can't suggest looking at a manual from a newer model with the same engine to get some insight.
/ High Performance Radiator? #17
Thank you. I will create a new thread in a couple of days.
/ High Performance Radiator? #18
2014 Ford Transit Connect Handicap Van (A61573)
2014 Ford Transit...
2016 KENWORTH T680 6X4 T/A DAY CAB TRUCK TRACTOR (A59914)
2016 KENWORTH T680...
Crate of Misc Parts (A64119)
Crate of Misc...
2023 Mercury Verado 350HP Outboard Boat Motor (A61574)
2023 Mercury...
KBH PT 12 Row Liquid Fertilizer Applicator (A64119)
KBH PT 12 Row...
2014 JEEP GRAND CHEROKEE (A64280)
2014 JEEP GRAND...
