Good morning!!!!
/ Good morning!!!! #193,842
Popgadget has been messaging me many suggestions.
I need to go check pressures now. Fortunately I have gauges, but discovered the battery in my probe thermometer is dead. Going to order new dual thermometer also.
I believe I can legally buy Freon with the HVAC license I have. I took a class many years ago for the first part of 608 license. It’s been so long, have been refreshing my knowledge.
I don’t have any leak detection fluid yet, nor most of the tools needed. My gauges are old from R22 days.
/ Good morning!!!! #193,845
73F few clouds here and there mid 80's for high.
Out the door at daybreak headed to side field with tractor chainsaw cut down and clean up several damage gray white birches trees cause by last winter ice storm,Doe kept close eye on me lying about 50 yards away. :oops:
Plans for rest of today :unsure:
Enjoy your day all.
/ Good morning!!!! #193,847
Truck’s all shined up and ready for another year of neglect lol!
/ Good morning!!!! #193,848
Good Morning!!!! 86F @ 9:00AM Sunny. High 107F. Winds SW at 5 to 10 mph.
Dad got mom an Olds Delta 88, I think in about '65 or '66. That winter she spun it 360° on ice in an intersection, and refused to drive it again. By the next summer she had a '67 Ford Country Squire wagon woodie, the car I would later learn to drive in.
Your timing was just about perfect, PH. Great video, watched it full screen.
Fooled around with the solar panel up at the gate yesterday. Changed it out for a new one, but no improvement in charging. Used the multi-meter on the connectors to the panel, and the ground wasn't conducting through the connector. Thought it might be the female side, so gave it a little squeeze with a pliers, but still no joy. All my solar stuff is still up here, so I changed out the female side of the connector and now it's working like it should. Sure glad I didn't have to pull the wire out. It runs inside a 20' pole, then underground for about 15'. What a mess that would have been.
By then it was hot enough I didn't want to be in the sun any longer, so I started spackling holes in the garage walls and ceilings where storage shelves had been. Must have done at least a hundred of 'em, and that was only about a third of the garage. Also repaired the pair of 6" holes cut by the PO to vent a portable A/C unit he used to cool his dope crop. I was trying to do it with a putty knife and not having much luck. Looked in the box of painting supplies and found a 10" drywall knife that was just right. Not a perfect job, but good enough under the spray on texture I'll use to finish it. About then the heat drove me back inside. Spackled a few more holes on the inside walls that I'll touch up with paint today.
Up early and got a transmission oil filter changed on the M62 before it gets too hot. Service manual says to drain the transmission first, but I put a bucket under the filter, which sits sideways, and let whatever oil was in the filter drain into the bucket. I also hooked a shop vac up to the oil add hole, but I don't think that helped much. Regardless, glad to have that done with less than a pint of oil lost, not even enough to show on the dip stick.
Probably do more spackling in the garage this morning yet, not sure what I'll get into this afternoon, other than it'll be inside the house.
Monday, Monday...
/ Good morning!!!! #193,849
68°F and .16 inches rain.
Today’s Happy Hour will be home hosted at friends. Spanish theme. I will be attempting A Spanish Garlic Shrimp.
My dealer tech supposed to be getting guidance from factory tech 🤞
Prayers for all
Be safe
Have a great day
/ Good morning!!!! #193,851
Was checking on the Waste to Energy facility in Mass called Semass that in the past was under Operating and Maintenance contract that was very interesting and challenging
It is still there and in operation. The recovery of coins in the garbage was one of our initiatives as well as making it more explosion proof for propane bottles and explosives in the garbage. Making the shredder roof out of sail cloth saved time and insurance costs. Always loved the area near Cape Cod. Took a couple of the kids with me on one of the visits to learn about waste to energy
/ Good morning!!!! #193,852
Ted, I bet Max slobbers a lot looking at all that wonderful food...I mean he's a dog
and his primary purpose is to get to that food. Is it all dry or do you change flavors at times?
Drew, it is fresh and moist, gets frozen in containers. Each container holds 2 days, the 'leftovers' are refrigerated. Similar to the "Freshpet" or "The Farmer's Dog" food sold in stores.
Basically a mix of beef, chicken, liver, gizzards, yams, peas, carrots, whole oats, brown rice, goat milk, eggs, coconut oil, parsley.
Flavor only changes by varying the amounts of chicken or beef quantity.
All good foods.... Dona actually 'taste tests' . We could steal some and have a meatloaf for us!
Yes, Max hangs out in the kitchen the whole day, making sure its made right..... he gets samples at different stages.
Yesterday, he started to bark at the pots as they were cooling up on the stove.... "C-mon already--- I know the good stuff is up there! "
/ Good morning!!!! #193,853
Plowhog, thanks for posting the video! Awesome on the video, must be spectacular in person!
I was disappointed that it wasn't coming closer to us. I would definitely drive a few hours to see it.
Looking, thanks for the tip! I wanted to get one of the "bug-assalt" guns, but the wifey wouldn't be happy shooting salt all over the house. It would be a blast for sure!
Got a few pieces glueing up, other pieces ripped. Time to go take Max to the groomer. Need to stop at HF too ---- I broke the backing plate on the sander. Wasn't good to drop it off the bench.... 🤯
I think I'll get a spare too....
Wifey making homemade Italian gravy and meatballs, sausage, and a chunk of pork. 🥲
/ Good morning!!!! #193,856
Thomas, white birch is good kindling for the fire.
Very true,these gray birch I cut down were mostly punky and top were dead now stack in pile,come December some sausages rolls good chance couple spirits ;) I'll burning the pile.
/ Good morning!!!! #193,857
Good Afternoon,
Scott, nice car! I am assuming you did the resto?
Hi Ted, I can only lay claim to part of it ! Last year I replaced all the wheel bearings, brake drums brakes and seals, springs etc. I also installed blinkers on the car to make it safer to drive out on the road with all those crazy drivers !
/ Good morning!!!! #193,858
Took pressure reading on the geo unit this morning. compressor is still shutting down in about 2-3 minutes from startup.
opened up the pack of Halo 4" LED lights I got for the porch ceiling. Takes a 4 3/16" hole. Why doesn't a 4" take a 4" hole? Didn't have a hole saw that big anyways, so ordered one, and some cable clamps for the boxes. Also ordered a new dual thermometer.
Found corroded battery in my IR thermometer this afternoon.
Got a large bill from the hospital from my son's wreck, so now trying to find out what exactly the car insurance paid out for medical. They claim they paid $2500, but I have no idea what for. My agent said to call or email the adjuster and gave me the info. Also Car insurance still had the totaled car on it. They never removed it, so I had to email them the proof of return of plates to MVA.
after 1 day the new eufy camera working great. I might have to get another. Like the way it tracks, and only notifies me on people or vehicles. All my other cameras capture all the trees and bushes blowing.
Got .27"of rain today. Not much, but better than none.
AC feels good downstairs........
/ Good morning!!!! #193,859
Good (Tuesday) morning. Overnight Low of 13.4C and it's presently 15.0C, overcast with a mild breeze. There was 0.6mm in the gauge @ 0900.
Lovely Church Council meeting last evening. Home by 1815.
Not much going on at the moment, which is fine by me... just enjoying this mild Winter weather.
/ Good morning!!!! #193,860
And took me an hour to find my multimeter, in my bag of electrical tools.....duh I checked the basement, truck, barn, camper, garage multiple times (but not in the open bag in plain sight..)
cut up a watermelon after supper, it's pretty good. Cantalopes about ripe. one plant the leaves starting to get spots and dry up.
2020 Kinze 3505 High Speed 6/11 Planter (A61307)
2020 Kinze 3505...
2015 Ford Explorer AWD SUV (A59231)
2015 Ford Explorer...
2017 Kustom Signals Towable Solar Radar Speed Limit Trailer (A59228)
2017 Kustom...
2017 Ford F-150 Crew Cab Pickup Truck (A59230)
2017 Ford F-150...
2013 BMW X5 AWD SUV (A59231)
2013 BMW X5 AWD...
2016 DRAGON SAND CONVEYOR (A58216)
2016 DRAGON SAND...
