Hay Making on a Different Scale
/ Hay Making on a Different Scale
/ Hay Making on a Different Scale #123
Still have the open station IH with 4WD?
Love that thing…..
/ Hay Making on a Different Scale #124
If I would fix the rear tongue I would be pulling a 2nd wagon with 10 more. Get 2nd bale wagon would be pushing 50 per trip. Anything to save time
Yep! Its amazing how time is our most precious asset.
I went to a large square baler years ago to save time, and a bigger rake, and road speed tractors, and a bigger trailer….
TIME is what there is never enough of….especially during 2nd cutting. 😂
/ Hay Making on a Different Scale #125
I bobbed and weaved and got all my fields in one 2 day shot down with a real heavy crimp, let it sit a day in the hot sun and raked it the next day and bailed it that evening (that was a long night). My customer came with 4 flat bed semi trailers and I loaded everything and away it went and then it rained again before I could run the bat wing shredder on the fields so I had to wait 2 days for that and then right after, I applied 28 Urea liquid and 24D(B) herbicide and called it good and it's been precipitating about every other day since. I was extremely lucky and all the equipment ran flawlessly, well sort of. My open station M9 Kubota developed a leak in the right outboard that needs to be addressed as all the gear oil ran out on the rim and tire and I'm not about to use it for anything until I get it fixed. I have the big radial O ring and the O ring for the end of the hub so that is next on the agenda along with fixing my buggy. It seems to have a bad bearing in the alternator but I won't know until I take it apart. Have a new serpentine belt as well as a new idler tension assembly because I'll have to destroy the original serpentine belt to get it off to surmise what bearing in what is puking. Always something needing fixed here. New rebuilt alternator at Auto Zone is 175 bucks, hate to think what the AC compressor would cost if that is what is growling. After that, I'll get into the tractor hopefully. Last year I did the upper and lower kingpin bushings on it. It has 6700 hours on it. Kubota uses a kingpin front on their FWA tractors btw. I'm done until September now, maybe October depending on what the weather brings. It will be mostly vernal alfalfa and again, it's all pre sold. I relinquished my 2 remote fields I was doing on shares. With my ongoing cancer issues I don't want to wander far from home and have some sort of episode in the field and expire and no one would know. Doing my owned fields around the house, I feel much safer and I'm 75 this year so I have my age against me as well. Besides I carry a high power GMRS business radio in the cab and my wife has the base station in the house so if anything happens, I can get help immediately.
Little backstory on my round bailer. 2 years ago I bought a new Kubota BV series net-twine round bailer, traded in my New Holland for it. I never liked the NH net-twine round baler as it was very inconsistent wrapping over the edge net, plus the pickup wasn't wide enough even with gathering wheels on it.
I had issues with the Kubota bailer right away and had to have the regional rep out here to reset the net stickout because it wasn't picking up the net consistently and I had to resort to twine when it failed and my customer wants everything in net so I got that handled but I was building loose hay on the inner drive roller to the point where the belts were getting tensioned way too much when the chamber was full so I had Dennis (he's the head tech at the dealership I deal with) look at it and he agreed there was something seriously wrong with it plus I could not set the density tension on the fly which I was supposed to be able to do (I like a soft centered bale for ease of spearing but I want the rest of the bale fiddle string tight) so he came out and picked it up this spring and took it back to the dealership and I told him if Kubota could not fix it, I wanted my money back and I'd go buy a John Deere bailer.
Anyway, he had it for a month and my hay was getting rank and I was dead in the water but he brought it back and now I have a Kubota BV Silage Special bailer. Kubota stood the entire bill too. He spent 3 solid days refitting it inside with scraper bars and rotating axles equipped with fan shaped rollers plus a new computer. They didn't make anything on that bailer but I will say it runs perfectly now and now I can dial the density I require on the fly from the tractor seat. Runs perfectly. I can even twine a bale and then over wrap it in net if I want to. I'm a happy camper and it runs over the edge net just fine as well. Speaking of net, the price per roll went up appreciably this year, dang inflation. I like running Bridon net but I've used Tamanet (JD) as well. The twine box on it holds 6 balls but I only have 2 mega balls in the box, just in case I had a net issue. I don't believe that will be the case now. Next year I'll probably purchase a new Kubota center point disc machine with chevron crimp rolls. No new rake however as my Kuhn Masterdrive twin rotor is just peachy. I need to keep those machines newer for that tax write off. Besides, my NH center point is getting old and I like new stuff anyway. My one hay customer was laughing at me, giving up about half of my hay ground but running a 70K round bailer. I really didn't want to but my health issues (cancer) made the decision for me. It's all good and being close to the farm if anything happens is a big plus for me as well as my wife. Been dealing with it for 7 years now and it's taken a toll on me and age is as well but I like doing it and I do everything by myself, no outside help at all. Wasn't the case when I did small squares. that was hard work all the time. Glad I gave that up and sold that 575 NH square bailer and all the hay wagons as well. Got top buck for it on Tractor House btw. I always take good care of my equipment. I ran thousands of square bales through it and a ton of wheat straw bales for the local county road board as well. They would buy complete wheat fields and have the farmer put the windrower attachment on the back of the combine and then I'd come in and square bale it for them I believe they used it for roadsides when doing new bridge construction or whatever. Don't know who does it now, I don't. It was easy too. Just kept the tine box full, the ac on in the tractor and drove, windrow after windrow, was kind of boring too, but it paid really well and I never touched one bale either. Their employees loaded it on their trucks I presume as I was never around to see that part. I just billed them for the total number of bales I ran on the counter and they sent me a check. One good day, I remember running close to 4000 bales. Started at dawn and finished about 10pm and used around 20 balls of twine or so. Cannot remember exactly, been a long time ago. I did stop and ate my lunch however. That NH 575 high capacity was a beast of a square bailer and really ran trouble free though I did stop infrequently and blew off the knotters. I still carry a cordless blower in the tractor cab even today.
Never liked dealing with horsey hay people anyway. IMO, very few of them know what good hay is and they all wanted it cheap as well. Don't have that issue now. My one customer never whines about the price, always provides his own transportation for the rounds (semi trailers), all I do is load them, his crew secures them and off they go and been that way for the last 5 years now. He always pays me before the first of the next year, just like clockwork and he's already lusting for the second cut alfalfa to feed his 'baby' cattle.
Don't know how much longer I'll be able to do it but I'm hoping until I'm 80 or deceased, whichever comes first I guess.
The cancer I have is inoperable so all I can do is keep it at bay with semi weekly infusions. So far so good. I don't have any discomfort or pain but I know it's there inside me. I can see it when they do a PET scan. I deal with 2 medical institutions, Cleveland Clinic and Trinity Health Care in Ann Arbor, Michigan. Trinity is my primary care facility. Cleveland Clinic is my go to for advice. Just got done with an infusion and had an infusion pump on the last 2 days.
Wish I could be rid of it, but not in the cards. Like I said, it's inoperable.
I will say at 74, just turned 75 on the 15th of this month things get a little slower and harder to do but I'm a survivor anyway.
Kind of long post but I felt like posting it.
Cleveland clinic is an amazing hospital, they kept my mother alive with a procedure that was very experimental. The Dr. was amazing. She (She and God) added another 12 years to my mom but unfortunately all of the surgeries and being under the knife for hours caused early onset dementia for the last 7 years of her life. She passed in her sleep in Nov. 2020.
She was a heavy smoker since she was 14 years old and should probably not even have made it to 78, but she did.
You're going to go out when God says it's time, as will I, I could be dead before you!
Love that thing…..
That wasn’t me. So far this is the only IH I’ve owned. Are you thinking of JD w/hfwd? Yes still have that.
/ Hay Making on a Different Scale #127
Yes! Sorry. I was only on my first cup of coffee. 😂
/ Hay Making on a Different Scale #129
We had a cabbed 4040 2wd and my dad said he was scaling back and was going to get rid of one of the JD's, he decided to keep the 2840 and sold the 4040, I always said that the 4040 was the best tractor that we ever had on the farm.
/ Hay Making on a Different Scale #130
Is that FWA? or MFWD
/ Hay Making on a Different Scale #133
28 rolls to the barn every trip isn't a bad haul,especially if you have someone at the barn ready to unload and get it in for you, but if it's like most of the time for me, you are loading it in the field, carrying it to the barn and then unloading and putting it in the barn then back to the field to start the process all over.
/ Hay Making on a Different Scale #134
When I did round bales and stacked them like that, they would get kind of a sweat damp spot where they touched together.
I really dislike stacking. Eats up time & fuel. Feels like you aren’t making hay (or money lol)
/ Hay Making on a Different Scale #135
I'm enjoying your pictures of you moving your round bales to the barn. Do you have any pictures of you unloading them, how they are stacked? I'm mostly curious in how you store them. I need to build a hay barn at my place. The entire process of getting hay to the farm where it can be used, and how it's stored is something new to me.
Someday need to get where I can stack all hay with skidsteer. Picking away at squares by myself. Slide them in with skidsteer then stack by hand. Fun
/ Hay Making on a Different Scale #137
That's a great barn!!!! Did you build it?
My ancestors did starting over 100 years ago. The area with squares was the last section added in the 70's. It was built in 3 sections.
All but 40 of the bales went into storage. The rest went down the road. 15/trip 45 minute turn around. One of our most efficient haulers. 240 bales this year to feed the horses year around for our local Jew Camp.
Not a great picture but until the tongue broke this is how we hauled the bales. Another 10 bales. If they go in the barn this is how they are stacked. If in shed only 2 high. Using skidsteer most of the time. Best investment ever made. Did 5 high once on one stack and having a 3rd bale wobbling on top was a little unnerving so that was the one and only time that happened. They make a double clamp that specifically grapples 2 bales so with that thought I could go 6 easy using same clamping method. Maybe someday. $$$$$
/ Hay Making on a Different Scale #140
You have an impressive operation!!! Is this your full time job? Most of the people that I've met have to work to afford their farms.
2003 Chevrolet Kodiak C4500 Flatbed 503372 (A62613)
2003 Chevrolet...
12ft T/A Utility Trailer (A64557)
12ft T/A Utility...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A61306)
2016 RAM 5500...
Hobart Champion 16 AC/DC Engine-driven Welder and generator (A63689)
Hobart Champion 16...
2011 FORD F-750 CHEMICAL TRANSPORT TRUCK (A65643)
2011 FORD F-750...
1997 Peterbilt 379EXHD Day Cab w/ Wetline (A62613)
1997 Peterbilt...
