any toro groundsmaster fans on here?
/ any toro groundsmaster fans on here? #1,021
remove the wire off the fuel solenoid, it activates to shut off fuel, after a short time it releases so remove the wire should run no problem
/ any toro groundsmaster fans on here? #1,022
I read up and found a decent video about Kubota fuel solenoid. Mine has a 3 wire connection. Before the arctic blew in I was close. From what I gathered. There are 2..12v coils that together open to allow fuel flow. 1 coil takes more amps and only operates momentarily. Then a low amp coil holds it open. I added a switch to manually operate the low amp coil.
Ill update when its running reliably.
/ any toro groundsmaster fans on here? #1,023
on my fuel shutoff coil only 2 wires one being ground, when starting the coil is not energized, the fuel free flows, when you turn key to off there is a timer circuit that energizes the coil and shuts fuel off, after a delay the coil power is cut and solenoid opens fuel again, fortunately the motor is stopped.
had a time there where the delay circuit was open and motor would continuously rum until I pushed the plunger to manually shut off fuel.
on the Jacobson the fuel shutoff is closed until the key is turned at which time fuel can flow
/ any toro groundsmaster fans on here? #1,024
Hi all, anyone have a wiring harness for a 1986 217D? Mine has been overcharging terribly and I tried a new rectifier/regulator that did't help. Must have a ground fault somewhere. Now the wiring started smoking and I need to replace it as it's quite crispy all over :(.
/ any toro groundsmaster fans on here? #1,025
Check on eBay.
/ any toro groundsmaster fans on here? #1,027
I did to no avail.
Thanks though.
The previous owner messed up the wiring and several of the connectors on our 220D.
I temporarily installed a toggle switch to shut off the lift pump. Otherwise it ran non-stop.
I've resigned myself to the fact, that if I want it right, I'm going to have to take a day and fix one wire at a time until it's right.
Luckily I have a running parts machine to copy the wiring harness. schematic.
They aren't quite the same. One is a 223D the other a 220D.
I never figured out the difference in schematics while looking at both schematics on separate sheets.
They're very similar.
/ any toro groundsmaster fans on here? #1,028
Howdy, has anyone tried to use a deck from a manufacturer other than Toro on their groundsmaster? Mine didn’t come with one and there is a front mower ford cm274 for sale locally cheap. It’s non running but does have a deck, brush, and snowblower. I’m in Kansas and I rarely see anyone selling just a deck in my vicinity.
/ any toro groundsmaster fans on here? #1,029
I think anything can be made to work. Just allow plenty of time and extra money!
/ any toro groundsmaster fans on here? #1,030
Not too familiar with either mower you mentioned, but in case they both have a mechanical PTO output, I would first check couple of basics like PTO rotation direction of Ford CM274 vs. your Grounds Master?
Also the lift capacity of your Toro vs. the Ford deck weight etc.
Some cutting & welding will likely be required to make the lift arms fit.
UNKNOWN TANK MANIFOLD (A58214)
UNKNOWN TANK...
2015 PETERBILT 367 WINCH TRUCK (A60736)
2015 PETERBILT 367...
2019 PJ  40FT GOOSENECK TRAILER (A58214)
2019 PJ 40FT...
Land Pride RCR1260 (A53317)
Land Pride RCR1260...
1999 John Deere 7810 (A60462)
1999 John Deere...
2012 HEIL (A60736)
2012 HEIL (A60736)
