Snow Can a 25 hp MT 225s handle a 6ft blade?
/ Can a 25 hp MT 225s handle a 6ft blade? #1
lsgreg
LS MT225S
I am looking at a used snowplow for my LS MT 225s. The blade comes in two widths, 5ft and 6ft, and it designed for "25 to 40 hp" tractors. It will be used to plow a long gravel driveway.
The used one I am looking at is the 6ft width. Frankly, I would rather have the 5ft blade, but it is used, and that is what it is. The price is excellent, so I am tempted.
Looking for opinions - would the 25hp LS MT225s handle a 6ft (400lb) blade OK through maybe 6 (occasionally 8) inches of snow?
/ Can a 25 hp MT 225s handle a 6ft blade? #2
The 5' blade would be the safe bet, but really there are so many variables when it comes to snow the 6' may work well also.
A somewhat dry snow would be no problem, but a wet slushy 8" snow may be an issue. If the deal is good, I would go with the 6' blade... you could always cut it down to 5' later.
JMHO
/ Can a 25 hp MT 225s handle a 6ft blade? #3
It depends on the snow and the slope. If you're pushing downhill, you might be ok. Dry and fluffy snow, you will likely be ok. Wet snow, you will need more weight and power to push it.
If its a good deal, get it and try it. You won't hurt anything, and if you find you cannot push with it, then you can always sell it.
/ Can a 25 hp MT 225s handle a 6ft blade? #4
If you don't already have chains, invest in chains. They will certainly help.
Thanks for all the above.
I will certainly have chains.
It is a very good deal, I will likely buy it, if the seller would return my calls :mad:
Wow, I didn't think of that! Thanks.
Well, I bought it. $950, barely used, no signs of wear, just paint rubbed off.
/ Can a 25 hp MT 225s handle a 6ft blade? #7
Thats a pretty good price! A quick google search shows used ones going for about $3k! CONGRATS! 🄳
Yes, I was seeing them for $2500+ used.
/ Can a 25 hp MT 225s handle a 6ft blade? #10
I have a Western 6’ 8ā€ that I adapted to fit on my Branson 2400H which is 24 HP and around 2200 - 2500 lbs. like others said wet snow is a challenge but the extra width at full angle clears a path wider than the tractor. Not sure if a 5 foot would do that.
Triple Sink Table (A60352)
Triple Sink Table...
2015 FREIGHTLINER CASCADIA 6x4 T/A DAY CAB TRUCK TRACTOR (A59906)
2015 FREIGHTLINER...
2004 TRAVIS BODY & TRAILER ALUMINUM BELLY DUMP (A58214)
2004 TRAVIS BODY &...
2014 Magnum 7696BLA Light Tower (A59213)
2014 Magnum...
2002 CHEVROLET 3500 FLATBED TRUCK (A60430)
2002 CHEVROLET...
2021 CATERPILLAR 289D3 SKID STEER (A62129)
2021 CATERPILLAR...
