CK3520 CEL Fault Codes
/ CK3520 CEL Fault Codes #1
Long Roof
Pekin IL
Kubota BX24, Kubota G2160, Kioti CK3520
I have a Kioti CK3520 that just turned 50 hours and today the CEL light came on and the following was displayed.
dtc
8241
F22
8241
F01
END
I am going to try to get to the dealer tomorrow but was wondering if anybody can give me a heads up on what all this means. The Owners Manual was not much help. It seemed to be running fine, almost didn't notice the fault code display.
Thanks in advance
/ CK3520 CEL Fault Codes #2
Found this on the service manual:
Could be as simple as some wires that could've gotten pulled out or a plug not fully seated, maybe corrosion on the pins, or bad sensor.
/ CK3520 CEL Fault Codes #3
Most likely Dealer prep/assembly. My CK2610 with 350+ hours has been flawless except for the dealer's involvement that was apparent in the first <25 hours. Dealer support was :poop:. Fixed most at my time and expense.
Patrick
ptsg, I see the "8241" in your reference to the service manual. What do the F01 and F22 codes mean? I am new to the Kioti and trying to learn this as I go. Are these codes supposed to be useful to the dealer only or to the end user? I thought I could fine a list of the F codes somewhere but came up empty.
34Willys, I agree on the dealer prep/assembly. They missed several things on mine too, mostly minor but should have been caught none the less.
/ CK3520 CEL Fault Codes #5
Sorry, should've post the entire page. Would have made more sense. The F01 and F22 correspond to that FMI column. I would say it's just different protocols to identify an error.
I stopped by the dealer yesterday and they verified it is a DPF sensor issue. I made an appointment for them to come and get the tractor. In the mean time, they told me is would not be an problem to use the tractor until the sensor issue is fixed. I used the tractor last night and all of the fault codes were gone. I have some small tractor projects this weekend an will see if the codes reappear.
/ CK3520 CEL Fault Codes #7
I suspect it will only throw the code if it decides to start the regen process. Those codes do disable the regen accordingly to the chart so it'll be a matter of time till is throws the code again.
/ CK3520 CEL Fault Codes #8
I know this is a few months old but thought I would share my experience with these exact codes on my 2023 NS4710. I asked the dealer about them and said I had seen on here that they may be a fault with the DPF temp sensor. The dealer told me that the fuel filter was probably causing the issue. Basically the fuel filter clogging was starving the machine of fuel during the regen cycle and not running hot enough. This would cause the temp sensor to kick it out of regen. After changing the filter and forcing a manual regen, the codes went away and haven’t come back.
/ CK3520 CEL Fault Codes #9
Thank you for providing this info. I'm sure this will help other people in the future and it's cheaper that throwing the parts cannon at it.
/ CK3520 CEL Fault Codes #10
Can you post more codes. I have the following codes and the machine runs super rich.
8194 f28
4097 f25
9263 f28
/ CK3520 CEL Fault Codes #11
8194 f28
4097 f25
9263 f28
4097:
8194:
9263:
You have a severely clogged DPF. May need the dealer to do a forced regen on it.
UNUSED KJ 20'X12' LIVESTOCK METAL SHED (A62131)
UNUSED KJ 20'X12'...
2012 John Deere 1990 Planter (A63109)
2012 John Deere...
2025 Pabreak Auger Bits and Plate Skid Steer Attachment (A61567)
2025 Pabreak Auger...
Cummins 6-Cylinder Diesel Engine with Transmission (A59230)
Cummins 6-Cylinder...
2019 Cadillac Sayers and Scovill 70IN Limo w Only 7729 Miles (A63118)
2019 Cadillac...
Decorative Alligator Statue (A61569)
Decorative...
