Thread sealants on NPT and others?
   / Thread sealants on NPT and others? #21
I do as well but I never wrap the tape over the last 1/16" of the threads.
yep.....it's for tapered threads......just about "ONLY" for sealing tapered threads.
Pay attention to keep it out of servo valves, and understand that it causes trouble on the internets.
   / Thread sealants on NPT and others? #22
I will defer to Parker on this, I know that they have done testing to determine the best way to seal fittings.
This is what they state for O-ring Boss. R4
Inspect components to ensure that male and female port threads and sealing surfaces are free of burrs, nicks, and scratches, or any foreign material.
2. If O-ring or seal is not pre-installed to fitting male port end, install proper size O-ring or seal, taking care not to damage it.
3. Lubricate O-ring with light coating of system fluid or a compatible lubricant to help the O-ring slide past the port entrance corner and avoid damaging it.
4. Screw fitting into port and tighten to proper torque from the appropriate table located on pages R5 - R6
Below is for JIC R26
Torque Method
With proper tube fl are alignment with the nose of the fitting, tighten the nut to appropriate torque value in Table R23. This method is fast and accurate when preset torque wrenches are used. Consistent component selection is recommended so that the effects of dissimilar plating is not an adverse factor in joint integrity. This makes it desirable for high production assembly lines. However, a joint assembled using the torque method
can only be checked for proper tightening by torquing it again.
Note: This method should not be used if the type of plating on the fitting and mating parts (sleeve + nut or hose swivel) is not known. The torque method should not be used for lubricated or oily parts as improper clamping forces may result. Over-tightening and fitting damage may occur as a result
All straight thread fittings have this note.
Assembly Torque: Torque values are for unlubricated carbon steel components and properly lubricated stainless steel components. All stainless steel Triple-Lok tube nuts have an anti-seize lubricant to prevent galling during assembly.
No additional lubricant is needed unless the tube nuts are washed or heated above 150ºF. Stainless steel fittings use the upper limit of torque range
Pipe Thread R7
The proper method of assembling tapered threaded connectors is to assemble them finger tight and then wrench tighten further to the specified number of turns from finger tight (T.F.F.T.) given in Table R5. The following assembly procedure is recommended to minimize the risk of leakage and/or damage to components.
1. Inspect components to ensure that male and female port threads and sealing surfaces are free of burrs, nicks, scratches, or any foreign material.
2. Apply sealant/lubricant to male pipe threads if not pre- applied. For stainless steel fittings, the use of Parker Threadmate sealant/lubricant is strongly recommended.
(Pre-applied dry sealants are preferred over other sealants). With any sealant, the first one to two threads should be left uncovered to avoid system contamination.
If PTFE tape is used it should be wrapped 1-1/2 to 2 turns in clockwise direction when viewed from the pipe thread end.
Caution: More than two turns of tape may cause distortion or cracking of the port.
3. Screw the connector into the port to the finger tight position.
4. Wrench tighten the connector to the appropriate T.F.F.T. values shown in Table R5, making sure that the tube end of a shaped connector is aligned to receive the incoming tube or hose assembly. Never back off (loosen) pipe threaded connectors to achieve alignment.
5. If leakage persists after following the above steps, check for damaged threads and total number of threads engaged.
I was surprised about the comment for tape so I looked for another reference.
Rhino Ag in reference to installing hoses on a loader.
Apply sealant only to all tapered threads unless coupled with swivel adapters. When using Teflon tape, wrap tape clockwise (as viewed from end) and wrap only twice. Keep sealant away from first two threads of tapered end to prevent contamination of hydraulic fluid. Do not use sealant on O-ring or flare adapter threads.
Based off what the manufactures state we should be assembling straight thread fittings dry and using pipe dope or tape on tapered threads. I was surprised that tape is an approved method of sealing. The folks at parker know more about sealing threads than almost anyone on the forum and have spent thousands testing the best methods. Feel free to link to reliable sources that state otherwise. The tape for tapered threads was new to me and I have been advising clients that tape was evil for years....
I see tape as safe until it has to be taken apart.
I don't know that I have ever seen a tapes joint, that didn't have tape residue inside the fittings on disassembly.
I can see how the tape residue could easily get in the oil upon reassembly.
It's very hard to make sure every little bit is removed.
This leads me to be anti tape for those types of fittings.
   / Thread sealants on NPT and others? #23
jrsavoie your points are good.
Some items, the tape is of no concern. For example a simple gearbox.
But in some hydraulics circuits, cleanliness is crucial.
And when you see tape on a machine,,,,
and a crucial function is behaving like there is contamination,
to suspect the tape is logical.
But excess liquid sealant can shed residue into the system as well.
   / Thread sealants on NPT and others? #24
If you use Teflon Tape, use the Yellow tape intended for gas and fuels. The white and pink will break down when exposed to hydrocarbons, including hydraulic and motor oils.
I don’t know that there’s a “right” answer with NPT. Pipe threads seal by deforming the threads EVER so slightly … Teflon tape actually functions as a lubricant more than as a sealant. Reducing friction between threads to achieve the right torque.
There is certainly a right answer with JIC and O-ring fittings. The seal is created by
-the two tapers coming together in the male and female (JIC)
-or the o-ring being squished “just enough” in O-ring boss or face seal
In either, the threads are just there to clamp. Threads hold the connection mechanically but there is no sealing done at threads.
If you THINK glopping stuff on threads in such instances “helps”… it’s at best a band aid for a damaged fitting or cut oring that needs replaced. If fluid is even GETTING to the threads when tight, you got bigger problems, and spackling over the threads isn’t a proper repair. Or safe.
If you’re worried about fittings coming loose, you don’t have a loctite issue, you have a torque issue. Or you have a hose installed with a twist in it that’s trying to loosen your connection under vibration or whatever
My only thought to "sealants" on non NPT fittings is not to seal but to prevent or reduce corrosion on the threaded, non sealing, parts. I've had a hard time removing some that lived out in the weather for years.
I'd never use anything other than hydraulic fluid on oring/mating surface or JIC mating surfaces.
   / Thread sealants on NPT and others? #26
For NPT fittings I've always just used some sort of PTFE pipe dope. Right or wrong I was told that the dope or tape on NPT fittings was basically just a lube to allow you to get the fitting tight enough to seal. I was also told that dope will dissolve in a hydraulic system. I just took it that the info was correct? I have used teflon tape on a black pipe fitting because I had it handy. It leaked and I tightened it for all I was worth and could not get it to quit. Found some dope, pulled the fitting apart, pulled the tape and added dope, re-assembled and no more leak.
   / Thread sealants on NPT and others? #27
I mostly agree. If someone is sloppy applying ptfe tape, causing issues, they’re the type of person who would also apply another sealant/lubricant sloppily too. I’ve seen sloppy applications of joint paste compounds that caused internal damage to parts of machines.
Good high pressure designs don’t employ NPT anyway, so it shouldn’t be a factor.
When someone learns how to properly apply teflon tape on low pressure NPT threads , it’s an easy, reliable, repeatable skill that someone can use thousands of times over a career, with great results
For what it's worth, when I first started working on my own tractor, "before I knew better", all the NPT joints I made up dry. Cleaned, but dry. Mainly because I did not see any sealant at all on the existing fitting.
Always just "good'n'tight". Can't recall a leak. But it always kind of bothered me, so embarked on a journey to "educated myself".
   / Thread sealants on NPT and others? #29
Actually NOT quite true........ Yellow PTFE tape is for Natural Gas and Propane lines, not fuel/oils ...
   / Thread sealants on NPT and others? #30
Good post. Only NPT (tapered pipe) receives a thread sealant, as it has a spiral leak path formed by the flattened crest and filleted root of the thread. The sealant (tape or dope) is designed to fill this spiral leak path.
NPTF is a special variant of NPT, and can sometimes mate without leaking, as the crest and root are better matched to eliminate the classic NPT spiral leak path. But even there, sealant is recommended to provide sufficient lubrication to draw the tapered threads tight.
All other fittings, such as JIC, ORFS, and ORB, do not get thread sealant. The thread is not the sealing mechanism in these fittings, but rather only provides the mechanical clamping means, holding the two halves together around the o-ring or tapered cone seal. Using thread sealant on these fittings is more likely to cause, than to resolve, any problems.
As to tape versus dope, both work equally well, when used properly. The reason "tape is evil", is because it takes more skill to properly apply it, and so many do it wrong. Any idiot can slather dope on a fitting, and so it's become the preferred method, for most.
   / Thread sealants on NPT and others? #31
Teflon can and will get into the hydraulic system and clog valves and such. I have personaly pulled it out of places it shouldnt be.
Only when wrapping the fitting incorrectly. When wrapping a fitting with tape, you are supposed to keep it off the first thread completely, for precisely this reason.
Tape is also less likely to find its way into the system than dried and hardened dope, upon disassembly.
   / Thread sealants on NPT and others? #32
Lots of old threads and various opinions, but would like to revisit. I've not done much but all the NPT I've done (Kubota B21 2000# nominal) have been "dry" and not leaked. But I gather that is not the norm.
Teflon tape seems to be on no ones "good idea" list.
Various other solutions, loc tite, 3 Bond, and others, seem to be favored. At least on NPT.
Some say to use nothing on JIC or oring boss. But I have found, taking stuff apart, that corrosion can be and issue on those, so maybe using a modest amount of low strength thread locker or non hardening sealer, just to keep water out, is not a bad idea, but just on the threads.
Let the games begin.
   / Thread sealants on NPT and others? #33
As to tape versus dope, both work equally well, when used properly. The reason "tape is evil", is because it takes more skill to properly apply it, and so many do it wrong. Any idiot can slather dope on a fitting, as so it's become the preferred method, for most.
I use Gasoila on almost everything. Good with gas and oil as the name implies and also is usable on plastic which Rectorseal is not. Good luck, Alec
   / Thread sealants on NPT and others? #34
By "everything", I hope you just mean NPT fittings for all fluids.
Rectorseal No.5 is listed for use on PVC, but not CPVC, or some other plastics.
Gasoila is good stuff, my local propane guys swear by it. It's becoming more popular, with more approved application range, whereas Rectorseal No.5 has been the standard for plumbers for many years.
For hydraulics, I use either tape or a specialty dope made Henkel.
   / Thread sealants on NPT and others? #36
Teflon Tape or Teflon in a tube has worked well here for about 40 years. Protects the threads as you note as well as seals. Enjoy your games... serious business here.
   / Thread sealants on NPT and others? #37
I use Blue Monster on everything
Same here. I keep a bottle of Blue Monster thread sealant and role of Blue Monster tape on hand since they're suitable for use with many types of fluids/gases -- and all the ones I work on around my property (which largely eliminated the need to keep multiple different rolls of tape around -or to track what is compatible with what for the existing stuff I work on).
I've yet to have issues by following the instructions for use posted above for using tapes - and the Blue Monster tape seems to hold together better than other tapes I've used if/when you need to dissemble a fitting shortly after assembly. So I suspect that will be the case even after a few years (kind of doubting any of them would get better at holding together during disassembly with age).
   / Thread sealants on NPT and others? #38
I’ll throw in my 2 cents, backed by about 10 years of real world experience and actual real world testing. I designed and installed commercial and hospital systems that dealt with sterilant, which back in the day used a high percentage of Freon 12 as a carrier gas. We reclaimed the Freon so our piping systems had to deal it both in liquid and gas form. Every system had to have each joint tested with a gas Freon detector, at parts per million. Before we put anything in service, we put in some gaseous Freon 12 and believe me, it could find a leak. Our systems were primarily threaded NPT brass, 1/2 to 2”. We also used stainless npt, which can be very tough to seal for a gas.
Loctite Hydraulic (red) worked reliably! I think today it’s called 545, but I’m not certain. I still have my bottle from 25 years ago, a little goes a long way. Basically the RED was the ticket!
We also tried Loctite Pneumatic/hydraulic sealant, purple. While it worked good, we found it did not work as well as the red Hydraulic sealant, in our challenging applications.
When using either, I recall you must have clean threads, clean of cutting oils etc. I think they used to sell a primer, but just make sure you have clean threads. I doubt many will be cutting your own threads as we did.
I still use teflon tape and especially good teflon paste. However, The hydraulic sealant will give you an excellent seal, without the mess of a teflon paste or risk of tape in your system. One local and very major corporation here, that you’ve all heard of, banned teflon tape in their huge complex. They just had too many issues with folks overapplying it and getting into critical systems.
Loctite Hydraulic sealant was never cheap, but you don’t need much and that bottle will last the average guy a long time.
   / Thread sealants on NPT and others? #39
In my experience, Loctite 545 does a great job...if the fitting is new or at least has only ever had a pipe sealant on it but never had PTFE tape. If a connection previously had PTFE tape, the person probably "did it wrong", meaning they both wrapped it more than 2x max and cranked it down as tight as they could, a combination guaranteed to deform (if not split) the nut end. Loctite doesn't work well if the nut is deformed. So in those cases you're going to have to use PTFE tape again or it will leak/weep.
   / Thread sealants on NPT and others? #40
I had the experience of Industrial Engineering at our plant getting the idea they could save time and money by switching from Loctite 545 to Teflon tape installing the single pipe thread port we had on a new model, the exit from the tank to pump inlet. To us, any leak was considered a failure, part of our measure for Dealer Repair Frequency. Our pre-production fleet began having leak problems from the HMU (hand metering unit or steering control). We kept having to have HMU's replaced on our test fleet, drove us crazy. But nice to have resources so we sent some units to test lab at HQ for analysis. Through high magnification, they found small narrow pieces of material between the seal lip and shaft. Spectrometry proved it to be Teflon, specifically Teflon fibers like in Teflon tape. Back to the assembly line to investigate how Teflon tape got in our plant and discover the root of our problem was a cost reduction by Industrial Engineering. The worst thing is getting that stuff out of a contaminated system. In our case no solution - following our evaluation sell the machines with the customers knowing there will be an oil weep (price discounted accordingly).
2024 CATERPILLAR 255 SKID STEER (A60429)
2024 CATERPILLAR...
2012 DRAGON 130BBL VAC TRAILER (A58214)
2012 DRAGON 130BBL...
DEUTZ MARATHON...
Gleaner N630 Corn Head (Allis Chalmer Branded) (A56438)
Gleaner N630 Corn...
Crown RM6025-45 4,500 LB Stand-On Electric Forklift (A59228)
Crown RM6025-45...
2014 Ford F-250 4x4 Ext. Cab Pickup Truck (A59230)
2014 Ford F-250...
