Briggs and Statton Backfires through carb
/ Briggs and Statton Backfires through carb
I have pressed it back in and put Loctite on the guide, but I don't feel fuss warm about that. I could take it to a machine shop, but they would probably charge almost as much as a new head. I saw online a guy that said he welded his in I'm not that good of a welder that I would attempt that. Still open for suggestions. I might put it together just to check the running and if everything works ok go ahead and get a new head. This lawn tractor is 18 yrs. old.
Loctite needs some space to work. If the guide fits the hole with with no space between the guide and the head when the guide is pressed in the Loctite will just be wiped off. You could file a groove for the Loctite in the guide and then press the guide in. The groove needs to be only a few thousandths deep. The green (#609? I forget) Loctite for cylindrical parts loses its hold completely at about 450 degrees F. It does start to weaken at about 400 degrees.
Eric
Yes, I tried the Loctite and it just wipes off. I wish I had a way to put a slight knurl on it that would slightly expand it.
/ Briggs and Statton Backfires through carb #23
A knurl would result in high spots that are sharp. These would file the metal the guide gets pressed into. Cutting a very shallow spiral in the guide on a lathe will guarantee success. You will need to identify the portion of the guide that will be fully enclosed in the head and have a machine shop cut a thread solely within that portion. -- I have a lathe and did this on mine. As I recall I used a 0.040" parting tool and cut a ~4 thread/inch flat bottomed spiral about 0.002" deep. I turned the lathe by hand to have good limit control. Assembled with loctite and no more problem.
Good luck!
/ Briggs and Statton Backfires through carb #25
Would a heavy duty snap punch work, once you get everything back into it,s proper place ?
/ Briggs and Statton Backfires through carb #26
Im not sure that the guides are ductile. They may be cast iron.
/ Briggs and Statton Backfires through carb #28
There steel
Could be, but valves are definitely steel, and steel on steel is not a good sliding bearing combination. Thats why I think the guides are cast iron.
/ Briggs and Statton Backfires through carb #30
You can put grooves in the guide with a demel tool, use a high temperature loctite product making sure all is perfectly clean
Also if you have access from the outside you can drill & tap for a set screw
Thank you for the info
/ Briggs and Statton Backfires through carb #32
When checking valves make sure the intake valve is not (still) stuck. If it is stuck and rod not bent, then you adjust the lash it will try to push the valve farther than it will go and bend the rod.
/ Briggs and Statton Backfires through carb #33
Breezing through here it looks like you rather take a stab at a fix here to hold the guide rather than go through the expense and trouble of pulling this apart. I did see where you brought up welding. All that is really necessary here is to create a raised spot so it won't pull through one way or another. That shouldn't take much. Or maybe draw the guide out if you can, do a quick knurl job, maybe lightly peen the bore and reset it.
Thanks for the info. I don't have the tools for knurling so I'm thinking of tapping and install a set screw. I'll either fix it or break it all together.
I drilled through the side put a set screw in. Hopefully it holds. Thanks everyone for your help.
/ Briggs and Statton Backfires through carb #36
Eng starts and runs great. Time will tell if my repair will work.
INOP/NON-RUNNING 1957 B61 Mack (A65563)
INOP/NON-RUNNING...
26 ft trailer 20 ft bed (A61567)
26 ft trailer 20...
Carryall 1700 4x4 (A61574)
Carryall 1700 4x4...
1999 Volvo Manure Truck (A62613)
1999 Volvo Manure...
2019 KENWORTH T680 T/A 6X4 SLEEPER TRUCK TRACTOR (A59910)
2019 KENWORTH T680...
2022 EZ-GO ELITE...
