Trying to mount a York rake to a Kubota bucket. Any bucket to 3 point adaptors?
   / Trying to mount a York rake to a Kubota bucket. Any bucket to 3 point adaptors? #1
stoic
stoic666
Hello,
Does anyone know of a way to get a 3 point hitch adaptor of some sort mounted to this bucket? Do they even exist? Before I start welding and drilling a bunch of nonsense to make this work, I wanted to make sure there's not some kit that'll attach to the bucket. I have a JD2155 for the rake, but if I could have more control of this and get it hooked up to this Kubota, I'd get a lot more done. Thank you to anyone for any help or advice.
   / Trying to mount a York rake to a Kubota bucket. Any bucket to 3 point adaptors? #2
Never seen anything for a bucket mount but they do make SSQA to 3 point adapters;
And I built one by welding a quick hitch to a SSQA plate.
It works to move equipment around, it doesn't work very well for working with 3 point attachments as they are so far from the axle that dips and rises move the attachment up down to much.
   / Trying to mount a York rake to a Kubota bucket. Any bucket to 3 point adaptors? #3
Even when in the floating position? I'm on the fence on getting one myself.
   / Trying to mount a York rake to a Kubota bucket. Any bucket to 3 point adaptors? #4
I started a project but life came along and it's been stalled. It'll be a QA frame that with adaptive mounting for 3-point stuff (rake will be first). I have a fence row that needs cleaned out.
Mounting the rake to a bucket would be a cinch. Two pieces of angle bolted to the inside bottom of the bucket and something at the top for the top link and you're off to the races. It may not be quick on and off if you need to bolt and unbolt one of the angles but it'd be simple.
   / Trying to mount a York rake to a Kubota bucket. Any bucket to 3 point adaptors? #5
Mine is a heavy loader and I tried it using a york rake and it was terrible, in float it had so much more weight then the 3 point does.
   / Trying to mount a York rake to a Kubota bucket. Any bucket to 3 point adaptors? #6
I was all ready to pull the trigger on one until i read your post. I was going to use a landscape rake on the front and back drag stuff when i have the backhoe on. Now I'm rethinking it.
   / Trying to mount a York rake to a Kubota bucket. Any bucket to 3 point adaptors? #7
I've seen those front mounts and turned around so they are a pusher. Easier to see what you are doing.
I'm not going to be using the bucket mount for big areas. I have a John Deere for that. I have a marina and need to get in tight spots to get weeds down. Tough to do backing up with the JD and the herky jerky movement. When I get this mounted on the bucket, I'm home free. I've come up with an idea about how to do this with welding on to the rake itself. I don't want to weld a ton inside my bucket. I'm always loading cinder blocks and what not in there and I need inside the bucket flat.
Thank you to all for the replies. I really appreciate it.
Bush Hog 72in Rotary Brush Cutter Tractor Attachment (A55852)
Bush Hog 72in...
TEST YOUR BID BUTTON! (A58374)
TEST YOUR BID...
New/Unused 14ft Bi Parting Gate (A57454)
New/Unused 14ft Bi...
MASSEY FERGUSON 39 - 2R FLEX PLANTER (A52708)
MASSEY FERGUSON 39...
TANK MANIFOLD (A58216)
(2) HD ALUMINUM RIMS (A58374)
(2) HD ALUMINUM...
