Rotary cutter gearbox
/ Rotary cutter gearbox #1
fishfrank
Member
The gearbox on my rotary cutter came from the dealer filled with grease instead of gear oil. When you take out the check plug you just see grease. It’s now 10 years old and I’m wondering if this should ever be changed and if so how? Also how do I know if it has enough now? Like I said, you open it and just see grease.
It’s an Ag-Meier Bronco 6 ft. The owners manual class for 80w-90 oil but it is most definately filled with grease
/ Rotary cutter gearbox #5
I can’t imagine that grease should be used in that gearbox. That being said, it apparently came with grease from the dealer and has lasted 10 years. Seems to be ok. Not sure how you could change it anyway, without total disassembly and reassembly.
/ Rotary cutter gearbox #7
Some rotary cutters use corn head grease, or NLGI grade 0 (zero) grease.
Check this thread: grease in a rotary cutter gear box?
My cutter uses the grease, and that's what is specified in the owner's manual. But I couldn't find a source for the grease - no one around here carried it. So I called the cutter manufacturer for advice and they told me if no NLGI Grade 0 grease is available then just use the heaviest gear oil you can find. Been running that mower for 25 years now; no leaks and no problems with the gearbox.
/ Rotary cutter gearbox #8
the rhino tech recommended the same, GL5 85/140 as replacement to their factory grease. if your gearbox doesn't heat up excessively during use, i'd say the lubricant is doing it's job
personally, i'd have no problems converting to the above hypoid gear oil, but the OP will have to make up his own mind. many would say just leave it...but i certainly would not disassemble the gearbox if you do change as one poster recommended. let us know what you decide
/ Rotary cutter gearbox #10
I’m going to try that. Good idea
you might inquire to the manufacturer if their factory grease product is compatible w/GL5 type hypoids, bet it is... i'm not suggesting change, that's your choice, but just to know, regards
/ Rotary cutter gearbox #11
Was it new from the dealer or used? I watched a Tractor Mike video where he said he's seen guys pack an old gearbox that might have been leaking or worn with grease to get more life out of it.
Apparently it is a thing and works, as you are now testifying also.
It came new from the dealer like this. Quite a bit of time passed before I checked it and saw that it was grease. Now 10 years have passed and it just made me curious. I’m going to do some mowing today and check to see what it looks like immediately after use.
/ Rotary cutter gearbox #13
I don't have anything to add to your specific situation, but if I had a gearbox that was leaking (with 80/90 oil), I would add a little cornhead grease. grease, or straight STP just to keep things full and "oily".
/ Rotary cutter gearbox #14
Some guys fill the gear box with grease because they have a leak and
grease don't leak out
willy
/ Rotary cutter gearbox #15
John Deere Corn Head Grease is the best solution for leaky seals. I put a green spot on the gear boxes with grease to remind myself.
No problems in 20 years.
/ Rotary cutter gearbox #16
/ Rotary cutter gearbox #17
I've been using corn head grease in gearboxes like that for over 25 years,no problem so far.You could always add a little gear oil to thin the grease if you wanted.New Holland for example originally used gear oil in their hay rake gearboxes but now say to use corn head grease.
/ Rotary cutter gearbox #18
Most John Deere dealers carry what they call "corn head grease." I bought mine online (ebay), and replaced the 85W90 oil in my Ironcraft cutter.
/ Rotary cutter gearbox #19
Its been covered on other threads here - people open their gearbox or chain/gear drive on roto-tillers only to find grease rather than oil. I can't quickly find threads but people got responses from suppliers that the book may say oil but they made the change to Type 0 grease (which is most commonly found as John Deere corn head grease) due to customers seeing oil seeping past seals. Type 0 grease is a popular solution to leaking - all the similar gearboxes of my farm equipment have been changed to grease and I keep a supply of the grease on hand. Remember, it has to be Type 0 or John Deere Corn Head Grease. There are equivalents from other manufacturers like AGCO but I can't identify them all.
/ Rotary cutter gearbox #20
00 corn head grease. It will remain a semi fluid and lube wwll without sneaking away through seals. I use it in all of my gearboxes and it is available in grease gun tubes from JD.
2020 CATERPILLAR 299D3 XE SKID STEER (A62129)
2020 CATERPILLAR...
2021 Takeuchi TL10V2-2 Track Loader with 76in Tooth Bucket (A63118)
2021 Takeuchi...
UNUSED KJ 14' EXPANDABLE SITE FENCE (A62131)
UNUSED KJ 14'...
2009 BMW Sedan (A61569)
2009 BMW Sedan...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A63118)
PENDING SELLER...
UNUSED RAYTREE RMSG29 HYD STUMP GRINDER (A62131)
UNUSED RAYTREE...
