ericm979
Super Member
I think one advantage to roof mount panels in the summer anyhow is that the panels shade part of the roof.
What does your 10kw system produce through out the year? What's January production? May? And maybe July to give me an ideaConsider also that while a panel may be, for example, a 350W panel, you may or may not spec the inverters (microinverters these days) to the same maximum.
I have 10kW of DC (panel maximum output) but my microinverters will put out a maximum of 7.68kW AC. The microinverters will unlikely degrade at the same rate as the panels, and the panels will only put out their rated maxima at very specific conditions (angle of incidence of the rays, temperature) and it was explained to me that while I could potentially end up with a few more AC watts in the first few years of operation, the extra cost for higher output microinverters would never come close to being paid off.
In other words - don't think your 10kW of panels all added up together will give you 10kW.
I was also concerned about putting panels on my roof: 1, my roof wasn't exactly new, but it wasn't old enough to require a re-roof yet; 2, my roof hip is aligned N-S and I couldn't easily tilt panels at all toward the south; 3, some shading of the roof.
Due to setbacks here, my 8ac of land had a 50'x50' region that allowed new "structures" to be placed on it (we have to be 100' away from water, 30' from property lines, and other places have bad shade in the mid to later afternoon). I'd imagine I could've gotten a variance because a solar ground mount isn't particularly polluting to water features (meanwhile I can plow and run cattle right next to the pond and irrigation canal but I can't put concrete into the ground?) but I went with the easy spot because it really had the best sun. Still, it was a 550' cable run from the panel mount to my service entrance; the trench and the cable added to the mount itself weren't particularly cheap, but I can also clean my panels from the ground; I'm still a proponent of the ground mount (plus I intend to add 50% more on another ground mount next to it if I need to).
Ours is a smaller system, with less than perfect orientation.What does your 10kw system produce through out the year? What's January production? May? And maybe July to give me an idea
What latitude?
What is your system size? And what latitude?Ours is a smaller system, with less than perfect orientation.
Dec/Jan is about 20% of June. If we were to pull the angle of the panels from about 20 degrees up to about 30-35 degrees, the winter production rises to about 40% of the summer production, though the summer production would take a 10% or so hit, per PVWatts. That's the plan for the next array.
All the best,
Peter
7.6kW DC, 6.9kW maximum typical production due to orientation, roof planes, etc.What is your system size? And what latitude?
