Moving a "modular building"
/ Moving a "modular building" #1
joea99
Marbletown NY
Kubota B21, JD 240GT
This may not be the right place to post this, but, here goes.
A fellow about 10 miles from me (zip code 12484, near Kingston NY) is offering a "modular building" 24x30 for sale, but has no means to move it. He did provide the number of a fellow, with no opinion as to his ability, that does this for a living. Apparently. So far, no response from him at all.
The building, from photos, seems to be a typical, for this area, ""Amish built" shed/garage, in that is is on 4x4 skids with a plywood floor. It bolts together length wise, in 12x30 sections. I've not bothered to go look yet as I wanted an idea of the moving costs before going any further. That alone may make it unworkable.
The local shed companies seem to want to only move what they originally sold and I've been unable to find anyone that advertises such services. Some "house movers" but so far away as to be unlikely to be reasonable in costs.
/ Moving a "modular building" #2
If you don't mind dismantling it you may be able to connect with somebody with a hay trailer. You can't readily put a twelve foot wide piece on the highway but if you can secure it vertically it should be a go.
/ Moving a "modular building" #3
I would think it was assembled by joining the 2 sections together in the middle, so it should be easy to get it apart again. I would ask the seller if he knows who delivered it to him initially, and see if you could get in touch with them. I have an Amish shed, and it was put together with screws, which makes it very easy to dis-assemble it into managable size pieces , and move it on a small flatbed trailer.
/ Moving a "modular building" #4
I have never done it, but I have seen it done more than a few times, both multistory modular homes and offices, and I would only let a pro with insurance do it. It is all too easy to jostle a segment and do serious damage.
I would expect that the building would be close to free, or being paid to take it. 12' wide is fully permitted oversized load territory.
All the best,
Peter
/ Moving a "modular building" #5
Any mobile home outfit should be able to stuff axles under it and get the wide load permit.
/ Moving a "modular building" #6
24 feet, as somebody already pointed out it was probably delivered in two 12' wide sections.
/ Moving a "modular building" #7
15 years ago I spent 5 years inspecting the manufacture, transport and erection of 100s of modular units from simple storage buildings to fancy offices and living quarters.
A true transportable modular; each unit has a steel frame under each unit, frame has hangers for set up for installation of one or more axles (depending on weight), and are highway transportable that way. The one in question would be two 12' X 30' modules connected along the 30' length after setting on pier blocks or permanent concrete foundation.
The OPs description doe not include the interior finishes that could increase the access to the connectors.
Believe me this is not a DIY project. It takes specialized knowledge and equipment to disassemble install axels, move, reset and repair finishes. Modular buildings are designed to be relocated but it probably costs 3 times as much to relocate as it did to set the first time.
OP needs to find a company that makes a business of servicing modular dealers for these functions. LOL
Ron
/ Moving a "modular building" #8
Hey! A bit off topic but would like to ask. I'm moving shortly to my new house and have a lot of stuff to move, plus my garage is full. What lifehacks can you offer me?
/ Moving a "modular building" #9
How are you moving your tractor?
/ Moving a "modular building" #10
The local shed companies seem to want to only move what they originally sold and I've been unable to find anyone that advertises such services. Some "house movers" but so far away as to be unlikely to be reasonable in costs. 새해 혜택이 왔습니다! 알리익스프레스에서는 설날 연휴를 맞아 2월 동안 특별 할인 행사를 진행하고 있습니다. 이번 행사에서는 알리 프로모션코드를 사용하여 기존 상품 가격에서 최대 50%까지 할인 받을 수 있는 기회가 주어지니, 명절에 맞춰 적절하게 활용해 보세요.
It seems since housing prices have gotten so expensive, I see people trying different ideas to own a home. One example is they purchase a modular building that used to be a classroom or an office and convert it into a house. The final cost is well below what you can build a traditional house for. The building is solid and built to the same standards of a stick built dwelling. (not a HUD home like a mobile home) It's already plumbed and wired too. Is this a wise investment? What about resale in the future?
/ Moving a "modular building" #11
Rent a dumpster and park it so you have to carry stuff past it to the truck. Anybody who helps you move gets dumpster diving privileges.
2024 CASE TV370B SKID STEER (A65053)
2024 CASE TV370B...
Westerns 8.5 Pro Plus w/Quad, Ultra Mount 2 (A62679)
Westerns 8.5 Pro...
2022 DEMCO KARKADDY X 9713093 CAR DOLLY (A64277)
2022 DEMCO...
Skid Steer Pile Hammer (A65640)
Skid Steer Pile...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
New/Unused Wolverine 72in Tiller (A65583)
New/Unused...
