Sub Compact or Compact for my needs
/ Sub Compact or Compact for my needs #1
BrewWizzard
Craftsman(garden tractor but looking for compact)
**** Edit **** I’ve decided to go with CUT instead of SCUT
I recently went to the local Kioti dealer and looked at a CX 2510. I have an an unusual , but small lot with a seasonal creek and a lot of sagebrush and Bitterbrush on it that I need to remove. I also need to flatten some areas remove some Willows and a few other tasks like moving gravel around.
There is also need for some tight space maneuvering for crushed rock near the house so my concerns are getting a smaller tractor or a compact one like the CX 2510.
It’s only a 1 acre a lot and I thought about renting, but the prices are so high for as much work as I want to do. I thought I would look into buying something and then selling it a few years down the road.
Anybody have any suggestions? Seems like a lot of people here are pretty knowledgeable and have some good experience.
/ Sub Compact or Compact for my needs #2
A subcompact will meet your needs. I, too, have the largest "garden tractor" that the Craftsman line had. There is a DRAMATIC difference when I got my first subcompact (LS MT125 tlb).
Did a lot of work: Installed full septic system, trenches for utilities, prepped the foundation, final grade, driveway, etc.... all with the SCUT.
it did have some limitations, but you can overcome them, it will just take a bit longer to do. I ended up selling the SCUT, and moving up to a CUT.
Same HP, just twice the size. It does what the SCUT does, just easier (more lift capacity, better traction).
Unfortunately, I do really miss having the small SCUT, it got into places that the CUT can't get to. I have been actually looking to get another SCUT.
IMHO, go with the subcompact. I believe you will be able to do what you need and be able to manage 1 acre with a subcompact (SCUT).
I absolutely agree in terms of capabilites except for “Ground clearance” and easier rolling in very uneven ground. Have you used it in very uneven ground? And how does the LS MT125 compare to the CS2110 in terms of tire sizes and ground clearance?
/ Sub Compact or Compact for my needs #4
Unless you need the smaller machine to fit your property I would choose the CX over the CS all day. So much more capable than the CS. For what its worth Im only on 1 acre right now (buying more property soon) but my CX has been great for my uses, was originally looking at sub compact but when I sat on the CX and compared it to the CS it was an easy decision. Of course again, your needs and limitations will dictate the size you will need.
/ Sub Compact or Compact for my needs #5
Try keep horsepower under ReGen limit,also if front loader power steering helpful.
I’m a newbie, so I don’t know what “ReGen limit” is. Can you explain, or direct me to more info?
Thanks
/ Sub Compact or Compact for my needs #7
Thanks
He's referring to the emissions systems on the larger HP engines. Stay at the 25 hp and under and it wont have emissions to worry about.
/ Sub Compact or Compact for my needs #8
My experience is with the Kubota line....but SCUT and CUT are probably about the same regardless of brand. I'd go with a 25 HP CUT even though you are on 1 acre.....because it sounds like your terrain is pretty rough....especially for leveling and brush removal. I'd guess that the difference between close space manuvering wouldn't be much different. Attachments for the 3 point and maybe for the FEL could also make some difference.
Cheers,
Mike
I’m pretty much sold staying with the larger (compact) one, after reviewing other posts. I should probably redirect this to a CX features post, or maybe Kubata comparison, as that’s the other nearby dealer.
My Kiota dealer had a CX2510 built with a hydrstatic trasmission. I’m not particularly fond of hydrostatics, and actually miss not having manual transmissions on my cars and trucks(yeah, I’m old). Is there a good reason not to get a manual transmission configured? Would save me a little.
/ Sub Compact or Compact for my needs #10
If you’re not doing mostly field work you will regret a manual in my opinion. I would hate a manual with my CX doing loader work or almost anything else for that matter. It’s not a sports car
/ Sub Compact or Compact for my needs #11
ditto what kozal said.....................
Cheers,
Mike
/ Sub Compact or Compact for my needs #12
The LS MT 122 and 125 have the same tire size and ground clearance as the CS 21 & 2510.
They are all very similar in specs. I did put 2 1/2" spacers all the way around. It "felt" much more stable for sure!
I should have said CX 2510. It has a way bigger front tire, a 10-16.5 which should mean a 30” diameter, and has 14.5” ground clearance. That’ll get me across the creek. The CS (subcompact) has the same front wheel size as my garden tractor, which is very small, and the ground clearance is about 6.5”. HUGE difference.
/ Sub Compact or Compact for my needs #14
DON'T BUY KIOTI, THEY DON'T HONOR THEIR WARRANTY!!!!
/ Sub Compact or Compact for my needs #15
Other than cost there’s zero reason to get a geared transmission on that size tractor. A HST is much more productive and easier to use. A gear trans will pull a disc across a field better than a HST but that’s about it.
/ Sub Compact or Compact for my needs #16
That front tire sounded a bit large for a 25HP tractor to me,
Tractor data shows this:
Kioti CX2510 Tires
Standard tires (ag)Front: 7.0-12. Rear: 11.2-16
Lawn/turf front23x8.5-12
Lawn/turf rear33x12.5-16.5
Industrial front23x8.5-12
Industrial rear12-16.5
If front tire size is important a Branson /TYM 2515 25 HP might be a better fit: also larger rear tires
Ag front8-16
Ag rear12.4-24
Industrial front28x8.50-15
Industrial rear43x16.00-20
Maybe a CK 2620 would work, it has a 7 - 16 front tire 11.2 - 24 rear AG's
You are right! I just took delivery yesterday. The front tire outer dameter is 23”. I had been looking at the CK 3XXX series at one point; probably confused them. Still, the CX tire diameter is bigger than the CS series.
TYM and many others are missing dealers in my area. Of course, there were plenty of ads on craigslist or Facebook, but all were actually in Arizona or Oregon or California.
Glad I bought local - my Kiota dealer’s wall is filled with awards. From the price, transaction, to the walk-around to how fast they delivered to making a special trip(35 m each way) the next morning because they forgot to give me the manuals was pretty impressive.
/ Sub Compact or Compact for my needs #18
Good deal, Glad you have a Quality Kioti dealer. Enjoy the new tractor and Congrats,
/ Sub Compact or Compact for my needs #20
Seen your posts. Why don’t you try suing your dealer rather than wasting time here.
Because nobody covers neglect and he’d just be throwing more money away with lawyers.
2005 JLG Skytrack 10054 10K Capacity Telehandler (A59213)
2005 JLG Skytrack...
UNUSED IRANCH MINI SEMI-AUTOMATIC QUICK CHANGER (A62131)
UNUSED IRANCH MINI...
UNUSED WOLVERINE TQH-26-01C 3PT. TRAILER MOVER (A62131)
UNUSED WOLVERINE...
2025 Pabreak 74in. Hydraulic Dual Cylinder 4-in-1 Bucket Skid Steer Attachment (A61567)
2025 Pabreak 74in...
5ft. Wooden Cowboy Statue (A61569)
5ft. Wooden Cowboy...
New/Unused 3 Point Ball/Flat Hitch (A61166)
New/Unused 3 Point...
