10 ft drag box scraper, 60 HP tractor and other discoveries (picture)
   / 10 ft drag box scraper, 60 HP tractor and other discoveries (picture) #11
Allen
Do you have any implements to loosen the ground first before using the box plane? I know may require hooking and unhooking implements or two tractors but would make moving dirt easier.
My Kubota M6040 has 775 pounds of RimGuard in each rear tire. I have no idea how I could get that much weight in cast wheel weights. Let alone get that much weight attached to the rims.
Nuff said..........
I have 315 pounds of cast weight on each wheel and few pounds of bolts and nuts holding it on. I'm probably going to make a trip next weekend to a dealer that sells RimGuard.
Allen
I do have a few implements. I have a cultivator that has 9 shanks on it that I use for things like this but as I said in my first post, those shanks aren't really meant for hard ripping. I've bent several of them. I also have a small tool bar with 3 shanks that can do the primary ripping. but I'd really like to find (or build) shanks that I can use on this blade. I have found several blades similar to this one but not close enough to the same to buy the shanks. And I still don't know who manufactured this blade. Sure gets expensive saving money.
   / 10 ft drag box scraper, 60 HP tractor and other discoveries (picture) #19
My Kubota as it is now set up with a HD Rhino rear blade - FEL & grapple - RimGuard in the rear tires - a tad over 10,000 pounds.
I have a Bush Hog roll over box blade - RO 720. It's 72 inches wide. If I take too deep a cut - I can bring the Kubota to a complete stop - all four wheels digging their own hole.
If I had a wider blade - just take a shallower cut.
However - a 120" box blade is a little big for the OP tractor for two reasons. Width and overall weight. I'm sure the operating manual for a M5740 recommends - 72 inches or less and something less than 1000 pounds for box blades.
2011 INTERNATIONAL DURASTAR 26FT NON CDL BOX TRUCK (A59904)
2011 INTERNATIONAL...
SHOP BUILT TOOL TRAILER (A58214)
SHOP BUILT TOOL...
Case 1020 25ft Draper Head (A56438)
Case 1020 25ft...
2017 Toyota Hybrid Camry Sedan (A59231)
2017 Toyota Hybrid...
2016 Chevrolet Sonic LS Hatchback (A56859)
2016 Chevrolet...
(INOP) 2016 CATERPILLAR 259D SKID STEER (A60429)
(INOP) 2016...
