10 ft drag box scraper, 60 HP tractor and other discoveries (picture)
   / 10 ft drag box scraper, 60 HP tractor and other discoveries (picture) #11
Allen
Do you have any implements to loosen the ground first before using the box plane? I know may require hooking and unhooking implements or two tractors but would make moving dirt easier.
My Kubota M6040 has 775 pounds of RimGuard in each rear tire. I have no idea how I could get that much weight in cast wheel weights. Let alone get that much weight attached to the rims.
Nuff said..........
I have 315 pounds of cast weight on each wheel and few pounds of bolts and nuts holding it on. I'm probably going to make a trip next weekend to a dealer that sells RimGuard.
Allen
I do have a few implements. I have a cultivator that has 9 shanks on it that I use for things like this but as I said in my first post, those shanks aren't really meant for hard ripping. I've bent several of them. I also have a small tool bar with 3 shanks that can do the primary ripping. but I'd really like to find (or build) shanks that I can use on this blade. I have found several blades similar to this one but not close enough to the same to buy the shanks. And I still don't know who manufactured this blade. Sure gets expensive saving money.
   / 10 ft drag box scraper, 60 HP tractor and other discoveries (picture) #19
My Kubota as it is now set up with a HD Rhino rear blade - FEL & grapple - RimGuard in the rear tires - a tad over 10,000 pounds.
I have a Bush Hog roll over box blade - RO 720. It's 72 inches wide. If I take too deep a cut - I can bring the Kubota to a complete stop - all four wheels digging their own hole.
If I had a wider blade - just take a shallower cut.
However - a 120" box blade is a little big for the OP tractor for two reasons. Width and overall weight. I'm sure the operating manual for a M5740 recommends - 72 inches or less and something less than 1000 pounds for box blades.
2011 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2011 INTERNATIONAL...
2012 Ford F-550 4x4 Chipper Truck (A55973)
2012 Ford F-550...
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A58214)
2011 MAGNUM...
2017 Genie GTH-5519 (A53317)
2017 Genie...
KENWORTH T/A DAY CAB ROAD TRACTOR (A57192)
KENWORTH T/A DAY...
2018 MACK GU813 DUMP TRUCK (A59823)
2018 MACK GU813...
