Traner TR45/ FLand FR45
/ Traner TR45/ FLand FR45 #1
D'oh
Gold Member
N.W.Ontario Canada EH
FF12 Mini Excavator/SDL380Stand on Skid Steer/Traner TR45 Wheel Loader
Anyone have any info? Good/Bad, Originating Manufacture. Pin Head is Threaded, is it Bored for Grease Fitting?
Any Mods needed?
/ Traner TR45/ FLand FR45 #2
These machines are being dumped on the market all over the world under various brand names and price points.
From what I can see there doesn't appear to be any zerks on the Z-bar, lift arms, hydraulic cylinders, and steering pivot, but it looks like the pins may be drilled for them. But I do see zerks on the drive shaft and U-joints.
I'll reserve any comments on fit/finish, quality of build, and machine longevity.
/ Traner TR45/ FLand FR45 #3
I bought one. Can’t find a manual anywhere. Make sure you go over all the bolts and fittings. Most of them were loose. I still need to adjust the clutch. Anyone else have one so we can pick each others brains. Thanks Bob
Congrats SignScape!
It's a neat Machine. Has some benefits over my Stand On, but also some draw backs.
Check all fluid levels. My Diffs and Transmission didn't have any.
The Valve Covers need to be swapped sides so you can add engine oil. Change it too quickly, it is oil but not engine oil.
The Fittings were in the Tool Kit. No issues there, just need to install them.
Added R Clips instead of Cotter Pins in all the Pins.
I recommend removing the Floor Pan, and Looming all the Hoses under there, some very tight/close hoses at the Articulating Section. They will rub through eventually.
Wiring is very sloppy, Wires patched in and taped, no solder or crimps. Clean that up while the Floor Pan is off.
Upper Key Switch is just a Accessory Switch. I plan to run the Engine to it, but will need to add a longer Choke Cable at the same time.
/ Traner TR45/ FLand FR45 #6
Upper Key Switch is just an Accessory Switch. I plan to run the Engine to it, but will need to add a longer Choke Cable at the same time.
Any idea how the clutch adjustment is done. Mine is slipping. Did you get a manual with yours. What fittings are you talking about? I didn’t get a toolbox.
I received a Tool Envelope, Grease Gun that you can't get cartridges for, a couple of wrenches and a bag of Grease Nipples.
I honestly think the Clutch is the weak spot, that and it is geared WAY too High. It just has fingers and a Throw Out Bearing, if the Through Out Bearing isn't riding the fingers, then you have an issue with the whole Pulley.
/ Traner TR45/ FLand FR45 #8
Do you have any play in the clutch pedal when it’s not depress?
I do have a space between the Throw Out Bearing and Fingers
/ Traner TR45/ FLand FR45 #10
Okay then that’s the problem. I have none. Thinking an 1/8” will do it. Thanks for all the help. Been searching for days. Got more info here in the last 24 hours than anywhere else. I have other mods I’m going to do. I’ll post them as I do them. Thank you so much!
/ Traner TR45/ FLand FR45 #11
Break down of the clutch.
/ Traner TR45/ FLand FR45 #12
I received an air and oil filter and two spark plugs in my kit. It is the fl45. I will check fluids tomorrow. Do we go with other mini's for fluid choices as the book had none other than 10-30 for oil.
/ Traner TR45/ FLand FR45 #13
Hello,
I recently purchased a Traner TR45 and the clutch is not working properly. Any one has an idea on how to adjust the clutch?
/ Traner TR45/ FLand FR45 #14
Congrats SignScape!
Hello,
I recently purchase one, my first front wheel loader and I was wondering what kind of transmission oil (transfer case) would be appropriate to use on the Traner TR45? Can you share an example of a brand?
I just used 80W Gear Oil in the Diffs and Transmission.
/ Traner TR45/ FLand FR45 #16
Hello,
Make sure the clutch is engaging. Some owners have had the clutch sticking. Go to YouTube. I posted a video. Another guy has posted one also. Break out the wd40 for a quick fix.
Well, Just sold the Traner45, so off to the Next Adventure.
I did acquire some knowledge, so any question I would be happy to "Try to" answer
/ Traner TR45/ FLand FR45 #18
I bought one. After 20ish hours the clutch release bearing went and I'm currently ordering. One showed up and the numbers wrong. Maybe I can return
/ Traner TR45/ FLand FR45 #19
Any Mods needed?
Hi we're you ever able to find a manual or parts supplier for your Traner T45??
/ Traner TR45/ FLand FR45 #20
Just heard you sold. Did you lose money? I see them auctioning off really cheap...$3000, plus or minus.
Glad to see owners are sharing info about the clutch. Buyers are not going to be able to count on the makers, if known, to offer parts. I would continue to share info, and monitor eBay for sellers who offer items that look correct.
2019 Ford Escape SUV (A61569)
2019 Ford Escape...
2012 Ram 2500 4X4 Pick-Up Truck (A61568)
2012 Ram 2500 4X4...
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A63118)
2022 Greenworks...
2019 PJ TRAILER 32FT GOOSENECK (A58214)
2019 PJ TRAILER...
2015 BOBCAT T590 SKID STEER (A62129)
2015 BOBCAT T590...
20704 (A55853)
20704 (A55853)
