John Deere 5320 starter won't engage
   / John Deere 5320 starter won't engage #1
steve flint
Member
gallipolis oh
John Deere & Mahindra
My 5320 solenoid won't engage or spin the starter, I started to start it the solenoid engaged I let off it and thought I smelled a small burning smell then went to engage the starter only a very weak clicking then nothing, the positive post on the starter tests almost 14 volts, when I turn the key I get an occasional weak click but not every time. The fuse 30Amp is good. I can coast start it, it runs fine and shuts off fine when done. But will not restart only an occasional weak click.
Yes and check the armature brushes while you have it apart.
It’s a bosch starter looks like the solenoid can’t be taken apart. I can get a starter for $150.00 the solenoid still does a weak growl and weak clicking. Sounds like something clicking inside the dash every now and then.I have a little hay to roll I’m roll starting it until I can tear it down and fix it right. Thanks for your replies.
now this afternoon after parking it where i could roll start it, it failed to start when I rolled it? wth
MAGNUM PRODUCTS 35KW GENERATOR (A50854)
MAGNUM PRODUCTS...
John Deere Gator XUV835M 4x4 Utility Cart (A48082)
John Deere Gator...
2020 FREIGHTLINER CASCADIA SLEEPER (A51222)
2020 FREIGHTLINER...
2016 FORD F-250 SUPER DUTY SERVICE TRUCK (A51243)
2016 FORD F-250...
2018 CATERPILLAR 249D TRACKED SKID (A51222)
2018 CATERPILLAR...
Komatsu D39PX-24 Crawler Tractor Dozer (A49346)
Komatsu D39PX-24...
