Man dies after being trapped under rear tires of his tractor
   / Man dies after being trapped under rear tires of his tractor #2
   / Man dies after being trapped under rear tires of his tractor #3
That's terrible; I wonder how that played out, poor fellow.
   / Man dies after being trapped under rear tires of his tractor #4
Trapped or Crushed? It makes a difference. If one is alive but trapped, then it could be a long slow, and perhaps painful death. A cell phone might help.
Use the emergency brake!!!
I "know somebody" who uses their bucket to move the tractor back and forth while hooking up implements. The bucket does hold the tractor in place, and I he always takes them off on level ground.
   / Man dies after being trapped under rear tires of his tractor #6
??? I have two tractors. Neither has an "emergency brake". If you get off the tractor you put the transmission in the Park position - no provision for any brake to be on when parked.
   / Man dies after being trapped under rear tires of his tractor #7
After I position the tractor lift arms to the implement, I turn off the machine and set the parking brake while attaching the implement. If you position the lift arm an inch or so below the implement pins, you can lift the arms manually and slip them onto the pins, especially if the lift arms are telescoping.
   / Man dies after being trapped under rear tires of his tractor #8
I've always had a, more or less, memorable experience with implement change over. Never had the tractor move when doing any exchange. It takes longer - but, never done an exchange with the tractor running.
2012 Mack CXU613 Day Cab T/A Wet Kit Truck Tractor (A56858)
2012 Mack CXU613...
New Holland WorkMaster 37 (A53317)
New Holland...
MASSEY FERGUSON SEAT (A58374)
MASSEY FERGUSON...
2014 Dodge Charger Sedan (A55973)
2014 Dodge Charger...
LOT: (2) Rolling Nut & Bolt Carts w/Bins & Contents (A59076)
LOT: (2) Rolling...
2017 Ford F-550 4x4 DurALift DTAXS39 39ft. Bucket Truck (A55973)
2017 Ford F-550...
