Rotary Cutter Does Direction of Travel Matter?
   / Does Direction of Travel Matter? #41
whatever your method, keep the knives sharp & replace if bent.
a no brainer to get an even cut
   / Does Direction of Travel Matter? #42
This is why I like my HX10, dual spindles mean you can mow any way you want and the cut look likes a lawnmower made it
   / Does Direction of Travel Matter? #43
Both spindles counter-rotate and spaced to back-sweep BOTH tire tracks?
Wish I had enough tractor to run something like that.... or somebody made a smaller mower like it. That would be sweet!
   / Does Direction of Travel Matter? #44
I wanted a dual spindle, but they are more than double the price.
   / Does Direction of Travel Matter? #45
after decades of 5' mowers, years ago went with 3ph 8' twin spindle. surprising just how smooth it runs & cuts. & yes, pricey, mine was around 5.5k. but requires at least a 70+ utility tractor.
otoh, there are many who use 8'+ pull type finish mowers on smaller machines. for me, 3ph lift type is my only option.
to me a 7' single spindle mower is a bastard size, & creates a lot of vibration, etc when you hit something given the long knives, regards
   / Does Direction of Travel Matter? #46
dual spindle require less HP than single for same size, a pull type uses even less. I almost bought a dual 7 ft bush hog for $7500, but went with 6 ft single for around a1/3 the cost.
   / Does Direction of Travel Matter? #47
Dual spindle is the best for clean cut by far, and keeps the deck shorter. Spreads cut material better too. My 10' drawbar bush hog is a great size, good for large areas but still fits in most places
   / Does Direction of Travel Matter? #48
Absolutely right. I have a compact tractor with 20hp pto. NOTHING out there short of single spindle rotarys and finish mowers (I dont have the power for a flail).
So what does a former tractor/mower engineer do in retirement? He builds a prototype mower!
Built from an old beat-up used Keen Kutter 3pt finish mower, it has two 3' dia swing blades/stump jumpers from Fred Cain. It has staggered conventional CCW rotation spindles.
The mower is offset to the right so BOTH tire tracks are back swept. I've been mowing all spring with this thing and it has exceeded my expectations. I knew it would cut well but was concerned my tractor could run it. It does! I routinely cut 20" down to 4" without slowing.... at a full 6' cut width! Because it is mechanically back sweeping the tire tracks, it didnt need high lift blades or high tip speeds... both huge power hogs. Somebody needs to make these for sub-compact and compact tractors!
   / Does Direction of Travel Matter? #49
nice job!
   / Does Direction of Travel Matter? #50
LOVE the cutter, nice work!
Your 2520 appears to be standing tall also.
Any idea of the weight?
2012 Freightliner M2 106 Altec AM650 50ft. Bucket Truck (A55852)
2012 Freightliner...
202479 (A54757)
202479 (A54757)
2018 RAM 2500 SERVICE TRUCK (INOPERABLE) (A55745)
2018 RAM 2500...
2012 CATERPILLAR 304E CR EXCAVATOR (A51242)
2012 CATERPILLAR...
CATERPILLAR CP44 PADFOOT ROLLER (A52707)
CATERPILLAR CP44...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
