New Toyota Tundra’s Recalled for Spun Crank Bearing
/ New Toyota Tundra’s Recalled for Spun Crank Bearing #61
So, real world impact has been less than 900 units, but they recalled 100k.
If you think that's bad look at the battery issues with the GM Bolt. Less than 0.1% worldwide had issues yet all batteries were replaced.
/ New Toyota Tundra’s Recalled for Spun Crank Bearing #62
Torvy on post 52, Thank you.
/ New Toyota Tundra’s Recalled for Spun Crank Bearing #63
It will be interesting what Toyota will be doing about this issue. Will they pull the oil pan and inspect the main bearings for damage? Will they repair or replace the engine? Who knows?
/ New Toyota Tundra’s Recalled for Spun Crank Bearing #64
No matter which way they go with the repairs I feel comfortable in saying that Toyota will make it right.
/ New Toyota Tundra’s Recalled for Spun Crank Bearing #65
Toyota owner here.
Owned multiple Camry's, corola's. Now i have 4runner i bought in 2009. It has 260K miles on it with not a single issue. Brakes, tires, oil and filter. that is it. Most reliable vehicles i cold imagine
Being absolutely happy with all of them i went and bought a new 2024 Tundra Platinum.
1. Wile driving home 4 out of 4 moldings on the doors fell of. They are on national backorder with no ETA
2. Next day i found a couple of spots were there was damage on the paint which were covered with the clear coat and very roughly polished. It was not the dealership fault because i took the possession of the vehicle 1 hour after it was delivered.
3. in less than 1k miles, while accelerating all warning light lit up and the motor died in the middle of freeway.
The vehicle was taken to the dealership where they changed the fuel pump, but since then every acceleration the vehicle jumps and wants to dye. After spending 1 month at their shop they declared they need to change main harness which is, you guessed it, on the national backorder with no ETA.
Toyota refuse to declare it as a lemon on grounds "We do not believe we failed to repair your vehicle"
It is already 6 month, now the case at the KY DA office.
So, yes, 2024 Tundra is junk for only one reason :It is the most American car. Even more American then ford, gmc etc.
It was developed in the US, build in the us, and now we have even longer line of not reliable tracks made in the US
It's possible that Toyota has changed its Texas work force, voluntarily or was forced to due to labor shortages. Who knows the people running or working at the engine plant or the assembly plant? What are their demographics?
My '08 Tundra SR5 Turd model has 295000 miles and is running fine. Zero issues so far but I would not want a turbo anything now. Exceptions are turbo diesels.
/ New Toyota Tundra’s Recalled for Spun Crank Bearing #66
Why I keep driving my 97 F350. It never sees snow or salt and will last me until I no longer need to drive. Been paid for for decades. I'm not to buy a new overpriced truck loaded with gadgets that will ultimately fail.
I would, if I were you, is pray every day "Oh Lord, let me not become a curmudgeon as I age." It might be a little late for you but you can try.
/ New Toyota Tundra’s Recalled for Spun Crank Bearing #68
It always was that way so let's hope it stays that way.
/ New Toyota Tundra’s Recalled for Spun Crank Bearing #69
From what it sounds like, they don't have a plan yet for repairs. It will be interesting how long it will take for customers to get their vehicles back.:rolleyes:
/ New Toyota Tundra’s Recalled for Spun Crank Bearing #70
I hate to rain on anyone's parade and I have driven or owned Toyotas for over 50 years.
To say that Toyota will take care customers is Totally off the mark, as in hogwash.
In the past 15-20 years and as recently as a year ago, Toyota has settled many lawsuits, class action suits, over a plethora of complaints. My wife's Toyota Prius had an inverter issue where the electronics in the HV inverter could fail and could, and did, leaving motorists stranded in a middle lane of a busy California freeway. There were some reported fatalities.
I would love to say that TMC stepped up to the plate and assisted all of the affected car owners but no, they denied, denied denied, were caught in lies and were caught lying in Court and the NTSB over this, the gas pedal sticking issue, the emissions issue, their cut throat consumer loan practices etc
I would estimate that TMC has paid out well over 2 billion dollars in fines to the Feds and compensation to US consumers.
These were not voluntary paybacks or rebates. TMC was forced to do so. I did not mentioned all of the criminal complaints and it grieves me to give a synopsis on a company I once thought very highly of. NO MORE.
Just search for Toyota class action suits. re our Tundra's, expect more lies and obfuscation.
I still think very highly of my old Tundra, but trust the dealer or the Corp? NO F Way.
of course YMMV
/ New Toyota Tundra’s Recalled for Spun Crank Bearing #72
I thought we were discussing Toyota Motor Company
/ New Toyota Tundra’s Recalled for Spun Crank Bearing #74
Nothing wrong, just what did you add to the original thread? We were discussing one of the top auto manufactures.
/ New Toyota Tundra’s Recalled for Spun Crank Bearing #75
I have a 2023 Tundra that has about 6k miles on it.. its been at the dealer for 3 weeks trying to figure out what is causing a vibration that's felt in the steering wheel and gas pedal when speed is held constant in the 70s.. my suspicion is that's its some rotational out of balance issue in the motor or transmission.
/ New Toyota Tundra’s Recalled for Spun Crank Bearing #76
Depends on what you call "making it right". If this is like the V6 engine sludging, the flimsy truck frames or the unintended acceleration issue their response will probably be: (1) deny there's a problem (2) when that fails, blame the customer for doing something wrong (3) when it becomes apparent it's a manufacturing/design problem drag feet working on a solution...never hurts to say the info they need is in Japan and they're searching for it as we speak (4) Putting the PR machine into overdrive to make it look like they're really concerned about their customers (5) once the problem is found, throw a supplier under the bus for providing components that didn't meet their "rigorous" standards. All this accompanied by much kicking and screaming. :poop:
/ New Toyota Tundra’s Recalled for Spun Crank Bearing #77
I've owned Toyotas for nearly 40 years and don't want to believe any of the above even though I see signs of it. Toss in planned obsolescence, certain parts designed to fail, difficult to service formerly user serviced things like oil changes and I'm getting concerned.
/ New Toyota Tundra’s Recalled for Spun Crank Bearing #78
I've been trying to tell people for decades that Toyota superiority is a myth. For every Toyota with 500k on the clock there are ten Fords with 500k on the clock. There is nothing special about a Japanese truck.
We went from bodies that were rusted by 25k miles in the 1980s to frames that folded like a lawn chair in the 1990s to engines that lost crank shafts and head gaskets in the 2000s to the modern era with plastic beds that crack under load, engines that fail, turbos that blow, and electrical nightmares galore. How in the world did Toyota ever get the reputation they have? The PR team must have been brilliant.
/ New Toyota Tundra’s Recalled for Spun Crank Bearing #80
Just stop.. I added the same thing everyone else added. Context. When we talk about our favorite or not so favorite, whatever, the logical thing to do is compare it to it's competitors. I bought my first Toyo in 1976, my first Datsun in 1979. There have been few years that I haven't owned at least one of them. I could only wish that my newest Ram truck is as good as my 2008 Tundra has been.
1992 Talbert 70 Ton Lowboy Trailer with Removable Gooseneck (A61307)
1992 Talbert 70...
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
2007 Freightliner Columbia 120 T/A Wet Cab Sleeper Cab Truck Tractor (A60352)
2007 Freightliner...
FORD F SERIES DUMP TRUCK (A52707)
FORD F SERIES DUMP...
2019 Case CX80C (A60462)
2019 Case CX80C...
2016 Kubota L3301 (A60462)
2016 Kubota L3301...
