Hard water car wash solution?
/ Hard water car wash solution? #1
dodge man
Super Star Member
West central Illinois
JD 2025R
So this is a problem I’ve had washing my car at home. We have three vehicles one of which is a Dodge Challenger that is black. It’s the car that wants to spot from hard water. I recently bought a foam cannon and use a wash and then a rinse product that helps, then immediately pull it in my garage and dry it down but still get some water spotting.
I bought a TDS meter and untreated water shows a little over 500. We have a water softener in the house and it tests higher than the unsoftened water. After doing some reading I learned this is normal, the water softener replaces “bad” water hardness with good so I’m convinced it’s working normally. Do to some logistics it’s difficult to wash the car at the house but possible.
I realize this is a problem only a car nut would worry about but I’m looking for something I can hook up in my shop for a rinse of my car that won’t spot. I looked on Amazon and didn’t really find a result I was sure would help. I can keep going to the car wash but they keep jacking up the price. Anybody have a first hand solution with a specific product?
/ Hard water car wash solution? #2
Pressure washer with 'spot remover' injection.
/ Hard water car wash solution? #3
...Anybody have a first hand solution with a specific product?
I'd like to hear about that as well.
We have soft water spigot on the side of our house. That's about the only way I can keep them from spotting. I've tried rinses, etc., but the general consensus amongst my car buddies is to get a soft water spigot. :(
/ Hard water car wash solution? #4
I have the same hard water problem. Also have a water softener but still get water spots.
I have two classic cars and after washing and drying I find I still have to go over the entire car with Maguires quick detailer (or your brand of choice) with microfiber towel to buff out the water spots.
I've seen ads for some kind of finish (possibly ceramic finish) that forces water to run off and not let it bead up and dry as spots but haven't tried it yet.
/ Hard water car wash solution? #5
There are some interesting videos out there.
Mostly, they tell you to wax your car well in the first place with ceramic coatings and that'll let most of the water run off to begin with. Soft water if available, portable deionizers, and shade.
I ceramic coated my car recently and bought a ceramic rinse product with my foam cannon. It still wants to spot.
/ Hard water car wash solution? #7
Is that ceramic wash and coat just sprayed on? The product I've seen is applied by hand as you would a good wax then residue is wiped off with microfiber towel. I tried a similar product using my foam cannon but then hosed off and still got spots. I think the only way to achieve success is to hand apply ceramic coat finish and wipe off with towel. Hand applied wax is good but allows water to bead then spot.
The ceramic wash and coat is just sprayed on with a foam cannon and then rinsed off. I also used a ceramic wax that I applied with a machine buffer.
/ Hard water car wash solution? #9
I realize this is a problem only a car nut would worry about.....
I'm not a car nut (just a general nut LOL) and I have the same problem. Only thing I've I've found that prevents the hard water spot staining is that immediately after I've washed it, I have to put it in the garage and use Turtle Wax dry and wax, or similar spray and with a microfibre cloth use the spray and dry it off. My trucks been ceramic coated which didn't do anything as far as water stains was concerned.
/ Hard water car wash solution? #10
I just watched a video to use a portable water deionizer that removes minerals in the water along with special low Ph car wash soap. Then rinse and blow dry the remainder of the water off.
Deionizer price is too much for me to spend so I guess I'll keep doing what I have been. Another video says to use the deionizer to rinse the car after washing as it would get expensive replacing the resin if used to wash and rinse.
/ Hard water car wash solution? #11
Expensive, but it really works. Wash, rinse, blow dry - no spots on a black car!
Turbo36 that’s kind of what I had in mind. It’s just more than I’m willing to spend.
/ Hard water car wash solution? #13
That is what I do with the new car using the $17 Cerakote ceramic paint sealer. It is pretty hydrophobic after sitting overnight. I have been using a Toro plug in high power leaf blower to dry the car immediately after washing, it works pretty well. But Black is tougher than almost anything else. Not sure if the Cerakote will get rid of hard water spotting, but I do notice most of the water runs right off now and the blower gets most of the rest.
/ Hard water car wash solution? #14
How about collecting rain water and rinsing off with that.
Someone told me thats how they wash their car and they collect it off the gutter, into a 275 tote.
I’ve given that some thought. I’ve already got the tote too. I’d have to rig up some kind of pump.
/ Hard water car wash solution? #18
Do you know what brand? How long do they last?
It's a Pentek 4.5 x 20. Capacity of 1850 grains. I also run a water softener cartridge before it. I think the D.I. cartridges are over $100, so you want the water as clean as possible going into it, hence the softener cartridge first.
/ Hard water car wash solution? #19
Would an under sink RO system with a 275 gallon storage work? They are relatively inexpensive and easy to install. Upwards of 50 gallons a day. Just a question in my mind.
I think just about anything would be better, I think it’s just the final rinse I need to be soft water.
Solesbee Hydraulic Thumb (A61166)
Solesbee Hydraulic...
(INOP) 2017 FORD F550 XL SERVICE TRUCK (A62130)
(INOP) 2017 FORD...
Bobcat T66 (A60462)
Bobcat T66 (A60462)
2013 KBH Hopper Bottom Trailer (A64047)
2013 KBH Hopper...
1998 Ford L9501 Louisville 101 Truck, VIN # 1FTYN90K4WVA35579 (A61165)
1998 Ford L9501...
UNUSED ATS GAC40Y 40 GAL.AIR COMPRESSOR (A62131)
UNUSED ATS GAC40Y...
